Question about Estate TEDS740JQ Electric Dryer
Drum will not turn
I have an Estate electric dryer, Model TEDS680EQ2 and the drum will not turn. The dryer turns on, heats up. Took the cover off and I can turn the drum by hand and the belt is not broken.
  • Victor
    Victor May 11, 2010
    Can you see if the belt is on both of the pulleys properly?
  • 47 Answers
YOUR BELT ON YOUR DRYER IS BROKEN. THAT IS WHY YOUR DRUM WON'T SPIN. YOU CAN BUY A NEW BELT FOR YOUR DRYER AT ANY PLACE THAT SELLS APPLIANCES.
RODNEY
Posted on May 16, 2009
My dryer has heat but does not dry
is the drum turning? if not you must replace the strap that turns the drum. if it is heating and the drum is not turning , that could cause a fire.
Sep 30, 2014 | Estate by Whirlpool EED4100XQ Estate...
TEDS680EQ2 estate dryer. I need directions on how to change a 4 prong plug to a 3 prong
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 25, 2010 | Estate TEDX640JQ Electric Dryer
I have and electric estate dryer. The drum is turning but the clothes are't getting dried in the automatic cycle or timed cycle
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 14, 2010 | Estate TGDS840JQ Gas Dryer
Dryer runs and drum turns, but will not create any heat at all.
Sounds like a bad heating element. Go to www.appliancepartspros.com put in your brand and model number. this will pull up a list of all your dryer parts and the schematics of where all parts are. You can also buy parts from them. Great prices, quick service.
May 07, 2010 | Estate TEDS840JQ Electric Dryer
The drum is turning but there is no heat it is an estate dryer yb whirlpool
Review the items in:
http://www.fixya.com/support/t2312372-no_heat_starts_but_igniter_doesnt_light
If electric dryer check thermostat and heating element. Heating element probably needs to be replaced.
Jul 09, 2009 | Dryers
Whirlpool estate teds680eq2 dryer will not heat up and don't have an ohm meter to test with.
Hi, One way to check the lement is to remove it from the housing and see if it has a break in the coil. UNPLUG the dryer. Remove the rear panel and the element is located on the right side. There are two screws holding the element in.
If the element has no breaks in it, you will need to test the fuse and thermostats. The only way to test them with no meter is to tape the wires together and plug the dryer in and see if it heats when you turn it on. PLEASE be careful.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 05, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
Wirlpool Estate Electric Dryer TEDS680EQ2 Drum Won't Turn
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
Once you access the site you will be able to navigate numerous pages of information on your dryer. You will need to enter your model number to access your dryer information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 05, 2008 | Dryers
Estate Dryer Model TEDS680EQ1
check the thermostats and see if your belt is still there if not put a new belt in
Mar 25, 2008 | Estate TEDS740JQ Electric Dryer
Estate TEDS740JQ Electric Dryer Logo
221 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
