Question about Dell 922 All-In-One InkJet Printer
Very fine horizontal black lines superimposed over text printing.
Printing of colors seems normal. This seems to be confined to the black cartridge.
  • 26 Answers
Print at a higher resolution. Clean the print heads, check the print alignment.
Posted on May 15, 2009
I have a brother all in one MFC 685 CW &having problems printing
Not sure where you found the recommendation to use Windex on your print heads but chemicals should be avoided. It sounds like you have damaged so of the head elements and now they are leaking. There are specialized fluids for cleaning print heads or plain old water will dissolve ink as well. Too late for you however if the heads have been damaged they will need to be replaced.
Oct 06, 2016 | Brother MFC-685cw InkJet Printer
Canon Printer - Pixma 5000 Trying to print out pages of text. The text is coming out with a line printing normally - then a block of text / lines missing completely - then tops of line or bottom of line...
pull out the black cartridge then get a tissue paper try pressing the nozzle again the tissue paper but not so hard then release look for the straight line that appear on the tissue paper if it is not change it
Aug 07, 2011 | Canon Office Equipment & Supplies
My Brother HL1230 printer prints with whole lines of text missing several times on a page and gets worse by missing more lines if printing several pages. It has a new toner cartridge. How can I sort this...
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 28, 2010 | Brother HL 1230 Laser Printer
Lexmark z705 printing blank envelopes soft ware ok
The problem that you are experiencing is caused by the way the text is formatted in most word processing documents. By default envelopes are printed not in black, but a dark gray. This confuses the printer and causes it to use the color cartridge to process gray instead of using the black cartridge.
You can fix this problem with one of two ways:
1. Click on "Start", "Control Panel" and click on "Printers and Faxes." Right click on the "Lexmark Printer" icon and select "Properties." Click on "Printing Preferences." Go to "Quality/Copies" tab and select the option "Print color images in black and white."
2. You can also change the color of you text to a true black in your word processor. This will require you to resort to the word processor's documentation and help files.
Both of these settings will cause your printer to use the black cartridge instead of the color. If either one of these solutions solves your problem, it means your color cartridge needs to be cleaned or replaced. If you feel that the color cartridge should not be out of ink, please follow the steps given below:
Clean Nozzle Procedure:
1. Go to the "Solution Center" and click on the "Maintenance" tab.
2. Select "Clean to fix horizontal strips."
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzles" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
“Wicking” Procedure:
1. Select "Install color/black cartridge" and remove the cartridge from the printer.
2. Get a damp paper towel.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
5. Next dab the cartridge on the towel to make sure that the ink is flowing.
6. Snap the cartridge back into the printer.
7. On your computer, select "Old Cartridge installed."
8. Repeat the "Clean to fix horizontal strips" procedure listed above.
If this procedure does not help, please let us know so that we can continue with technical support.
Oct 01, 2009 | Lexmark Z705 Inkjet Printer
Canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Mar 18, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Printer prints in color but has gaps
Have you tried a new colour cartridge? This is a classic sign that the cartridge may be low on ink. When printing text, assuming you are printing black, it is likely that the black cart is doing most of the work so the gaps are insignificant. You could try printing text in several different colours. If the colour cartridge is low, you'll find that some colours may be ok but others may have gaps.
Best to try a new cart if you have one.
Dec 11, 2007 | HP Deskjet D2360 InkJet Printer
Color Printing Produces Pink Horizontal Lines
Hello we have had customers with this problem and this model printer We came upon this type of problem also exhibited the same lining when you did a nozzle check independant of the computer (not attached to computer and just using the internal head check print) This was a cartridge problem and after replacing the cartridge the problem stopped.
Apr 21, 2007 | Dell 962 Photo All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
