Question about Dell Dimension 8300 PC Desktop
Will not restart, has been deadlocked in power safe. I pressed any key and moved the mouse. Nothing.
My Dell will not come back on. When I push the plus button on the screen it says locked in power safe mode. Press any key or move mouse. It will not come back on. Thanks Jessica Vandenberg vandenbergjessica@hotmail.com I called Dell, but failed to understand the tech support as he had a heavy accent and I am not able to understand him.
  • JDTec
    JDTec May 11, 2010
    What monitor do you have? If it is a Dell monitor, did you downlaod and install the Dell monitor driver?
  • 433 Answers
Sounds to me that Windows is setting your computers video controller to output a video signal whose timing is not compatible with your display. You may be able to boot Windows in safe mode and then be able to pick a compatible video timing ( refresh rate) in the display settings Windows control panel. Did your monitor come with any kind of setup disk?
If your monitor is a flat panel try the resolution refresh rate at 60MHz. Lower than a CRT.
Hope this does it for you, please leave rating...
Posted on May 15, 2009
Dell deminsion 4700 when i moved it,monitor,mouse,keyboard quit.monitor briefly displays power safe mode.pressing any key don't help
When you moved your pc you probably knocked the graphics card loose. You can open it up and try re-seating it. Make sure you unplug the pc first and then press the on button for 10 seconds to clear out all the power from the power supply before opening the computer up.
Also, If you are using a KVM... Unplug the KVM's power cord for 30 seconds and plug it back in. That will reset it.
May 14, 2012 | Dell Dimension 4700 PC Desktop
My computer is stuck in sleep mode and it says to touch any keys or move the mouse, i did and nothing is happening, i have restarted and same thing. just a blank screen. please heklp
turn off computer and remove power cable
and reconnect power on
by pressing F8 go in to SAFE MODE REMOVE ANY TEMP FILES RESTART MAY FIX UR PROBLEM
Mar 01, 2012 | Dell Inspiron 530s Desktop Computer...
How to unlock the key pad on a dell latitude D600 laptop
Hi. Please do troubleshooting steps below:
1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
2. Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
3. Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
4. Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
Have a good one!
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
  • Read more: How to Unlock a Dell Keyboard | eHow.com http://www.ehow.com/how_5063232_unlock-dell-keyboard.html#ixzz0uguUk4bZ
    Jul 25, 2010 | Dell Latitude D600 Notebook
    When I restart the computer, the keyboard and mouse do not work. The mouse won't move the cursor and hit cntl alt del on keybourd and nothing happens. I have tries three mouses (one wireless) and two...
    Use wired mouse and keyboard (not wireless) and change the USB port you are using to another one.
    Connect them directly to the computer, do not use USB hubs.
    If no joy reboot in safe mode: turn on your computer and immediately press F8 repeatedly until you get the Advanced Boot screen. Select "SAFE MODE" and press ENTER. After that, restart in normal mode.
    Thank you
    TechSaver
    Jan 21, 2010 | Dell Dimension E520 PC Desktop
    No programs, no buttons work, mouse works, starts but thats it
    Restart and keep pressing F8 key. Select safe mode option. IF it will boot into safe mode ok then go to start->all programs->Accessories->system tools->system restore. REstore computer back to previous date.
    If this will not be possible.Restart and keep pressing F8 key and select safe mode with command prompt. In command prompt window type in "chkdsk /r " this will run checkdisk and restore missing files.
    Please leave your feedback if issue was solved
    May 27, 2009 | Dell Inspiron B130 Notebook
    Dell Dimension 5150 Stuck In Pwer Safe Mode
    Sounds like a problem with the video card. Cross check the connections to the CPU. If its all fine, Then Connect the monitor to a diffrenet pc and then use the monitors keys to change it to a plug and play mode.This might help with ur problem
    Feb 01, 2009 | Dell Dimension 2400 PC Desktop
    In power save mode
    The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
    Nov 17, 2008 | Dell E173FP 17" LCD Monitor
    Monitor
    I think your resolution is set too high reduce it in safe mode
    Sep 02, 2008 | Dell E153FP 15" LCD Monitor
    In power save mode
    Try hitting the space bar on the keyboard. Does the mouse work normally?
    Nov 30, 2007 | Dell E173FP 17" LCD Monitor
    Dell Dimension 8300 PC Desktop Logo
    69 people viewed this question
    Alun Cox
