Question about Uniden Bearcat Pro PC78LTW 40-Channels Base CB Radio
Not working right
Will scan but audio is really low and ditorted. But i accidently touched a pin on contorller board and audio comes up fine and stays on till you unplug it or turn it off.when you turn it on then you have to touch pin again to get sound.
  • james morgan May 11, 2010
    what pin did you touch on the pll chip audio chip what is the ic number. sounds like it is shorted out give me the part you touched???
  • 86 Answers
Sounds like a cold solder joint,I would resolder
all pins in that one place
Good luck maybe this will help
Posted on Sep 25, 2009
Hi, My Roland Fantom G6 keyboard has an accident and the analog output is dead. I ask you if it is a possibility to find the entire Jack Board for replacement. It is named: FANTOM-G6 JACK BOARD ASSY...
Does the headphone jack work? Replacing a whole board would be expensive and the problem could be elsewhere. What was the accident? If large signals were driven back into the audio out lines, probably the output driver chip is fried... They likely use a common 8 pin dual op amp as the driver and the part costs 50 cents. It takes a little care to replace it as it is likely surface mounted. I am looking at the audio/jack board for a G-600 and there are a pair of transistors for some testing they do that could also be fried and might be the whole problem if the G-6 uses same or similar circuitry. The Fantom X6 uses very similar circuitry... Download service manual here:
http://elektrotanya.com/roland_fantom-x6.pdf/download.html
Scroll down to "get manual" and click to download. IGNORE other download links. On page 57 of 66 you will find the audio drivers at the right. They use little dual op amps M5218APF which probably are available someplace, however probably 4568's would work fine and are readily available. If you drove high voltage into the audio outs, I suspect first that the RF bypass caps such as C203 on the above schematic shorted. Simple to replace... pennies apiece... The test path transistors such as Q37 may also be shorted... Next would be IC18... While this circuit may not be the exact one for the G6 it probably is CLOSE as the several Rolands all seem to use similar circuitry. Regarding system SAFETY... Make sure ALL and I do mean ALL equipment interconnected including mixers, powered speakers, keyboards, etc. are powered from the SAME receptacle or power conditioning module to avoid accidents. Also for keyboards sent to mixers, USE DI boxes please! These protect against ground loops and these accidents.
Sep 13, 2011 | Roland Fantom G6 61 Key Pro Keyboard...
Everytime I turn on the television everything works fine except no sound. Sometimes unplugging the set and plugging it back in a few moments later fixes it. Sometimes redoing the 10 minutes long auto...
it signifies that there is a problem in the audio circuit on the PCB BOARD TV, you should check starting from the section "Audio Amplifier" check incoming voice signals on the L or R-in Audio-in Audio that led to the AUDIO IC amplifier. If you hear a sound when touched (touch point of tin solder to use a screwdriver) audio input pin means in part that there is no problem, you proceed to check into the IC close to the tuner (it is usually called Chroma IC / VIDEO + combination of Horizontal Drive + Vertical Drvie + IF). Just look at the physical form of IC is greater than the other ICs. tin solder first check whether there are loose or melting resulting in less good solder connections on each foot of the IC. It enables voice sometimes appear and sometimes not. if, after checked and looked normal / still good, you must replace the IC. I did not explain exactly NO. CODE from the IC because you do not describe the specific model and brand of your Flat TV.
Aug 26, 2010 | Televison & Video
Water and ice despenser doesn't work
you have a dual water valve one side for ice and other for water ( foutain ) but both never fail at same time so look at the pc board ( touch contorl on front of door this is prob the problem . ck for loose connections to board .before replacing .it .. mm
Aug 10, 2010 | Maytag MSD2756G Side by Side Refrigerator
Auxiliary too quiet when using my iPod!
clean all conects with acohol and cheak for shorts
Jul 08, 2010 | Pioneer DEH-P7700MP CD Player
Right light comes on- but then shuts off trying to get to turn on
First, check your fuse, it really could be that simple. Check it with the Ohms setting on your DMM, do not bother with continuity. If it is under 1 the fuse is fine.
It actually sounds like a short in the amp circuit. Inspect the amplifier where it connects to the heat sink. Check for signs of oxidation or any contaminant that may cause a short in the amplifier. Ensure there is ample thermal grease between the amplifier and the heat sink. You may wish to reflow the 22 pin connection on the board. I would recommend desoldering the whole component if you can, cleaning and testing it, and resoldering to the board with fresh lead free solder and no clean flux.
If the amp is blown you can replace it for around $70 USD.
Apr 02, 2009 | Pioneer VSX-D510 Receiver
Green light comes on then off 3 times.
I had this problem with mine. And it is caused because it is a safety shutdown-
The Safety shutdown may be broken into five distinct sections:
• Audio Power Supply and Audio Output Monitoring
• Main Run Power Supply Loss (PS LOSS)
• Rear Projection Instrument Safety (CRT Scan Loss protection)
• Startup Delay
• Power Supply Overvoltage
When taking measurement I used Pin2 of IP250, It is located in G-0 on the Voltage regulator board.
First off, check the main safety transistor, TP210 located at G-2 on the power supply/scan Bord. It will have 3 semi large heat sinks and the main tube power cables coming off of it.
The Emitter should always be 5Vs, The emitter is also the Furthers pin form the heat sink it is right by, So if looking at it face on to the flat side of the transistor the emitter is on the right.
The base when in:
normal high
protect low
off low
The collector goes to the power switch and should be
normal low
protect high
I pulled mine out to check to see if it was bad because it was reading odd like a shored EC, and it checked out fine. After re-soldering it back in, my set worked fine! Over my TV's life it seemed to have produced a weak point in its solder joint I guess. That in your case seems like it is about to go out for good.
I would say just re-solder that and you should be good to go!!
It this does not work for you let me know, I have much more information.
Regards
Joe
Jan 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv has problems cuting on
• Startup Delay
The base when in:
normal high
protect low
off low
normal low
protect high
Regards
Joe
Jan 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
LG Trax Phone - headset adaptor
I recently bought a similar adapter for my trax and had the same problem. Taking the plastic cover off of the adapter, I found the following on the back of the 18 pin connecter: a jumper from pin1 to pin 11, a jumper from pin 9 to pin 10. audio l and r wires to pins 14 and 15, common audio wire to pin 18 and unconnected pin at pin17. By accident, I found that if the unconnected pin 17 bent over to touch the wire to pin 14, the headphones started working. So, solder a wire to connect pin 14 to 17 reinsert these pins into the correct slots and you have a working adapter.
Dec 26, 2007 | LG CU500 Cellular Phone
Sound only coming out through one speaker
Try looking at your volume control connector. I found that 2 of the prongs were smashed down, so I got a tweezer and straightened them back up. As soon as I plugged it back in, the blue light on the volume control appeared (before it wasn't working at all), and the right side speaker worked again, whereas before only the left side had sound coming out of it.
Mar 25, 2007 | Creative Labs I-Trigue 2.1 3300 Computer...
Uniden Bearcat Pro PC78LTW 40-Channels Base CB Radio Logo
50 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
