Question about Maytag Washing Machines
Excess water in clothes at end of spin cycle
My Maytag PAV 2300 AWW appears to spin at correct speed, but my clothes are still excessively wet at end of cycle.
  • 47 Answers
SOUNDS LIKE THE MOTOR COUPLING TO ME.
Posted on May 16, 2009
I have a Maytag Performa PAV 2300 Washing Machine. Recently, clothes are still wet after spinning in the delicate cycle. This is not an issue in the Regular cycle. For now, I'm re-spinning the delicates in...
The belt is real easy to replace. Tip the washer back and yank the old belt off.
Loop the new one over the 2 small pulleys and then ease the belt over the large pulley.themobilian_2154.jpg
Important info a manual and more here
Apr 06, 2011 | Washing Machines
Spin cycle is not getting clothes completely dry, can still hand ring water from clothing
When the clothes are wet at the end of a cycle, check these: Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Aug 01, 2010 | Maytag Washing Machines
It spins but doesn't dry the cloth ,water stays in it
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 02, 2010 | Maytag Washing Machines
Maytag Performa Model# PAV 2300 AWW agitator & larger wash load
pull the agit out and look at the side just below the slots there is a small hole there and the lock screw is probably missing . / to pull agit you turn the screw out and to lock it down you turn it in till it stops . if no lock screw the out comes the agit ... could be very bad in spin if it came out . i have heard of this .. so lock it down .. **** hope this helps .
Dec 07, 2009 | Dryers
Machine won't rinse or spin properly..also stinks!
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
May 08, 2009 | Maytag HAV2557 Top Load Washer
Only spins slow
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
May 06, 2009 | Washing Machines
Wet clothes after spin cycle
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
May 05, 2009 | Maytag Atlantis MAV6000 Top Load Washer
What will the Max Extract button do?
The max extract button will do an extra spin to get any & excess water out of the clothes. It is a good thing to keep on to help cut down on drying time. If you find standing water in the washer, it is possible the hose is NOT in the correct position.
May 03, 2009 | Maytag Neptune MAH6500A Front Load Washer
Spin cycle leaves clothes very wet
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Feb 09, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Maytag PAV2300 AWW nevre agitates and only spins once.
Ive never seen a Maytag washer, but I think know the principle. So! I think the motor turns in one direction to wash & the opposite direction to spin. Now, if the transmission is very stiff in the 'wash mode', that could be why its not washing. The motor could be overheating & the thermal trip in the motor cutting off the electricity supply hence having to wait 45 mins for it to cool.
Not too sure! However I think I am on the right track. Let me know please
Oct 26, 2007 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
171 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
