Question about Dryers
Gas dryer lg8319w/l2 doesn't keep heating after started
My Amana gas dryer start out ok, flame starts up and begins drying but after light goes out for normal cool down it doesn't restart for the cycle even though the thermal starter trys to get it going again.
    President:
  • 1,136 Answers
Hi, You will need to change the coils on top of the gas valve. If the ignitor glows but the flame doesn't come on, this is your answer. It is a very common problem with the gas dryer. If I can assist you further, please let me know.
thanks
Vic
Posted on May 16, 2009
  • jmcbride1 Sep 11, 2010
    I have an Amana LG4319w/l2 gas dryer converted to Lp gas. The ignitor comes on but will not ignite the gas. Theis happened before and the technician replaced the ignitor and said the ignitor must dray a certain amount of current to allow the gas valve to open. How do you test to determine this problem? If it is the thermal protection unit that is defective will the unit be open or closed circuit? Any other area that I should look at?
AMANA DRYER MODEL LG8319W/L2 TRIPS BREAKER IN PANEL WHEN I PRESS START BUTTON
You have dead short to earth. You need to call in an engineer to diagnose where the fault is and replace the faulty item. Dryers have 220 volts and big amps, so you don't want to play with this yourself. Often the culprit is a broken element which his touching the case. Second choice would be defective capacitor on the motor, or the motor itself.
Nov 07, 2016 | Amana Dryers
What causes my gas dryer to heat and the flame goes out
Try using timed dry insted of sensor dry if runs ok you need aew sensor strips. also make sure dryer vent is clean.
Aug 10, 2014 | Whirlpool Dryers
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
May 02, 2013 | Dryers
Amana gas dryer LG8319W/L2
try getting a lint trap brush its long so u can get all the way down in the trap try cleaning that first that is usally the problem
Nov 17, 2011 | Amana Dryers
Gas dryer starts out ok. When it needs more temp to keep drying, the glow plug turns on and waits for the lp gas to show up and nothing happens. My quess, 1. solenoid valve malfunctions 2. no flame...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 03, 2010 | Amana NDG5800 Gas Dryer
Amana NDG2335AW Gas Dryer runs but doesn't heat
Check the spark ignitor when firtst starting the dryer up. It should click within the first 15 seconds to light the pilot up
May 31, 2010 | Amana NDG2335AW Gas Dryer
My dryer flame lights then goes out after a little while. It does this on timed as well as amount dried cycles. Drum still turns but heat goes out. I can usually get it going by starting the dryer again....
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 12, 2010 | Frigidaire FGQ332ES Gas Dryer
How do you light pilot light?
Dryer does not have pilot light.  There is an ignitor that glows when the dryer is started and lights the flame when the gas begins to flow.  With the front of the dryer off start it up and look for the glow. when it glows hot enough (or on a newer model it might be a spark) the gas should ignite.  When the flame sensor sees that the gas is ignited it shuts off the ignitor and keeps the gas valve open until the temperature sensor gets high and shuts it off.  When the temp sensor cools down the cycle repeats.
If no glow or spark-->bad ignitor If no gas flow-->bad flame sensor or bad gas valve coil If gas comes on and goes off quickly-->lint filter and/or vent pipe or outlet may be clogged or bad flame sensor.
May 29, 2009 | Whirlpool Dryers
Dryer flame on magtag wont stay lit. Pilot flares up but no flame
Thermocouple is probably bad. The pilot burns and heats a sensor which tells the CPU that the Flame can start, and the thermocouple heating up changes voltage with increase temperature and tells the CPU that the Flame is burning OK. If it is defective, there is no voltage change and the CPU assumes that the Flame didn't start for some reason, (Gas only!) and turns if off for safety. Over and over xx times.
My .02
Good Luck!
Mar 26, 2009 | Dryers
Dryers Logo
144 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
