Question about Cyberhome CH-DVD 300 DVD Player
Shows "Loading" but won't play
Cyberhome CH DVD 300.....tried 5 different DVDs with same result. Worked fine until about 3 weeks ago
    President:
  • 814 Answers
You can try cleaning the laser head and drive carriage. Clean the laser head with cotton swabs and small amount of isopropyl alcohol.Rub the swab back and forth across the head of the laser, do not apply to much pressure or you knock the laser out of alignment.Check the carriage, clean the the guide rails and check the belts and gears. All should be cleaned and checked to see if still in functional condition. if all this does not help you with your problem ,then the laser unit has probably weaken through age and can no longer function properly. Hope this helps you with your problem.
Posted on May 15, 2009
My CyberHome DVD 300 says "bad disk" every time I load a dvd.
pls check ur dvd player optial pickup lense.try to clean or replace.
Dec 28, 2009 | Cyberhome CH-DVD 300 DVD Player
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
Cds fine; dvds won't load
Most likely the DVD laser lens is dirty. Unplug the CH-DVD 300 from the wall outlet, wait 5 minutes, then remove the top cover. Next, remove the rectangular metal plate which covers the area where the CD or DVD disc would be when in the player's tray. Underneath the rectangular plate you should see two small lenses. Gently clean these lenses using ear swabs moistened with isopropyl alcohol. Reassemble the CH-DVD 300 in the reverse order that you disassembled it, plug it back into power, and now it should read your DVD discs just fine.
Aug 13, 2009 | Cyberhome CH-DVD 300 DVD Player
My Cyberhome CH-DVD-300 (dated 2003) will play movie DVDs, CDs with photos and music CDs. It will not play a DVD with a slideshow software for photos with music and text that I burn on my computer. The...
I feel for you because I also have the same unit and have been frustrated in the past when I tried different dvd's to play. The conclusion that I have come to is that I only use my cyberhome player to play rented dvd's
Jul 13, 2009 | Cyberhome CH-DVD 300 DVD Player
Not playing dvds but only trying to load with no success
I had same problem, I resolved by this way..
After opening cover , I found one ribbon wire was not moving freely,(That wire is connecting Lens), After stopping DVD, by hand I have done it free (for easy moving), After that it started working properly.
~Sudhakar
Pune-India
Dec 09, 2008 | Cyberhome CH-DVD 300 DVD Player
CH-DVD 300 Freezes Then Skips Ahead
Chech the laser lens rails maybe got dirt clean it take off the grease they got.
Jun 26, 2008 | Cyberhome CH-DVD 300 DVD Player
No color picture on any DVD played
Make sure the scart lead in pushed in fully and none of the pins are bent!!
Mar 27, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Region Error
this is for: Cyberhome CH-DVD-300 1. Ensure the players disk tray is Closed with no disc . 2. Press Menu. 3. Press 1. 4. Press 9. 5. A menu will appear with the region number near the bottom of the screen. 6. Press Enter. 7. Select the desired region. 8. Press Enter to save the settings.
Jan 31, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
115 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Henry  Thomas
Henry Thomas
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
