Question about Maytag PAV2300 Top Load Washer
Maytag washer pav2300aww noises in spin
Following a recommended test I went to spin and tried to hold the basket The noise was supposed to stop if it was the spin bearing.The noise continued. I than went to agitate and the agitate froze up I removed the belt and found the pump frozen. The bearing was canted but I found nothing wrong with the impeller. With the washer in the upright position the tub was difficult to turn. I turned the washer on its side and turned the pulley and it turned easily. I am reluctant to buy a new pump if there is another problem. Can you think of any further tests.
  • 47 Answers
I AM NOT A MECHANIC, BUT I CAN TELL BY READING YOUR PROBLEM IS THAT YOU NEED A NEW PUMP. IF IT ISN'T YOUR BELT, THEN YOU MAY NEED TO BUY A NEW PUMP. CALL AROUND AND ASK HOW MUCH THEY ARE. GOOD LUCK. HOW OLD IS YOUR WASHER?
RODNEY
Posted on May 15, 2009
Maytag top load washing machine 2 years old
This could be partly the clutch/break assy. You need to be able to run this with the lid open in the spin position. Activte the lid switch with a pencil or something. Reach in and hold the spin basket and then turn the washer on in spin. Hold this basket for 1-2 minutes then release it and let it reach full speed then stop the washer by turning the timer off or releasing the lid switch. See if the hard breaking/noise is better. Keep doing this untill it comes to a smooth stop and the noise is gone at the stop. Not sure this will cure the noise in the spin starting up problem or not, but start here. the clutch gets rust on the pads and this burnishes the break pads, removing this rust that makes it grab.
Goodluck..
Apr 05, 2008 | Washing Machines
Maytag Performa pav2300aww stops and starts
If it's stopping during a wash cycle, suspect the heater elemant not heating up and moving the controller on. See if it runs fine during a spin/drain cycle. If it is very slow on all programs, try the noise filter capacitor before condemning the controller.
May 18, 2012 | Washing Machines
Tub filled with water, Lr code
To pump out the excess tub water while failing to complete spin cycle;
Enter Service Mode by simultaneously pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
This process is documented in the Service Manual. I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
If I could ask you to do a little troubleshooting;
It sounds like the wash/agitate cycle completes and you enter into the spin cycle of the selected wash cycle is that correct. When the wash cycle fails does the Cycle Status LED indicate that the washer is in the Spin cycle?
With a empty wash basket no wash load in the basket and you start a Spin Only cycle will the Spin Only cycle complete?
If the washer will start the cycle do you hear and loud Spin Only cycle noise such as metal against metal grinding noise?
With the washer off and no clothes in the wash basket can you open the lid then Spin the wash basket as fast as you can in the CCW direction the only direction. The wash basket should spin CCW several rotations and coast down to a smooth stop dose it?
I’m checking for Outer Tub increased bearing resistance…..Rich
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Jun 28, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Jul 27, 2009 | Maytag Performa PAV3200
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
Maytag PAV2300AWW
hi there,
the humming is the motor trying to turn, which means it works. since you did not mention any error messages, it could just be a belt that slipped off the pulley. have you taken it apart yet?
it definitely worth fixing.
Sep 22, 2008 | Maytag PAV2300 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
230 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
