Question about Toro Lawn Mower With Toro Power Tools
I have a 2006 Toro 6.75 hp GTS lawn mower. I am
I have a 2006 Toro 6.75 hp GTS lawn mower. I am having difficulty starting. Oil has been changes, plugs are new and gas is fresh. Engine will crank and run high and then immediately stop.
  • 86 Answers
Your carburetor needs cleaned,you had gas in it that you drained out and replaced with new ? What engine do you have tecumseh,briggs,? Anyway remove carburetor and take apart get acan of carburetor cleaner and spray though jets in carburetor and blow out jets be carefull not to blow out needle seat !
Posted on May 16, 2009
Just wondering if this solution solved the problem? I am having the same problem.
Posted on Jul 28, 2010
I need to know why my toro gts 6.5 hp lawn mower engine starts and cuts off immediately
clean out all your carb jets look at the main jets and clean out little holes you cant see with ***** eye this will fix your issue check for dirt in fuel tank
Joe
Sep 11, 2012 | Toro Garden
My lawn mower wont keep running, I have put on new spark plug, cleaned the carborator, changed the air filter. Any other ideas?
How thoroughly did you clean the carb? They need to be fully disassembled. There are some small orifices in them that need to be cleaned with either a jet cleaning tool or a piece of wire.
Aug 18, 2012 | Toro Lawn Mower With Toro Power Tools
Toro GTS 6.5 HP doesn't run well in grass. Any ideas?
Has the fuel filter been replaced lately? Also you can look to see if the new spark plugs are getting fouled out still. Sometimes just replacing the spark plugs wont fix the problem.
Feb 17, 2012 | Garden
Toro recycler self propelled 6.5hp, 22" (gts)
Hi steve16092...
You may have MAJOR damage to your motor because of overfilling the oil.
Sometimes you can bend or break a piston rod when the engine is overfilled.
Meanwhile you can check a few other things.
Take your plug out and ground it against the head of the engine with the spark wire attached to it.
You should get a bright blue spark, if not then check your ignition module, it may be faulty.
If you have spark, then try putting a little bit of lighter fluid/or gasoline in the cylinder and reinstall the plug and try to crank it...if it cranks, then you may need to clean/rebuild your carburetor.
Please take time to rate me
Aug 18, 2011 | Toro Power Lawn Mower
Change oil in TORO GTS personal pace
warm engine remove dipstick place drain pan on floor tip mower on side so dipstick tube is over pan
Aug 14, 2010 | Toro Lawn Mower With Toro Power Tools
I have a Toro Super Recycler GTS 6.5 HP. Upon starting the mower white smoke comes out of the exhaust (silver housing) on the front. The smoke stops after about 2 minutes of running. Any ideas??
Oil level too high? *(check oil level with dipstick fully screwed down!)
or
Leaking valve guide *(rare.)
Cylinder walls not sealing well and oil leaking past rings. *(less rare...nothing you really can do about....just getting used up)
I would change the oil and be very careful to fill only within the full range.
Then, run the unit once to clear the muffler out.
Good luck and be careful!
Jul 21, 2010 | Toro Super Recycler Super Bagger Lawn...
How change oil on my Toro GTS 6.o HP lawnmower
the drain plug should be under the blade plate, remove the plate to expose the drain plug, should have a quarter inch square drive or a half inch square drive, undo it to drain the oil.
Should take around .5 of a litre
Apr 11, 2009 | Garden
Toro Lawn Mower With Toro Power Tools Logo
1,542 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
