Question about Canon S400 InkJet Printer
My old canon S400 is not printing anything. Trying maintenance checks but still will not print pages. The on off light flashes yellow 8 times follwed by 1 green light flash. What is the problem?
  • 4,041 Answers
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
All the best Pineworks
Posted on Feb 13, 2010
On the Ip4300 the yellow light flashes at 10 times intervals. The printer does not responde to anything. Thanks Dave
This is from Canon's web site...
Ten flashes:The Cassette is not installed properly/Cannot perform duplex printing
  • When loading from the Cassette, install the Cassette properly and press the RESUME/CANCEL button.
  • When performing automatic duplex printing, the size of paper may not be compatible with automatic duplex printing. The sizes of media suitable for auto duplex printing are A3, Regal, 11" x 17" (Tabloid), B4, A4, Letter, 10" x 12", 8" x 10", B5, and A5". Make sure that the size of the paper loaded in the printer is correct. Pressing the RESUME/CANCEL button will eject the paper and restart printing from the front side of the next paper. The reverse side of the ejected sheet will not be printed.
May 04, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Maintenance warning/technical issue message stops printing
You just need to reset your printer. Google search a resetter program for your printer model.
Jan 10, 2010 | Epson Office Equipment & Supplies
Flashing yellow light. paper does not load.
It's trying to say that the page you are trying to print is too complex.If you press the button to cintinue it may print out part of the page. Check the printer driver for print resolution settings. Change it to 300dpi and try again. Or, you could always add some extra memory to the printer. If you decide to add extra memeory, don't forget to tell the print driver it has more memory
Oct 14, 2009 | HP LaserJet 5L Printer
Do I need a new print head?
5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
8. Your printer should respond as normal.
Sep 13, 2009 | Canon BubbleJet i560 InkJet Printer
Canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Jul 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
No yellow printing from my color cartridges
The nozzles that the yellow ink flows thru are clogged. Try the print head cleaning utility. Right click on the printer, select PROPERTIES, select the MAINTENANCE TAB and press the PRINTHEAD CLEANING button. If that doesnt work, turn off printer, open front cover and move the ink carriage toward the center. You should see a small rectangular cotton sponge pad thats covered with old inks. Put several drops of Windex on it so that its nicely soaked and return ink carriage. Turn on printer and run the print head cleaning utility again. Then let it sit overnight. The next day, try printing a test page.
Jun 17, 2009 | Canon BJC 1000 InkJet Printer
Printer printing in with stripes
You can try to perform a power purge, do it by the following:
  • Enter maintenance mode. Either with starting your machine with Menu button down, or by pressing Menu, 2, 8, 6, 4 quickly. The fax/copy/scan buttons should flash/be lit.
  • Press 7, 6.
  • Press 3, the machine should now say something like "POWER_P" or "P_PURGE"
  • Press Mono/Black start, the machine should now say "cleaning".
  • When it's done, the display should say Maintenance, and you can leave this service mode by typing 9, 9.
You can now try printing a test page again, the result should hopefully be better.
Be noted however, that this purge takes ink from your cartridges, but it's more likely to solve the issue then just trying to do more "regular cleaning".
Jun 14, 2009 | Brother DCP-585cw All-in-One Wireless...
Canon S400 lite binks 6 times won't print.
1. Turn off printer
Dec 27, 2008 | Canon S400 InkJet Printer
CANON S400 PRINTING PROBLEM
What printer do you have? Clean heads, clean heads, clean heads, etc. Then do the test print to see if the heads are open. I had similar problem with an Epson, had to clean the heads often, finally got to where the heads wouldn't clean so threw it away and bought another one (HP this time, the heads are included in the ink carts, haven't had to clean the heads at all.)
Nov 02, 2008 | Canon S400 InkJet Printer
Canon S400 InkJet Printer Logo
357 people viewed this question
old marine
old marine
