Question about Philips Magnavox 51MP392H Rear Projection Television
Hey Guys, If anyone has any suggestions please let me know. I am attempting to remove the rear cover of my phillips projection TV Modle number 60PP9202. the TV is brighter white in high color "white" areas of the screen. Around white shirt's cars etc. I have adjusted every setting and it has not fixed it. I am attempting to clean it out i see dust in it from a crack in the side. can i wipe the lens with rags or what? Any help is apperciated.
  • Philips Master
  • 3,459 Answers
Your CRT fluid needs to be replaced. Call in a pro of goto www.TvRepairKits.com for a DIY kit.
Posted on May 16, 2009
I have a Phillips rear projection tv model number 60PP9202/17F.....it 60
What is the problem of your
Phillips rear projection tv model number 60PP9202/17F?
Jan 10, 2012 | Philips 60PP9202 60" Rear Projection...
TV Powers on and then shuts down and attempts to start again
Remove all connections from the tv other than rf cable. This is an hdmi lockup problem sometimes related to component video inputs depending on firmware version.
Jun 21, 2009 | Samsung HCM4216W 42" Rear Projection...
Convergence IC`S
Let me know do you have related service manual of Sony KP-57WS500 to guide you further?
Without service manual it would be difficult for you to understand our directions like what to check and where to go in TV etc.
Sep 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Convergence IC
Andrews Electronics www.andrewselectronics.com have an ETA of 9-6-8 on the part or you can contact www.wehaveparts.com I would either replace both IC`s or get a tech to do it, you can get them by calling this number 800-575-9833, they only sell the good ones,
Aug 19, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips Magnavox 9P6031C103
You can try ebay, they may have them for auction. or you can try the vendor (philips).
I hope this helps
Shuttle83
Jul 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Need the correct convergence IC number for my Phillips Phillips Magnavox rear projection tv P6034C. I am getting the double picture syndrome . It also appears as if I cannot adjust the red convergence...
Thats not the full model number should be something like 43P6034C or etc. Please respond to this same post and I will let you know the correct Ics and resistors because phillips / magnavox will always burn at least 2 often 4 of the convergence resistors as well.
Jun 26, 2008 | Televison & Video
Power Problem (Phillips 55P8341 Projection TV)
Same problem... I pulled out the second electronic board going from right to left and see a burned diode at position 3307. I wanted to know if anyone has a schematic of this TV and could tell me the numeric value of the part in position 3307. It would be appreciated it you could let me know.Thanks...
May 30, 2008 | Philips 55P8341 55" Rear Projection...
How to remove back of Samsung HCL4715W 47 in rear projection TV
the screws are identified by little arrows pointing to the screw holes. However I would be surprised if its the convergence board most times its the Convergence ICs located on the sub board
Apr 22, 2008 | Samsung HCL4715W 47" Rear Projection...
Where can i buy remote control for phillips 55pp9401?
get a full universal at your local walmart for less then 20 with full menu and program functions, get a phillips brand and no programming required.
Mar 16, 2008 | Philips 55PP9401 55" Rear Projection...
Horizontal green lines the whole length and width of the screen
Hey, I had the same problem with blue and red lines and this post helped me bigtime ! Just adjust the color your having problems with. Best Solutionposted on Sep 12, 2006By maddogmic Rank: Not rated Rating: 100%, 1 votes I had the same problem with my sony KP-57ws500 rear projection tv. To solve this problem all you need is a flat and phillips screwdriver. Right below your speakers on the right and left side are tabs. Pull out the tabs and remove the screw on eachside. Once that is done remove the speaker cover and you will see a fiber board cover in the middle of the tv, there will most likley be twist ties holding some wires, to make it easier to work remove the ties. Now remove the screws on the fiber board and pull it off. You should see 3 adjustments on the top for focus, do not touch those. Below the focus adjustments on the
Aug 27, 2006 | Sony KP-57WS500 57" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
