Question about LG RU-44SZ63D Television
Tv shuts off, and then turns back on, by itself
LG DLP model #44SZ8D shuts off then back on by itself. Duration varies from 10 seconds to 30 minutes. Frequency is three or four times per day.
When it shuts off you cannot manually switch it on, it will not work.
You have to wait an undetermined amount of time.
  • 62 Answers
I gave this answer for another requester with a similar problem.
Is there a person in your environs who is mischievous or prone to malfeasance? Someone may be using a TV-B-Gone on you. Check this out:
https://cornfieldelectronics.com/tvbgone/tvbg.home.php
Posted on Apr 14, 2014
  • 187 Answers
Mainboard damaged and need to be replaced, try EBAY for a general picture of prices but you will need your product code wich is located in the back of the TV next to serial number.
make sure you dont have a device plugged with two differents cables ie. HDMI and AV or HDMI and COMPONENT
Posted on May 27, 2009
Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
Samsung HLS4226 DLP television turns off periodically
It is the lamp, go to bestbuy.com and at the bottom look for orderparts. this is a third part vendor that has many aftermarket parts to replace manufacturers. They might have a replacement bulb in there for you. They usually run $250 or so but vary per manufacturer
Jul 26, 2009 | Samsung Televison & Video
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?CLICK=52978
Please keep us posted.
Jun 14, 2009 | Samsung HL-S5087W DLP TV
LG 52SX4D turns off randomly.
My Lg 52"tv turn off and on
Apr 29, 2009 | Televison & Video
HP Pavilion MD5020N 50 in. HDTV DLP TV keeps shutting down
ok this is what you do folks.... un-plug the tv from the power supply. once that is done hold the power button down on the side of the television for 30 seconds. this will release all electricity out of the tv.... then before you plug it back in hold the channel down vol up button along with the power button at the side on the tv this should reset the tv and it will start up automatically on video one. Select your source and scan for your cable channels again. If the problem is not solved then contact someone to come and clean the filter for the tv because it may be clogged along with this it can be the color wheel and may shut itself off like 3 times until it feels it is right.
Apr 08, 2009 | HP Pavilion MD5020N 50" DLP HDTV
LG RU-44SZ63D Television Logo
407 people viewed this question
Computer Repairing
Computer Repairing
