Question about Neff B1421 Electric Single Oven
Oven door does not close fully
When the oven door is closed it leaves a gap at the top and all the heat blasts out.
  • Neff Master
  • 3,463 Answers
You need to replace the oven door hinges.
Please rate my solutrion.
Thanks.
Posted on May 15, 2009
  • mr sadozai Sep 20, 2012
    how much it cost to replace its hinges
  • Anonymous Nov 22, 2017
    Around $40/pair on line, up to $80/pair at retail outlets.
I dismantled the door into 2 separate pieces by unscrewing the 3 screws on each side. I then place a 2mm thick washer on to upper hole of the hinge and a 3 mm spacer onto the upper plastic fitting to slightly angle the inner door skin. Heh presto the door closes and seals perfectly.
Posted on Jan 31, 2013
    New Friend:
  • 3 Answers
I have spent $$$ on new hinges for my KitchenAid double oven doors over the past few years, but they always fail after 6 months or so. Recently I decided on an elegantly simple solution. K&J Magnetics (kjmagnetics.com) carries a line of 1/8" thick, countersunk Neodymium magnets that are perfect. I purchased a pair of their # RE22CS-N magnets (3/4" dia X 1/8" thick), attached them to the upper corners of the door just outside the gasket area with some #8 flathead screws, and viola! They do a great job of closing the door while still allowing a proper gasket seal. Lighter or heavier doors might require a different magnet, but K&J offers types with varying pull-in forces, so you should find one to match.
Posted on Aug 25, 2017
I had neff oven and hot air is leaking. the engineer said to replace the hinges. How much it cost to replace hinges of Neff oven B1421N2GB
Posted on Sep 20, 2012
My oven door leaves large gap at top when closed. lot of heat escapes there. can i fix that
You may need to open the door and adjust the hinges that are attached the door itself as well as the ones connected to your stove..
Apr 02, 2018 | Ovens
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 | Ovens
Door will not close completely leaving 1cm gap at top.
If the door closes fine till that 1cm gap hinges more than likely wont solve it you need to replace the supports that the hinges slot into
Dec 13, 2013 | Electrolux EOG6330 Gas Single Oven
Eog 6330 oven door does not fully close ie small gap at top unless you hold door closed are hinges damaged or bent?
you will have to replace both left & right hinges / this should correct problem .. mm
Jul 12, 2010 | Electrolux Ovens
Euro maid sc1531 oven door dose not close at the top
Did you solve your problem???? Cause I am having the same problem :( I would really appreciate it if you could let me know Thanks
Jul 04, 2010 | Ovens
We have a 30 in prostyle electric double wall oven - the oven takes forever to preheat and the doors do not seal tightly when they are closed.
Hello- Many ovens use spring-loaded hinges to carry the weight of the door. Over time, these springs weaken or the hinge gets bent just enough to not fully close door. The door gasket can also become flat and stiff, compounding problem. Any small gap releases heated air, and oven will not heat up properly. Replacing the door springs should solve problem.- Thanks -Ed
Mar 14, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
Door will not close fully gap at sides and top akp 511
If it is a drop down door with rear hinges, then you need to replace both hinges.
Please rate my solution.
Thanks.
Oct 28, 2009 | Whirlpool RBS275PD Electric Single Oven
Re Neff B1451 oven door not sealing against oven body at top
If you take the hinges off, you can fit some washers between the hinges and the door to make it close it further. Probably not as good as new hinges, but cheaper. 2mm of washers will close a 5mm gap
Dec 30, 2008 | Neff B1451 Single circotherm plus Electric...
The oven door on my Whirlpool oven won't stay closed
Sounds like the door hinge springs are weak, it will probably be neccessary to replace them both.
Please leave feedbck
Dec 06, 2008 | Ovens
Bosch oven won't pre-heat/heat with door closed
Some oven has a door sensor, which prevents heating when door is open, evidently this is faulty, you need a service manual to identify and replace the part, If I find something I will post here.
May 24, 2008 | Bosch HBN 430560B / 430520B Single Oven
Neff B1421 Electric Single Oven Logo
1,307 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
