Question about RCA 20F512T 20" TV
Can't turn tv on. hooked up thru comcast cable.
Can't turn on. hooked up thru comcast cable.
was working, now sauddenly doesn't. standby light is on. disconnected cable. still cannot turn on. plugged in ok.
3 Suggested Answers
SOURCE: I have an RCA 50
I found out the model number is P52820BL and after researching on the internet further I found this set has a problem with power outages. I found a site that told another person with the same problem that it would take about $350 to fix - if it could be fixed - and there is no guarantee it would work for long after. Therefore, we decided not to bother fixing it. We are getting a new one.
Posted on Dec 03, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Posted on Mar 01, 2009
Testimonial: "Thank you. I forgot to thank you when I first read this response. Works fine now though :)"
I have comcast cable serice. Do I have to hook up my dvd/vhs recorder to comcast box or just to my tv?
Your tv. You will use your tv "source" to select which input to watch from. Everything goes to the TV. I have a surround sound amp that I run the sound FROM the TV that way if I want it loud I turn that on. It is the only exception.
Dec 29, 2014 | Televison & Video
Cant take tv off standby mode
cant get my tv out of stand by mode and don't have the original remote but it is hooked to comcast cable box. what can I do!
Sep 09, 2012 | Philips Magnavox 27MS343S 27" TV
I hooked hdmi to tv. i went thru ps3 settings for video n audio n swithch audio to the red n white output. now i have sound thru surround sound but my video is flickering n i cant c so i can undo it
Make sure the Component AV Cable is connected to the AV Multi Out port on the back of the PLAYSTATION 3 system. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the ON/OFF button long enough to reset the Video Output Settings.
3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jul 01, 2010 | Sony Playstation 3 (PS3) Console
Can't hook up Comcast cable box into tv. It is an HD comcast cable box and I am trying to hook it up to my childrens princess tv/dvd combo. I can't figure it out. Please help.
I assume this TV has no Audio In and Video In, from your Cable box there's an antenna out or cable out, connect that to your TV's antenna in, and make sure that your TV is tuned in to channel 3 or 4, try those two channels. You can only change channel thru your box, your TV channel is alway's on channel 3 or 4.
Jun 26, 2010 | Disney Princess TV/DVD Combo
Black screen, hear voices , but no picture playing?
check your screen back Light or get a working screen and test it or your screen flax is bad
Mar 31, 2017 | Mitsubishi WD-73C9 73" DLP TV
LCD TV is hooked thru cable box. When you use the
Try this (may not work):
1. UNPLUG power from TV at wall outlet.
2. Turn ON the TV (with no power cable plugged in).
3. Plug power cable back in (at wall outlet)
4. Turn ON TV (don't use remote this time).
Hope this works!
Sep 03, 2009 | Televison & Video
Closed captions will not work thru my tv remote
I hope this was resolved but this is a dish page and I am unable to answer Comcast issues.
Feb 14, 2009 | DISH Network 811 HD DTV Receiver
No sound from TV thru sony bravia hdx576wf; DVD & CD audio ok.
Could be a sync calibration issue. Try to divert the TV sound to another input source on the Hometheatre system if possible, if it is a go then maybe the TV audio needs to be recalibrated. Make sure TV audio setup menu option has not changed also.
Feb 08, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
No Signal HDMI
Had the problem. Turned out to be a defective hdmi port circuit board.
Aug 04, 2008 | Insignia 42" LCD Flat-Panel HDTV
My internet won't work on my new laptop.
First turn off you laptop. Second, go to your comcast cable modem unplug it from the wall and wait about 3mins. Now plug the comcast modem back it and wait for all the lights to come back (will take about 2-3mins). Now plug the yellow ethernet cable into your laptop if its not already and turn your laptop on. You should now have internet.
Also if you using a Comcast Surf Board modem be mindful of the standby button on top of the modem. You can tell your in standby mode if the standby light (bottom light) is amber. If it is press the standby button once to get out of standby mode.
hope that helps
May 12, 2008 | Computers & Internet
RCA 20F512T 20" TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
