Question about Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White
Filling in the gaps between the kitchen counter sides and stove
I have a Kenmore stove and there are gaps between the sides of the stove and the kitchen counters. The food keeps falling into the gaps when I am cooking. I looked up some "gap fillers" online, but they were all made of plastic and looked pretty cheap on the photos. I have a newly remodeled kitchen with green granite counters and the stove is black; and I want to find some gap fillers that would look very tasteful and top-notch. ditto - black granite counter top and stainless steel range at same level
  • marionbagget May 11, 2010
    Have you tried the Sears, a big box home center or the company that did the remodelling ?
MNTECH
  • 1543 Answers
SOURCE: GE OVEN/RANGE INSIDE GLASS ON DOOR SHATTERED.
You will need a window pack, part number WB56T10152 which is not hard to replace. You should be able to order it right from GE, or an appliance repair firm can get it for you, often without extra shipping if they can combine it with other parts they need to order. Should set you back just over $100. You can remove your oven door to make it easier to work on. Use a little screwdriver to pull down the little square hole you will see on the top of the hinge opening on the frame of the oven on each side. That little metal part will lock the hinge open. Next, lift on the door and pull it toward you. The hinge actually stays with the door and lifts right out of the rectangular opening in the oven frame. Reverse procedure to reinstall repaired door.
Posted on Nov 29, 2008
SparkyNZ
  • 43 Answers
SOURCE: frigidaire range blew up
It sound like something shorcircuited and put WAAAAY more current through your oven than it can handle.
You could test the circuitbreaker's circuit by pluging something else in that circuit (a 2kw appliance would be an appropriate test).
It's hard to say for sure but with a fault like that if it wasn't from the oven itself your circuit board should show a visible sign of overcurrent.
I would suggest trying to get something out of the Frigidaire, talking to the retailer if he can do anything and if no one gives contact a consumer reports journal. They love dirt like this.
Frankly, this fault, if it is oven related is dangerous and all appliances should be 'intrinsically safe.'
Good luck.
Posted on May 10, 2009
SOURCE: How can I clean my GE stove top burner and black stove cap???
Soak the black stove caps in 1 part ammonia and 3 parts water. Let soak for several hours. I let it soak overnight. It should clean right up.
Posted on Sep 17, 2009
  • 1531 Answers
SOURCE: corner broken off Frigidaire FEC30S7EC glass counter top stove
the top off these units can be purchased but a more exact model number is need. i can get you a part number and a place to purchase it they run about 208.00 dollars plus taxes if applicable and shipping.just need exact model number for example ( FEF366ABA ) there are alot of different verisons.
Posted on Sep 19, 2009
heatman101
  • 43501 Answers
SOURCE: I have a frigidaire GAS stove. Oven doesn't work.
Even though the ignitor glows it does not mean that it is working...sounds crazy but it is true... the ignitor needs to pull a certain amperage to let the gas valve open and as they get older they stop pulling enough current...
Check out this tip I wrote about this problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Posted on Mar 05, 2010
I need to find a manual for a 1959 Kenmore gas stove
I have a 1959 Kenmore gas stove with the original owner's manual. My stove is a 36" with griddle in the middle, a rotisserie, and a small electric oven on the left side. Very unique. Please contact me for further information. Mary
Sep 17, 2013 | Kitchen Ranges
I have a new viking stove slide in electric top range that was installed in our kitchen with existing granite counter tops. But there seems to be a small gap between the stove and the counter. My previous...
If you are talking about a gap caused by the height of the stove, You can lower the height of the stove by adjusting the threaded leg posts on the bottom of the stove. A more difficult fix would be in raise the height of the countertop and cabinets by shimming the bottom of the cabinets.
If your gap is not a height issue, then you can experiment with some type of trim around the stove itself. Local granite dealers has an assortment of trims for issues like this.
I was able to find a number of trims for a back gap on my granite countertops and backsplash from my local European Marble and Granite.
Mar 15, 2013 | Cooktops
Installed today and there is a four inch gap between wall and back of range! How do I get to be flush with back wall? Counter depth 24 inches with 1/4 granite over hang.
Have your granite contractor cut a "stove strip" to fill the space.  Completely normal.
Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
Jan 15, 2011 | KitchenAid KDSS907SSS Dual Fuel Range
My range top is not excatly level how do you level a glass top range?
Most ranges have leveling legs. Remove the storage drawer and look to see if the legs have threads. Then twist a leg clockwise to raise one corner or counterclockwise to lower it. (It could be reversed - it's been awhile since I leveled a stove.) Adjust as needed to get the stove level front to back and side to side.
BTW: the parts diagram for the 95002 chassis is here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Range-Parts/Model-66595002100/0582/0124111/P0101022/00003?blt=06&prst=&shdMod= .
I hope this helps.
Jan 12, 2011 | Kenmore 95002 / 95004 Electric Kitchen...
How do I set the time on my Kenmore stove.
how to set the clock on my Kenmore Range side in 4558?
Nov 01, 2009 | Kenmore 46123 Stainless Steel Electric...
Trim between range and tile countertop
The range usually about 1/2 inch higher than the counter. Normally there is a gap on each side typically about 1/2 inch. The range would heat up and expand at a different rate than the counter, so they cannot touch...
Apr 10, 2009 | Amana ACF4215 Electric Kitchen Range
Stove Buddy crumb bumper makes a black one that is a heavy duty non metal-can handle 500 F but is not cheap like the kleen seam--
Feb 18, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
GE profile gas stove igniter don't stop igniting
take a look at the igniter located in the center of two burners. clean the gap with a stiff brush between the eletrode and the upper plate. the distance is preset at the factory. you may have enough buildup to close the gap enough to trigger the igniter.
Oct 23, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
Sears Kenmore Automatic Dishwasher: Models No. 14041 /14045 /14045... Problem:
Many dishwasher have their drainlines tied into under sink disposers. If a person caps the sink drain while dishwasher is running, it can back the water back to the washer keeping dishes dirty and backing up water
Jul 05, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White Logo
551 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
