Question about Danby DDW1805W Designer Series Free-Standing Dishwasher
Water not flowing into Danby 18"
My danby 18" portable dishwasher will not run. the power is working, the attachment seems to be latching to my sink, but the water does not seem to be entering the machine.
It worked yesterday (this is the second time we are using it, or trying to use it). When I stop and examine the hose that is supposed to deliver water from the faucet to the machine, it appears to be filled with water. BUT, it clearly is not "delivering" water to the machine, because when I feel the hose, it does not warm up, even though I only have the warm water turned on.
The door for my Danby appears to be shutting properly, and the power lights and everything are on. I can even hear the "engine" running. My water pressure is not spectacular, but it worked fine yesterday. None of the cycles work. Neither quick nor super settings work.
  • johnbowers May 18, 2009
    Same exact thing has happened to me twice...the first time, I called in a warrantee repair, and the service guy told me it was the pressure switch. I asked him to show me how to flip it myself, but he wouldn't.
    So now that it's happened again, I find myself needing another appointment. I'd rather just know where the pressure switch is! Help us, O Wise Internet!
Okay, this might seem crazy, but it worked. I spent the last 2 days trying to contact Danby customer service to no avail, so I came back here to look for solutions. Found two:
(1) Someone said to open the little rubber cover under the front right of the machine...I couldn't find such a cover.
(2) Someone said to pull off the front plastic panel...mine doesn't seem to be removeable.
So! I turned my Danby DDW1805 upside-down (!) to see if I could locate the aforementioned rubber cover, and a bunch of water drained out of the machine. This is what both solutions above said I wanted to happen, so I flipped it back right-side up and hooked it back onto my faucet.
Golden. Works perfectly again.
Posted on May 27, 2009
How do I open door of the new 18 Danby dishwasher. This model has no latch under handle.
I assume you have gone through instructions supplied fully. You will have to contact, Danby directly, there should be contact information in the instructions.
Mar 11, 2017 | Danby Dishwashers
I need a manual for a Danby Model DDW1899WP-1 portable dishwasher
Danby has the manual for the DDW1899WP-1 on the product information site: https://www.danby.com/en-us/products/kitchen-en-us/ddw1899wp-1/ . Look in the right hand column as you scroll down. The direct link to the Owner's Manual is currently: https://www.danby.com/wp-content/uploads/2016/04/DDW1899WP-1_EFOM_201504212.pdf .
I hope this helps.
Oct 15, 2016 | Danby 18 inch Portable Dishwasher in...
Why won't my portable dishwasher work?
Recommend check door closed and not blocked; sprayer not blocked, dispenser not clogged, door latch locking and latch sensor connected and conducting.
Dec 31, 2014 | Danby "DDW1899WP 18"" Portable Dishwasher...
Attach hose to sink
what is your question? if it is how to attach there is an adapter that screws on to facet and then you connect the hose piece to that.
May 07, 2014 | Danby DDW1899WP 8 Place Setting Portable...
Water not drains,Danby Portable Dishwasher
I had the same problem and found the drain blocked at the outlet as it goes into the sink.
Dec 27, 2013 | Danby DDW1899WP Portable Dishwasher
We just bought a house, and it has a Danby WWD1802W dishwasher. My husband turned on the water supply to it and plugged it in. It sounds like it is on, but it won't fill with water. The water is not...
first make sure the line is on under the sink the next thing that you would check is that you have water flowing to the water valve after you check that you do have water flowing to the valve you would then assure on the plug in connection that plugs into the solenoid on top of the top that there is power going to the valve when the unit is pressed to turn on if there is power going to the valve then the valve would be at fault and have to be replaced if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to continue helping others in similar situations in the future Thanks again Rick
Apr 29, 2011 | Danby DDW1802W Built-in Dishwasher
I have a water-softener dispenser in my Danby 1899 W Portable diswasher. I do not know how to fill the dispenser and I cannot run the dishwasher until this is resolved. The user manual provides no...
I couldn't find it either for a long time:
1) Pull out the bottom rack as if you were putting dishes there
2) Look at the bottom of the dishwasher and there will be a white circle (near the upper left side) where you can add the water softener.
I didn't use any for a while and the dishwasher worked great so I'm not sure why you can't run it.
Sep 30, 2010 | Danby DDW1899WP Portable Dishwasher
Danby portable dishwasher filter stuck
If it says just pull up then you do just that, it is likely rusted on.
Jul 18, 2017 | Danby 22 in. DDW399 Free-standing...
Danby dishwasher
Call Marcone Supplies, Tampa Florida. (they are Danbys Supplier for parts.) DO NOT WASTE YOUR TYIME CALLING DANBY. They are not helpful. Danby 18" Dishwasher. Model # DDW 180 2W Parts 800-482-6022. Marcone:Very helpful. My door is open; thank goodness; it just will not stay closed. Latch broken on door. I have to order the "whole handle assembly" (all one piece which includes the door handle latch too.) $4.16 shipping from PA. I am in Calif. Total $12.53. 2 screws. Easy. I can do it, I know I can. (Signed, a woman in LA!)
Jan 22, 2008 | Danby 17 in. DDW1802W Designer Series...
Danby DDW1805W Designer Series Free-Standing Dishwasher Logo
400 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
