Question about Panasonic Televison & Video
U61 error; Self-check failed; unable to use machine.
I have a Panasonic DMR-ES36V. I am now getting a U61 message and then a message saying "self-check" failed. How can I fix this problem ?
hawk12online
  • 16 Answers
SOURCE: NEED UNLOCK CODE FOR PANASONIC DVD RECORDER DMR-ES36V
I beleive FixYa Terms of Service state that you cannot give out Unlock codes for any type of device, hardware or software.
Posted on Dec 30, 2008
  • 55 Answers
SOURCE: PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
Posted on Apr 22, 2009
  • 188 Answers
SOURCE: Panasonic DMR-EZ47VEB stuck on self check
Check IC in primairy power supply
Posted on Aug 29, 2009
  • 309 Answers
SOURCE: Panasonic DMR-ES15 DVD recorder startup failure
The unit failed during self check, probably the power regulation board. A check by a qualified TV/VCR repair person is in order.
Posted on Nov 20, 2009
Demonic-2011
  • 467 Answers
SOURCE: I have a Panasonic DMR-EZ47VEB
U61 is a common fault in the Panasonic DVD recorders. It is generally a failure of the DVD-RAM drive and/or the digital controller board (in some cases it is both and both must be replaced together as a module). Unfortunately these are not repairable at individual component level; they would most likely need to be replaced and fitted by a qualified technician in an authorised Panasonic service centre. The only trouble here is the potential cost(s) involved (such as labour, the DVD drive, etc) - could be expensive and/or uneconomical. However, you can always submit your unit to a repair shop for a quote and a second opinion (on the costs of the replacement part(s) as well as estimated labour charges and the extent of the problem - this allows you to make an informed decision afterwards to get this fixed, but it is up to you.
The cost of a new DVD-RAM drive (if that is the actual problem, and not the board it is connected to) is quite high; anywhere between $130 US (for XVY1961 to suit DMR-ES35V/DMR-EZ47V models) up to $450 AU for the same device plus labour costs should you choose to have it replaced.
I assume you like your unit and want it working properly. If you do decide to deal with an authorised Panasonic service centre, ensure that when the work is completed they provide a detailed report, and some sort of warranty on that repair, especially if it involved replacing the DVD drive. Unless you have an extended manufacturer's warranty on this; which means it won't cost you anything to have it assessed and repaired fully.
Posted on Apr 22, 2011
I have a Panasonic DMR-EZ47VEB and after recording overnight next morning dicovered the machine had swiched off with the word"Hello" on the front display. When switched on the unit displayed the...
Apr 21, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Paqnasonic DVD recorder Model DMR-EZ45VEBS is stuck with error code U61, and now will not play any disk. Every time I insert a disk it comes up with the error code, Problem started whnI was recording a TV...
try cleaning the OPTICAL LENS directly with a Qtip , gently rub , try again , the code U61 means a self test procedure that the unit is running according to PANASONIC tech people, good luck , AJ
Nov 30, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Nov 20, 2009 | Panasonic DMR-E55 DVD Recorder
Aug 29, 2009 | Televison & Video
U61 Code will not reset - any suggestions?
You have the same issue as the one who is posted here at Fixya. But this requires you to open the DVD cover. If the unit is still under warranty, its best to bring it to the authorized service center. If not, you can try and test this if it'll work.
http://www.fixya.com/support/t221217-u61_error_code
"I have the same problem (same error # same model of DVR).
I noticed it happened after I left a DVD in play mode and paused for a long time.
I saw a message on the Internet that error U61 can mean that the lens is unable to move (return to its normal position).
The Internet message said that person unpluged everything, then opened the cover to the DMR-ES15 (3 screws) and gently pushed the DVD head back towards the rear of the DMR-ES15.
I assume that would void his warranty, but I am considering trying it since the time to have it repaired versus the replacement cost makes the possibility of a "self-repair" attractive.
Here is part of that actual Internet message. I hope it helps you:
Yesterday, my DMR-ES15 started to malfunction, giving me the error U61.
No matter how many times I tried to press Enter, and Power On, the machine
kept re-booting with the error U61. I noticed that the drive was making some noises as if the Read head was not able to park properly.
So I decided to open up the unit and find out why.
I took out the 3 screws holding the top in place. And then moved
the drive head mechanism back (pushed it towards the back of the unit).
I then plugged the power in, turned it on, and amazingly there was no more U61 error.
I test the unit this morning again and everything seems to work properly again!"
Aug 17, 2009 | Panasonic DMRES15 DVD Recorder
From User guide:
Feb 26, 2009 | Panasonic DMRES15 DVD Recorder
Panasonic DVD/VCR message U61
Dear stds ~ My DVD Recorder Keeps Opening & Closeing The Tray A Gives An Error Message Saying ~ Repair Has Failed ~
DVD Recorder ~ DMR ES46V Panasonic ~
Error Message ~ U61 !
If Possible To Resolve ~
Please Do !
Before I Buy A New One !
Please Respond ASAP To ~ glvw@nyc.rr.com
Thanks !
May 22, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
U61 error code
UMM the DVD top lid uses FOUR screws. The entire DVD drive is bolted to the chassis with 3 screws.
Oct 14, 2007 | Televison & Video
Model No'DMR-ES15 - U61problem
I get this message occasionally on my Panasonic DMR-ES15. It's actually a really simple fix. It occurs when there is a corruption in the disc which causes the recording mechanism to malfunction. There is a separate error message for this, however it is usually not detected until it's too late. When the recorder asks you to carry out the recovery process, do it. When the disc ejects, make sure you take the disc out that was in there when it occured and throw it away...it will keep happening because the disc is permanently corrupted. However, do not close the tray without a disc or the self-check will fail. Instead pop in a disc of the same format that the error occured in (if it was DVD+RW then put in a DVD+RW). It resolves the problem every time on the first try. (It only happened two times in a year and a half for me). As the manual says the unit is "NOT BROKEN".
May 23, 2007 | Panasonic DMR-ES10 DVD Recorder
Televison & Video Logo
125 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
