Question about Pentair 1.0 Hp Whisperflo Pump
Low pressuere motor pump when i plug the vacumm drop 30 to 5psi
I have ah low pressure when i conect my vacum i have 30 psi and they drop to 5
    Problem Solver:
  • 16 Answers
If your filter pressure is 30 psi it needs to be backwashed! Reson pressure drops when hooking up vacuum cleaner is reduced water flow will drop pressure
Posted on Aug 23, 2009
Oil light on after engine warm-up on idle
this means a mechanical gauge test is required to check actual pressure warm idling if low below 20 psi then the oil pressure pump relief is stuck open or engine bearing are worn
May 15, 2014 | 2005 Opel Astra 1.4
Put on new fuel pump got pressuer but want stay cranked
Your post is lacking any detail. However, if you are stating that the engine starts after being cranked but dies out (wont stay running) there are 2 ways the fuel pump is activated. When the key is first turned on, there is a 5 second fuel pump run (the ECM energizes the fuel pump relay). After the engine starts, the fuel pump relay will only stay energized when the oil pressure switch closes keeping the fuel pump relay on (oil pressure is above 5-7 psi). If the oil pressure switch is faulty or there is no oil pressure, the engine will stall just after starting.
Apr 10, 2014 | 1999 Chevrolet Astro
1999 blazer sputters at Idle and take off. Changed plugs and fuel filter. Got what looked like coffee out of old filter did fuel pressure check got 60 psi when turned key to on, then dropped to 54-55 psi...
With pressure like that I would say there is nothing wrong with the pump. A 5 psi drop with the engine running would indicate that the injectors are getting a good supply of fuel. I would have the fault codes read to find a fault before I wasted money chasing something that may show up in the test.
Oct 08, 2013 | Cars & Trucks
Pump stops suction when I try to vacum pool
1. Something is stopping the seal at the basket
2. The hose going to the filter housing is partially clogged or not sealed
3. If you have a 2nd filter basket before filter housing, clogged/not sealed
4. Filter is clogged and needs to be cleaned, not just dirt, but degreased
5. Leaking pressure valve if one is used
I had a large filter and regular pressure was well above 5 psi, (8 to 10psi) with everything cleaned and running, once vacuum hose was connected it jumped to 14 to 18 psi.
May 05, 2012 | Hayward 1 12 Hp Super Swimming Pool Pump...
How do I change the front fuel sensor on a 51 plate freelander
get a new fuel pump and screen then drop the gass tank get hi pressuer clamp releasher dis conect the battrey releave the gas pressure on the fuel rail befor you themp to remove the clamps on the gas tanks the replace the whole fuel pump and screen note replace the fuel filter allso
Feb 18, 2010 | 2002 Land Rover Freelander
Describe your trouble shooting 91 gmc truck Problem Truck will start it won't idle you have to pump gas pedal to keep it running but it is fluttering the whole time. unhooked vac line to map sensor it will...
test fuel pressure by renting a fuel pressure test kit from schucks or auto zone then turn key on then off if it hits 50 psi it's ok if it drops below 20 psi in one minuter then fuel pump is bad. if it has throttle body injection then replace the injector or pull it apart to see if it is plugged.check oil pressuer switch behind the distributor to see if it is bad it will cause it not to run if defective.
Jul 18, 2009 | 1991 GMC Sierra
Pump spinning but not getting up to speed then shuts off
You have a pressurized system using a pressure tank.This is a case of an air logged pressure tank. Meaning there is more air than water in the pressure tank. The pressure tank must hold 2/3 water and 1/3 air of its total volume. Installed at the tank is the air volume control to take care of this proportion. Should the air volume control malfunction or becomes defective, the air-water ratio is affected. And then,
the pressure tank becomes either air logged or water
logged.
SOLUTION:
1. Shut the power off, and open the discharge line
gate valve to flush the water in the pipe lines.
2. Open the drain plug of the pressure tank to empty
all the water at the pressure tank.
3. Close the drain plug, and put the power on.
4. Start the pump, and set the flow control valve 1/4
open.
5. The pump will normally run.
Send your e-mail for us to know the results, and for
further assistance.
Jul 04, 2009 | Plumbing
1998 toyota camry,4,cylinder, 5 speed
it sounds like your oil pressure sending unit may be plugged by whatever took your pressure down to 5-8 psi the first time. this is extremely low pressure as i am sure you know but at 30 psi your light should go off i would replace the sending unit if your oil pressure is holding 30
May 15, 2009 | 1998 Toyota Camry
The pump builds up pressuer to 80 to100 psithe motor cant turn any more due the pressuer in the pump, can you tell me why this happens dayton compressor model 5Z592 5hp it had a 3phase motor when it was...
hi your problem sounds like the non return valve is either missing or is passing back pressure
the nrv should be on the hose that supplies the tank
Mar 24, 2009 | Air Tools & Compressors
Pentair 1.0 Hp Whisperflo Pump Logo
273 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
