Question about Furuno NavNet vx2 1920C GPS Receiver
Upload waypoints via laptop
I don't know how to hook my laptop to the unit to upload and download waypoints. I have connected a serial port for my laptop to plug in, but don't know how to set the nmea connection data in the pc and/or whether software is needed and what kind? I have Maptech software. The brochure says you hook a computer to any Navnet display and upload/download waypoints. Does this mean I can plug in the ethernet? Any help would be appreciated. Thanks, HTF
We have furuno GP 37, We need to know how we can rom NMEA output from the device, at he same time we need to know , if we are getting NMEA out put from NAVMEN fish 4430 , will we be able to combine theses both output data as per time. ie: if a is a lat,& bis long, & c is the deapth for the same point, as the deapth c is coming fro another point will we be able to process that in thses equipment?
Posted on Jul 23, 2009
Quite honestly, this is not worth the trouble. It easier to re-enter the waypoints manually. If you want to try it, you need to get some GPS connection software from someone like: http://www.gpsu.co.uk/. You cannot do it with your PC and cable alone. Good luck.
Posted on Jul 15, 2009
How do i hook up my linksys wireless-g broadband router wrt54g-someone disconnected it
Disconnect the power to each unit (except computer, shut it down). After you connect the modem,router and computer, power up the modem,then the router,then the computer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Hook it up per this diagram:
May 20, 2011 | Computers & Internet
Enter waypoints via computer keyboard
Install Mapsource from Garmin on your computer. It will allow you to enter your points then upload via serial or USB.
Jun 15, 2010 | Garmin Gpsmap 76csx Handheld Gps
How to interface a furuno 1833c navnet to a usb port and how to download waypoints to my pc.I have the older 9 pin pc cable and a usb adapter cable.Looking for usb drivers and software to make it work.
The display uses a serial interface, otherwise known as a comm port. You can get a USB to DB9 adaptor practically anywhere. Once you have a serial connection, you will need software such as MaxSea to send the waypoint with.
Jan 11, 2010 | Furuno 1833C/NT GPS Receiver
Cannot install java on samsung i640
Im very sorry Dude
  • It is NOT officially possible to install java MIDlets on samsung handsets (excluding smartphones) via bluetooth, IrDa, USB cable or serial cable. MIDlets can only be downloaded by Over-The-Air (OTA) via a download server
  • There is currently no method for installing MIDlets on other platforms other than by OTA/GPRS via a download server.
BUT THERE ARE SOME UNOFFICIAL METHOD PLEASE TRY THIS BUT RISK IS WITH U.
Install JAVA games on your Samsung via a USB cable, BT or even an IR port
The method here is rather straightforward. It has been tested on my two D500 phones without a single problem biggrin.gif
1. Download and install Softick PPP from here. The software is designed for Palm users, so if you receive any error messages such as unable to locate USBPORT.dll, just ignore them.
2. Active your IR connection or hook your USB cable into the phone.
For IR users, you need to active the IR connection on both of your laptop and D500, and approach the laptop with your D500 to let it find the phone prior to any transferring.
For USB connection, the one I tested is from fonefunshop
3. Start Softick PPP, and check if it has your connection in its 'Settings->Bluetooth/Serial'. Active it if done.
4. Run 'Uploader.exe' program and add a jad file.
5. Enable Serial Java download - #*536963#.
6. Enter Serial Java menu #*5737425#, and choose USB from "1 PPP UP'. Please bear in mind, just do it once for each switch on/off!
Select second option - "2.Serial Download"
7. Let upload and softick PPP access the net if you installed a firewall.
-More details--------------------------------------------------------
If you are using a USB cable, please take the following steps:
1. deactive Softick PPP, and exit it.
2. connect the cable,
3. run Samsung's PIM & File Manager to make sure that you get connected. If not, please switch off and on your mobile and try it again.
4. run Softick PPP
5. go to it's 'Settings->Bluetooth/Serial' to check if it has a connection such as COM7 Devicess_mdm0. If so, select it, otherwise exit the Softick PPP and go back to the first step. (you may find the proper COM setting from the windows device manager->modems->Samsung Mobile USB modem)
6. active Softick PPP.
7. run Uploader.exe
8. ......
For IR users,
2. active your IR connection。
3. approach your phone to the laptop, and make sure there displays an icon in your tray area and it gives a message 'there is a device around....'
