Question about Symbol MC9090 Barcode Scanner
Connecting to the internet
How would i go about actually connecting a Motorola Mc9090 to our wireless network, this really is a first for me this kind of operating system. Many thanks alex
  • 61 Answers
Hi there, this one might help since the OS is Windows mobile 5. the settings on your handheld might be quite different but still this may work. Please turn on wi-fi. There is a small icon below for wireless simply tick that and it will turn on wi-fi. Once you turn it on it will detect available wireless networks or you may simply go to Start menu and select settings. Go to connections and select network. It will give you available wireless networks. If prompted for the pass key or encryption, use the encryption set to the wireless network you're trying to connect with. Once you input the correct key you should be good to go.
Hope this helps
Posted on May 15, 2009
Can't get my friends motorola photon to connect wirelessly with my linksys WRT160N
Please see if you have a secured wireless network.
Go to 192.168.1.1 from Internet explorer.
User id =blank
Password =ADMIN
Go to wireless security tab and get the security key from there
try this while connecting to the network.
Dec 29, 2012 | Linksys WRT160N Wireless Router
Why does my internet keep dropping?
change your connection system
you can get TP link units that plug into the house electrical system and run ethernet cables from the computers on a home network system
works like a charm over any distance on the same power circuit for the house
may be a wireless dongle will fix your problem
Apr 11, 2017 | Motorola Computers & Internet
How do I get Symbol / Motorola MC9090 wireless settings to be
This is an old post but I'll give my solution anyway!
I anticipate that you're not exporting the connections:
Open the Wireless Menu icon on the task bar (Close "Manage Profiles" if it is open, select "options".
Select from the drop down "Regulatory" and select your country of operation (e.g USA), de-select "Enable 802.11 d", click Save.
Select from the drop down "Export", click "Export Options", click OK top right, click "Export All Profiles", click OK top right.
Now if a cold boot is performed the device will retain the added network profiles.
Cheers!
Apr 27, 2012 | Zebra Symbol Technologies Mc9090 Moble...
I own a regular MacBook and it's about a year and a half old. I recently moved into a new apartment and established a new wireless network through Comcast. They gave us a modem/router combo for our...
Hello Jodu,
Please check the internet settings of the Lan connection in the Mac Book. May be there is IP Address or DNS settings is installed in your Mac Book which are stopping the wireless network services. Please check the IPV4 settings in the Lan or wireless connection properties.
Jun 03, 2011 | Apple MacBook Mac Notebook
Having problems connecting my lap top to my wireless cable modem. Its a motorola SBG900 gateway. everything seems to be connected. Im able to use it with a ethernet cable just need help geting it to be...
Ok. As per your statement your laptop is working perfectly , when you are connected your laptop with with the cable wire.So the network cable is OK. So you have to configured the wireless cable in your laptop when it is connected to your laptop. After connecting the cable wire to your laptop you have to findout the gate way of your ISP ( Internet Service Provider). To find out the gate way , kindly follow the following instructions.
First findout the IP address , subnet mask,and Gateway addresses of your ISP ( InternetService Provider ).To find out the above mentionedaddresses first open the control panel -> network connections -> local area connction -> properties -> Internet Protocol Version 4(TCP/IPV4) OR Internet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses. Kindly note the Gate way address of your ISP. Then enter the gateway address in the browser and open the window. Then a control panel / a window will appear. It will prompt you to enter 1). user name, and 2) password. If you are having the user name and passwords provided by your ISP , kindly enter them in the window and click to open. Then the particulars of Motorola SURFboard SBG900 Wireless Router will be displayed in the window. Then click the wireless icon and click to enable. Hurray ! your laptop will work perfectly through wireless. If you are not aware of about the 1). User name and 2). password , you must approached to your ISP and try obtain the same for working of your laptop wirelessly.
Oct 03, 2010 | Arris SURFboard SBG900 Wireless Router...
Problem in connecting wireless internet
Some general guidelines to connecting to a wireless network..
Make sure you have at least 3 bars of signal
Make sure you know the password ( if there is one)
Try to connect to the network via ethernet cable to verify the wireless router is actually working..
Oct 28, 2009 | IBM Lenovo ThinkPad X61 Notebook
Symbol MC9090 unable to connect to wireless network...
check in your router MAC security
if in your router MAC security is enabled then only those can connect whose MAC addresses are in allow list in router.
you can access your router with following link
http://192.168.1.1
or
http://192.168.1.0
for belkin router
http://192.168.2.1
type user name as "admin" and password as "admin" or blank or "password
then go to wireless advanced security then check MAC security if enabled then add your moto MAC in allow list.
Let me know .
Jul 29, 2009 | Symbol Motorola MC9090 Mobile Computer
Symbol MC9090 Barcode Scanner Logo
786 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
