Dryers Logo
Posted on Dec 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replacing ge dryer motor need wiring diagram - GE Dryers
Melissa Martin
Level 3:
Master:
  • GE Master 753 Answers
  • Posted on Feb 04, 2014
Melissa Martin
GE Master
Level 3:
Master:
Answers
753
Questions
0
Helped
196064
Points
1330
Need model number to provide wiring diagram
3 Related Answers
Anonymous
  • 288 Answers
  • Posted on Mar 13, 2008
SOURCE: Ge Commercial Coin-Op Dryer.
When you replaced the motor, did you replace the relay? It sounds like you have done everything reasonable. I would try bypassing the coin operation part and see if that changes anything. Go back to the motor relay. It may be incorrect application. the part guys only know what the computer tells them. it may need a different one. I am assuming that when the unit shuts off you checked for power from the timer to the next place, according to the diagram.
Testimonial: "Ended up selling all of our commercial washer/dryers and going with a rental company. Best all around for our cost, man hours and headaches."
Anonymous
  • 6966 Answers
  • Posted on Jun 17, 2008
SOURCE: need a wireing diagram for
Often the wiring diagram maybe found in the console area or under the dryer top panel. Due to regional differences in electrical code and power requirement, wiring system hence the diagram may differ. Additionally, it would also differ if you are using a 4 wire outlet or a 3 wire hookup.
At this point, perhaps your best bet would be to seek the services of a qualified professional who is very familiar with the electrical/power system of your area as well as general wiring of dryers. Should you venture a DIY, pls post back power requirements/availability whether for a 240/120 or 110/110.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Anonymous
  • 1543 Answers
  • Posted on Apr 16, 2009
SOURCE: converting 3wire GE Dryer to 4Wire connection
Remove the wire or metal strap from the center terminal to the dryer frame. Put the white wire on the center terminal. Put the green wire on the dryer frame. Red to one outside terminal, black to the other.
1helpful
GE DVLR223EG clothes dryer. I need a wiring diagram please?
Question edited for clarity.
Try GE direct. They have a page on it.
https://products.geappliances.com/appliance/gea-support-search-content?contentId=19249
There are promises of Service Manuals but they don't open
https://www.google.com/search?q=GE+DVLR223EG+wiring+diagram
You could also look at videos working on the unit and see if you can freeze frame where they remove the console?
https://www.google.com/search?q=ge+dvlr223eg+replace+heating+element
Mar 25, 2023 • GE Dryers
One of the wires that connect to the motor is fried on my GE dryer. Do I need to replace the motor?
The heating element is faulty , I don't know if parts are available,some times repairs are worth more than a new unit please check.
Sep 14, 2019 • GE Dryers
1helpful
Need a color coded wiring diagram of the timer M460-G for the GE electric dryer DSXH43EAOWW
All GE dryers have a wiring diagram inside the control panel on the left side as you stand in front of the dryer. It should show the wiring in black but with color coding listed for each wire. If yours is missing I will try to locate a copy. SearsPartsDirect use to have some wiring diagrams on their parts site.
Jun 03, 2015 • GE Dryers
I don't know where the color cables go on the timer pals shaft for my ge dryer
you need to find wiring diagram it should be in the console with the timer the wiring diagram will tell you which wires go where
Hello all I have a GE DCLR333ETOWW Electric dryer. When we got it the start button was missing so I had the Blue and Brown Wires sticking out and we would just touch them together for a second and the...
first things first. Electric dryers are 220v on a double breaker in your breaker box. (120v for the motor,120v for the heater element). When your dryer sparked, it probably tripped the breaker. Note: you REALLY need to buy a switch an get those exposed wires back inside of the dryer where they belong...just sayin'
Apr 30, 2017 • GE Dryers
2helpful
Ge dryer #DBXR463ED2WW does not start and power is going to dryer
You said, GE dryer #DBXR463ED2WW does not start and power is going to dryer
Here are the 5 most common reasons for your Electric dryer not to start.
Door Switch
The door switch must be operative before the dryer will start. Ensure the door switch strike is properly actuating the switch and if so, check the door switch for continuity with an ohmmeter for proper operation.
Faulty Drive Motor
If the motor will not start, it is possible it is defective. The wiring of the motor is different for each brand and you will need to refer to the wiring diagram of your dryer for the specific terminal locations. You will need to use a volt/ohm meter to check for resistance between the run winding and common (may be referred to a neutral). If there is no resistance, the motor is open and will need to be replaced.
The motor bearings can also go bad. A dryer with a motor in this condition can sometimes be started by hand and it will run. However when the motor gets hot the bearings begin to seize and the motor will stop. In this condition you must also replace the motor.
Electric Dryers:
On Electric dryers you will need to check the heat element for resistance. With the power disconnected, remove the two wires connecting to the heat element and check the resistance of the heat element by using a volt/ohm meter. The resistance should be between 5 and 50 ohms of resistance. If there is no reading the element is defective and will need to be replaced.
Heating Source
If the element is not receiving power it is likely that one of the thermostats is defective.
Thermal Fuse
The thermal fuse is in series with one leg of power to the motor. If the fuse is open (no continuity) the motor will not run.
The thermal fuse is located in different locations according to the model and brand of dryer.
Solution:
Check the thermal fuse for continuity with a volt/ohm meter. If it is open, it will need to be replaced.
Timer
The timer is the source for power to the motor and if the timer contacts are defective, there will be no power getting to the motor. Since the wiring is different between brands and models, you will need to refer to your wiring diagram for terminal locations. Once you have located the correct terminal for the motor operation, you will need to turn on the dryer and check for 110v from the timer terminal for motor operation and the chassis ground. If you have the voltage, the timer is most likely okay and the problem is elsewhere. If there is no voltage, the timer is defective and must be replaced.
Thank you for using just answers.
Please remember to leave a solved rating befroe you sign out!
Huuum
Jan 23, 2009 • Dryers
1helpful
Dryer will not start
Faulty Drive Motor
Dec 05, 2008 • Dryers
Mar 13, 2008 • Dryers
Top GE Dryers Experts
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
