Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Troubleshooting code for Kenmore HE 2 Plus
My frontloading Kenmore HE 2 Plus washer is giving me a code of F-01. I can't find my manual. Can you tell me what does that mean and what do I need to do? Thanks! Gina
  • 11,896 Answers
Remove the lower front panel of the washer. (the 1/4 screws are across the bottom) Just inside that panel is a tech manual. Skip to the error code section. For an F01, the steps should be unplugging it for 2 1/2minutes (to reset the Triacc (part of the main circuit board). I would also pop the top cover (the screws are in the back) and check for any loose connections on your main circuit board ( front top, right hand corner) WARNING - Circuit boards are delicate and an static shock could ruin them. Ground yourself before touching the connections. If all steps fail, you can contact a local servicer. I only suggest this because I have found there are other things (not printed in the tech manual) that will give a false f01 error code. Make sure they give you a warranty for thier work. If you would like to replace the board yourself, they can be obtained from the local appliance parts supply stores or online form the manufacture. hope this helps
Posted on May 15, 2009
I purchased a Kenmore frontloader washer & dryer yesterday from Sears...it was a floor model. The owner's manual was missing and I was told I could get one online...help where and how?
I wrote a tip about these washers. I include a service manual. It is best you read this before attempting washes. It will save you a lot of grief. DUET SPORT
Oct 23, 2010 | Kenmore HE2 Plus Front Load Washer
Ge frontload washer pausing in the middle of cycle
as to the not draining properly check the pump Ive had to change many of these pumps on this type of front loader or you can go into the diagnostic of the machine. if you remove the bottom panel theres a technician sheet there it tells how to go into the diagnostic menu: first unplug the machine for about 30 seconds then replug the machine then hold in signal then delay then signal then delay after which you willhear the door lock click then ull get a t-01 number use the dial to scroll to t-02 then push start this will give you the error code and tell you whats wrong with your machine compare the code to the technical sheet provided inside your machine remember to clear out the error code when you fix the problem
Apr 29, 2010 | GE Energy Star WCVH6260F Front Load Washer
F21 on the Kenmore HE2 Plus Frontload Washer
there is a removable access panel on the front of the machine under the door. Remove one screw from each side. There you will find the pump that has a strainer basket on it. Remove that and clean the blockage out of there. You will also find attached to the panel, another manual that explains the codes better
Dec 27, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE3t frontload washer does not run. when
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jun 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore frontload washer wont start no beep or error code
May 24, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Frontload washing machine makes noise during spin cycle
call sears 1 800 4myhome they can walk you thru some troubleshooting. First thing pull back the rubber ring between door and barrel to see if anything like pens etc feel into the gap underneath. If not call for troubleshooting. Get a plan with sears then wait 30 days and call in the problem. Fix will cost less.
Mar 22, 2009 | Kenmore HE2 Plus Front Load Washer
I have an error code of F-01 on my Kenmore HE2 Plus washing machine. What does this mean and how do I fix it.
Your washer needs to be serviced by a professional. That error code means there is a communication error between the Control Unit and the EEPROM; the CCU needs to be replaced. Check to see if your product is still under warranty.
Refer to page 2 of this service manual:
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208540259.pdf
Mar 09, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore he2 plus will not start
unfortunatly the only way to solve that is to access the service mode for your washer, and reset the code from it. consult the service/owners manual on how to do it.
Dec 05, 2008 | Washing Machines
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
228 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
