Horizantal out put transistor burn after 1 to 2 hours
This model is jvc AV-2131EE , i found the origonal one is removed by another person so i do'nt know the real number , i tried to fix that by putting BU508D , and others but it become hot and burn after 1 to 2 howes , PLS, help me , the transistor i used is good quality thanks alot.
2 Suggested Answers
jingjao
  • 252 Answers
SOURCE: tv -jvc modele : av-g21t
check the yoke or change the crystal number 503(blue/ orange)if still damage the Horzntal transistor , flyback is defected.
Posted on Nov 16, 2008
How to fix problem of jvc crt tv model av-21l31 power ok no video/audio no display with lines coming from flayback
Look at the horizontal output transistor then the fly back transformer.Check ALL the voltages coming from the power supply. One or more of them have to be missing for the audio and video to be gone at the same time.
Sep 24, 2014 | Televison & Video
Power supply transistor transistor no. C4237 replaced 4 times. each replacement didnot sustain for a week. which transistor can i use instead.
I have worked to repair a few of these. When the transistor is burned, you most likely have a bad flyback transformer and bad picture tube. In this case you replaced this (transistor) component four times. This TV cannot be saved. Thanks for asking.
Oct 19, 2011 | JVC AV-24F704 24" TV
AV-27BM5 relays click on but no picture,high voltage or sound
It's been my experience that symptoms that point to the power supply, generally are not the case. Schematics now days are tough to find unless you are an authorized servicer for that brand. There are a couple of generic dealers out there but they don't carry everything. Before you replace the power supply I would suggest you go though other boards first looking for bad solder connections and/or transistors and IC's that may be defective. A good DVM with an ohm's scale should suffice. If you still can't find anything, I would suggest taking it to a reputable repair person.
Feb 25, 2010 | JVC Televison & Video
JVC AV-36260 No Sound No Picture Red Light Blinks Copntinuously
Try this blog I found on this site. I have the same model and problem with my JVC TV set and I was able to fix it for 2 bucks at home by myself.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Jan 07, 2009 | JVC AV-36950 TV
Albert
albert
thaks for you i.m
I found the solution I repleased coil ( L531 ) and the tv looks like new
Nov 23, 2008 | JVC AV-48P775 48" HDTV
Tv -jvc modele : av-g21t horizontal out put transistor burned after seconds
Nov 16, 2008 | Televison & Video
No power
Replaced the C226 capacitor. Using advice from this web site, found the capacitor, and yes it looked burnt, went to Radio shack and for $1.69 bought a new one, put it in, and we were all set. Does have to be soldered in, in all it took us about 1 1/2 hours. Thanks for the tip.
Sep 21, 2008 | Televison & Video
Monitor horizontal adjust no function
It is the problem of horizantal section.Check horizantan hold transistor that is placed on hitsink of eht and two small transistors near iton pcb.and check horizantal yoke coil pins for dry soldring or low voltages.If thats are ok then change hori. &ver. deflection ic.
Hope this solution works.i am always for you
Mar 15, 2008 | Gateway FPD2275W LCD Monitor
Model AV-32950 will not turn on. The power light is flashing and the relay RY921 is oscillating. I have replaced C926 1000uf/35v & no change. Any suggestions. Circuit daigrams????
did you check his horizontal transistor?what is the voltage of the b+ in flyback. but common causes of that model is the defective horizontal transistor.
Oct 18, 2007 | JVC AV-32950 TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
