Question about GPX MW3836 MP3 Player
Firmware update for chinese mp4 player
I have a chinese mp4 player, 8gb, and i want to update the firmware. i cannot find what firmware to use. there is no name brand or anything to identify the player i have. this has been frustrating. please help
  • j1m4l May 20, 2009
    same problem dude on the menu serttings option theres a option which lets you update firmware it says insert usb i did that nothing happens and i heard that the upgraded firmware gives you the option to change skins and has better features, dont know if its true or not so can someone prove me wrong or is that all ********.
How do I update the firmware for this player
Todd, first you give us enough information then we try to help!
what is it, make model #, etc and your complete question.
links below may help RE POST IF NOT HELPFUL
press the helpful button
How to Upgrade the Firmware on MP3 Player
Flash Drive Repair how to upgrade mp3 mp4 player firmware
http://www.moviecodec.com/mp3-players/installing-firmware-to-mp4-player-11573
How to Update the firmware for your MP3 MP4 player
Feb 07, 2016 | Audio Players & Recorders
My 8g mp4 player wont turn on !!!!!!!!!!!!!!!!!!!!!!!!!!
Hi all. to be very frank i should tell you some points
1. never buy an MP4 player( the format is not even MP4 in the player)
if you did
2. never format it,(ever)......(as long as possible)
3. if you get less space, there is a problem with the chip, which can only be solved by the Chinese who made it.
4. as long as possible never try to upgrade firmware, (the tool they gives is almost useless)
5. if up gradation is required check ur board number,(by unscrewing the player)
6. check s1mp3.org for the firmware
7. and please check the board number
these are the words of wisdom from a victim like you all, from the Chinese attack of mp4 player
one more thing
8. ask ur friend to buy an ipod, instead of going for cheap stuff
guys the memory problem is almost unsolvable.....i guess all gets the message ....take care
Feb 24, 2011 | Audio Players & Recorders
New MP4 Digitrl player is showing text in chinese need english
there should be an optioon for changing text in the menu but im assuming that you cant read it ... so lets try this method goto the manufaturers website and download the software and the latest firmware and try reflashing the mp3 players software with any luck the default will be english
Sep 29, 2009 | Audio Players & Recorders
Mp4 player freeze
if you can still see and detect it with your pc there may be a newer firmware update to fix this issue try and find the firmware and flashing utility from the manufacturer and see if that helps
Sep 24, 2009 | Digital Mind Corporation iQ Sound...
Sofware
type firmware of mp4 on www.google.com
Mar 24, 2009 | Computers & Internet
My PMP MP4 player's LCD screen is not working.
hi,
i dont think you can solve this very easily. try to do a firmware update of the player.
if the firmware update is no there then there is very little chance to clear this problem.
thanks you
Feb 08, 2009 | Audio Players & Recorders
Wrong firmware added in mp4 player.....
You'll need to open up your player to find the plate and board ID numbers to be able to find a compatible firmware for your player. Take a look at this post here: http://mympx.org/forum/knowledge-base-faq/41330-how-recover-dead-mp3-mp4-player.html. This will tell you how to recover your dead player using your firmware.
Hope that helps.
Nov 10, 2008 | iLO (2 GB) MP3 Player
Mp4 nano 4gb keeps turning off
What I would recommend you to do is fo format your device and then update the firmware on the device..This problem will happen if you have some digital rights management problems on your device...Formatting the device and update the firmware is the only solution to your problem...
Thank You
Computerrep
**Please rate accordingly...
Jan 30, 2008 | Apple iPod nano
Generic 8GB Flash Mp3 player
try a firmware update.....sound to me like a firmware fault???
Sep 13, 2007 | Samsung YH-925 MP3 Player
GPX MW3836 MP3 Player Logo
466 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