4. run Samsung's PIM & File Manager to make sure that you get connected via IR. If not, please switch off and on your mobile and try it again.
5. run Softick PPP.
6. enable IRDA interface support in 'Settings->Options'
7. go to it's 'Settings->Bluetooth/Serial' to check if it includes a connection such as 'COM4 Device
Jun 26, 2009 | Samsung SGH-i640 Cellular Phone
My Garmin Foretrex has a serial port. What software is available to download tracks and history to a PC
You can download tracks and waypoints via EasyGPS for free, or ExpertGPS or Garmin Mapsource. These programmes will transfer waypoints, tracks and routes to your PC.
If this solves your situation, please come back and rate our solution. Thankyou.
Jan 08, 2009 | Garmin eTrex Legend Cx GPS Receiver
GPSmap 176 not communicating with laptop via serial/USB adaptor
sounds you do not have appropriate usb driver so find download and install usb driver from following website:
http://www.usb-drivers.com/
chose your compute product to make sure about USB driver.
Nov 11, 2008 | Televison & Video
Gps
Hi fire1961,
Downloading data from my FURUNO GP-30 gave me no problems. But it took me long time to figure out why I coudn't upload waypoints and routes to the GP-30 via the serial port in my ThinkPad T30.
I tried nearly everything tested the cable, tested a lot of different software and even wrote a little c-program to communicate with the serial port. I also tried a serial-to-usb converter with no results. Then I stumbled over this RS232 Tutorial. According to this - serial ports are not just serial port but can be divided into three general categories:
The types of driver ICs used in serial ports can be divided into three general categories:
* Drivers which require plus (+) and minus (-) voltage power supplies such as the 1488 series of interface integrated circuits. (Most desktop and tower PCs use this type of driver.)
* Low power drivers which require one +5 volt power supply. This type of driver has an internal charge pump for voltage conversion. (Many industrial microprocessor controls use this type of driver.)
* Low voltage (3.3 v) and low power drivers which meet the EIA-562 Standard. (Used on notebooks and laptops.)
Then I installed the waypoint upload software to my ten years old Compaq Presario and suddenly I could upload routes and waypoints but only via the on board serial port. The serial-to-usb converter didn't still work.
So if people experience no result trying to upload data to these old GP-30's from their notebooks and laptops. Then I think it could be a matter of these Low voltage ports not are able to provide the FURUNO device with enough voltage. See the above RS232 Tutorial.
Best Regards
Lars Erting
Aug 03, 2008 | Furuno GP31 GPS Receiver
Garmin GPS III Pilot to PC communication problem
If it were doing this just on the Vista machine I would say it was Vista related but since you are getting it from an xp machine as well the problem is either cable or the gps unit. You don;t say if this just started happening or ? If you can try out the cable on something else to make sure so you can eliminate it. About the only thing you can do is to make sure the port settings in the pilot are set correctly. Generally the slower the better if you are having communication problems as this makes the signal timing not as critical. Try 9600 baud to start. Make sure that the data bits are also set roght. This is the 8n1 or 7n1 thing you see. I can;t think of what the default is on the garmin but as long as both pc and garmin have speed, bits, parity, and stop but set the same they should talk.
Try to download from the unit as well as upload.Unfortunetly you can only change the speed and protocal or reset the unit. You won't be able to fix it if is a hardware thing. If you are using a USB to Serial adapter then I would say that is your problem or could be. Cheaper ones just don't work often on higher port speeds. You might want to try the gps on a pc with a actual serial port if you are using one. If it works then you should try a different brand of adapter or really slow down the speeds.
This won;t solve it unless you luck out but it should let you know where the problem is.
Dave
Jul 10, 2008 | Garmin GPS III
I've got a garmin E-Trex Vista CX and Mapsource software. After creating routes & waypoints (for Ben Nevis, Scafell Pike & Mount Snowdon) when I download these to the GPS unit each subsequent...
The contours are not coming from the routes and waypoints, they are coming from the mapping software. You must load all the map segments at once to your unit. You can upload routes and waypoints separately and they will not erase the other ones already on the GPSr unit.
Apr 21, 2008 | GPS
Furuno NavNet  vx2 1920C GPS Receiver Logo
201 people viewed this question
Top Furuno GPS Experts
Ron Dufek
Ron Dufek
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
