Sony KDL-46XBR4 46 in. LCD Television Logo
Arturo Lee Posted on Dec 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Flash 8 times - Sony KDL-46XBR4 46 in. LCD Television
Richard Lilja
Level 3:
  • Master 401 Answers
  • Posted on Dec 28, 2013
Richard Lilja
Master
Level 3:
Answers
401
Questions
0
Helped
244455
Points
1244
When it flashes 8 times it is indicating a possible Audio Protector circuit fault. this circuit is located on the "AU" board. You will probably have to purchase a new AU Board if you were to attempt to fix it yourself!
Good Luck!
Rich Lilja
FUJITSU Indoor Inverter ASTA09LCC/ASTA12LCC airconditioning - not cooling
If the operation button is flashing 8 times, the timer light should also flash 4 times in each sequence. This indicates a failure of the PFC circuit in the outdoor unit which basically means a faulty outdoor board and will have to be replaced.
If the operation light is flashing 8 times by itself, the indoor controller board may have a fault. You can normally test this by putting the mode on the remote to 'Fan' and checking that the controls otherwise work normally - louvers work as directed and fan speed changes correctly when selected on the remote.
Most likely the fault lies in the outdoor board but you should contact a tech to diagnose correctly.
2helpful
Flashing start button, beeps, no other button functions
does it flash say 8 times then a little break then flash again 8 times or 9 or 10 . The flashes are giving the type of fault you have. Say 3 flashes then a tiny break then 3 flashes and a tiny break so on...
1helpful
Screen flashes and power light blinks 8 times
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
Thanks for using Fixya
'99 Mercury Cougar - Seatbelt light flashes 8 times in pattern
? I wounder what color is your lamp - red or yellow (amber) and just so you know most parts stores now days can tell what a code is with out charging a dime to you.
KP-57WS500 8 blinks will not power on
High Voltage Splitter Block #8-598-955-32 8 Blinks Call MAT electronics 1-800-628-1118 or Electronix Parts 1-800-223-3205 or you can go to thier websites online.
No sound or screen
8 time flash shows problem with T8005 (flyback transformer, horizontal transistor) in D board. Service manual says ...
High voltage error 8 times • T8005 is faulty. (D board)
bye
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
