Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
Hitachi 46F500 and there is a blue curved bar
There is a blue curved bar across the top half of the screen, there is also a yellowish line at the bottom of the screen. I have tried magic focus and it did no good
  • Hitachi Master
  • 3,459 Answers
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
7Hitachi 46F500 and there is a blue curved bar - f0900cb.jpg class=
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Posted on May 16, 2009
My 61" Hitachi UltraVision has
hello my name is rico, you have bad convergence problem. you need to replace the stks inside the tv, and look for colder on the boards. you gonna need a gun solder, solder, chawick, 2 stks(look in the tv for the number loooks like stk392-120 o something like it) look for bad fuses. that should fix your problem. if you need more help let me know at 602-810-7149.
Jan 07, 2011 | Hitachi 61SDX01B 61" Rear Projection...
Why my tv have a green curve line on the top on the screnn
You need to replace convergence IC chips to correct this issue
Dec 18, 2010 | Hitachi 46F500 46" Rear Projection...
My Hitachi 46F500 TV will not adjust either manually or in magic focus mode......it has green lines across top of screen and some red tinting in the picture ......is this a gun issue or mirror in need of...
Replacing the lamp will do the job. It is the lamp that is faulty not the gun or the mirror.
It will cost just a few box to get a new lamp.
Take care and good luck
Oct 10, 2010 | Hitachi 46F500 46" Rear Projection...
Blue outline on the top half of the picture on my Hitachi 51F500
your convergence ic is going bad. usually worth the repairl.
Jun 04, 2009 | Hitachi 51F500 51" Rear Projection...
Hitachi TV 43FDX10B has yellow line with blue curve line above it
It sounds like your convergence ic's are messing up
They have a kit for this tv it is available through local parts distributors
If you can't find it locally just Google HITACHI CONVERGENCE KIT
If you are not good with de-soldering and soldering do not attempt this repair. Remember to replace all the resistors in the kit
If you are not sure about doing this repair you should have your local tv guy do it for you
Jan 27, 2009 | Hitachi FDX Series 43FDX10B 43" Rear...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi 46f500 convergence?
a common problem wich i also have with convergence with blue and red convergence.
the image converge amplifiers are burnet out wich in turn blow out resisters that control individual color convergence.
Jun 19, 2008 | Hitachi 46F500 46" Rear Projection...
Hitachi 46f500 screen messed up after welding on same circuit
If you did manual conv. You have to redo it when you replace the bad parts. Them being conv. ic's replace them and check 1/4 watt resistors that are low value right beneath amps. Careful not to solder any foil pads together or you will have major problems. Very common for do-it-yourselfers. Good luck, Russmann.
Jun 15, 2008 | Hitachi 46F500 46" Rear Projection...
Has a wave in the picture half way across top of screen
You most likely have a convergence chip bad. In our shop, when we are working on projection TVs, we find that about 80% of the repairs we make are the same problem you are having. You need to replace the convergence chip ( there are 2 of the same chips on the convergence board, and I suggest you replace both ). If you are going to attempt the repair yourself you'll need to remember to use lots of heat sink grease so you don't have the same problem again. Also, try to get original parts, as there are times that the after-market ones don't work well. As a precaution, always remember to unplug the set from the wall before you do any work on the set. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 03, 2008 | Hitachi 46F500 46" Rear Projection...
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
540 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
