Question about Belkin OmniView CAT5 KVM Extender F1D084
The signal at the receiver of VGA extender drops out.
A new set of VGA extenders working over 60 metres of CAT6 UTP, run in conduit along with 9x RG59 coaxs. The video from cameras in the RG59s is fine. The CAT6 conductors send end socket to receiver end socket all check OK with a tester.
The VGA works fine for 5-20 minutes (the time varies), then the active light on the receiver goes out and the VGA picture is gone. Unplug the RJ45 patch chord from the CAT6 wall socket, replug the patch lead and the active light goes on again and the VGA picture reappears.
If the signal lost condition is left untouched the receiver & its power pack gets hot. The supplier has been able to replicate the problem with with two customer returns, with both long and short patch leads between Rx & Tx (but not as consistently as me). It seems from their experiments the patch lead plugs might be the fault. but the manufacturer has yet to agree there is a problem at all.
MEANWHILE...
I read that CAT6 is not so good for VGA extending as CAT5 'cos of the higher twist differential between pairs in CAT6. Would that only apply to passive extenders and not active ones? Could that be the problem even with the active one struggling to equalize the signals arriving at too wide a delay spacing and giving up...or is just more likely that the transmit strength is too low? (There's no sign of any skew in the VGA picture).
2 Suggested Answers
SOURCE: Hi, I recently bought a XTENDEX®
Well see Cat5 & Cat6 are different spec's and are wired differently...They have different wires inside the cable. You would be able to use the actual Wires, BUT they will have to be wired to the "Other" standard in the Outlet Jacks. Either that or get one that works on Cat6. http://www.connectworld.net/syscon/support.htm
Posted on Mar 04, 2010
Connect KARPRWL11NA
First off, have you connected your pc/laptop to the SSID called WiFi repeater? If not, do that first and then try browsing to http://192.168.10.1
Failing that and assuming you have a DHCP service running in your network, you could try checking the leases to see if your range extender has received a dynamic IP address. If it has, try browsing to that IP instead of the default 192.168.10.1.
Another option would be to use the cabled connection (assuming you're not already doing so) by connection your pc/laptop to the range extender using a UTP cable.
Jul 03, 2014 | Zyxel Prestige P-330W Wireless Router...
Some cables not long enough, can they be extended or can longer cables be ordered
yes you can extend the cables, also you can buy cable extenders for video and power cables.
Jan 27, 2014 | SWANN Security Products PRO-530...
AM reception is fine for about 9 seconds and then the signal and audio drop completely. The only way to get signal back is to toggle to fm and back to am, then another 9 seconds of clear audio happens,...
Hello, I am sorry about your issue. Is the FM reception OK. AM signals are difficult to receive at times. Try extending the AM antenna and place it near a window. Thank you, Onkyo USA
Jul 08, 2017 | Onkyo Audio Players & Recorders
I recently installed CAT6 cable to run between my computer and main stereo. The run is 50' so I also purchased a USB extender. My issue is that once I hook the network up to my computer, it can no...
Yes- don't use USB as an extender- Network spec for Cat 6 without a repeater ranges from about 165 feet to 75... You should be able to run the cable straight through.
Jun 15, 2011 | IOGear USB Booster Cable G2LUB16 USB...
I am trying to install dual monitors to my computer. I have no idea how to do it. Can someone provide me with a step by step detailed walkthrough on how to preform this task. Thank you.
If this has 1 or 2 video cards, install the software for them it will go through reboots. To set up the extended monitor via Windows 9X, 2k, XP: R click on the desktop, select properties, select settings, and choose extend on to monitor 1 or 2 via the picture. Scroll through the resolution size. Click Apply to set it or cancel. If this is Vista or Windows 7 it appear different. Right click on Desktop, go to screen resolution, Highlight which monitor to extend, select Multiple displays, Extend these displays, pick resolution and hit apply.
If only 1 video card you will need a Y splitter VGA cable to hook up both VGA cables to the 1 card or 1 card with 2 VGA cable ports. After cables are hooked up go through same setup process above.
Mar 18, 2011 | Computers & Internet
2 routers. Can i have two routers within the same workgroup. My wireless router will not work from one end of the house to the other. I need to have more than one wireless transmitter so my laptop will...
Yes you can have the setup in your workgroup in multiple ways.
Solution1:-
The logic will be making your new wireless router to act as a wireless booster which will receive the signal from your old wireless Router and then retransmits the signal.But this needs some extra configuration on your new wireless router
1. You have to select the WDS ( wireless Distribution System) mode in the new wireless router.
2. Set the same SSID on the new wireless router.
3. In the new wireless router config page , search for the wireless signals and select your old router from that list.
The WDS mode tells the new wireless router to send/receive the wireless signal to the old wireless router.
Solution 2:-
Connect your old wireless router LAN interface to a network switch through a CAT5e UTP cable and the new wireless router to another port of the switch (use a cable which can be extended to the other room where you want the new wireless router to be placed).
Configure the same SSID you have set in the old wireless router.
Best Regards
Nov 15, 2010 | Computers & Internet
Hi, I recently bought a XTENDEX® ST-C5USBV-300 USB KVM (Cat 5/5a/6) extender KWM switch. When I connect it to a HP DC 5800 SFF desktop I can´t get any video signal when it´s connected via a...
Mar 04, 2010 | Belkin OmniView CAT5 KVM Extender F1D084
My Internet radio operates off the Belkin router if the two devices are in the same room. The internet radio does not work if it is in adjoining room approximately 15 metres away. This is a new problem.
  • internet radio may require more signal strength, that is why the farther you are the weaker the signal, you may need an access point to extend the signal strength
Aug 03, 2009 | Belkin (F5D7230-4) Router (587009)
HP Procurve 1700-8 working upto 10m UTP cable only.
It is not a distance limitation of the switch, rather the cabling in the walls and ceiling. If the cable is Cat5 it can be up to 100M, but this can be drastically reduced with things like EM interference from fluorescent lights, kinks in cable and more. The switch auto detects the maximum reliable speed and this interference would cause it to drop to 10MBps. If you don't have a cable certifier (very expensive) you may want to consider simply replacing the cabling run with Cat6 following best installation practices. You can learn more at http://www.lanshack.com/cat5e-tutorial.aspx.
Feb 14, 2009 | HP ProCurve 1700-8
Belkin OmniView CAT5 KVM Extender F1D084 Logo
140 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
