Question about GE Cooktops
My ignighters on all burners are clicking help solve my problem
  • 355 Answers
Sounds like the electric sending unit for the burners is not working. Do you hear the cliking noise on the right side when you turn the knob to LITE? If not then you need to replace the electric sending unit, they are located under the knobs, they are a smal square box that goes on the switch valve rod, they have tow wires on the side, just unplug and lift, and look for greasse or anything that might interrup contact, you might be able to use the same ones, or just replace with new ones....Good Luck
Posted on May 15, 2009
Model CVGX2423W ignighter sparks at all four bunners if only trying to light one
Every time you try to light just one burner the ignighter will try to light them all. The reason why is that they are all wired to the same switch under the cook top. There is nothing to be worried about. That is the way the factory made the cook top.
May 01, 2010 | Jenn-Air Cooktops
Igniter doesn't spark on only one burner
There are three parts to the ignition system typically.
The ignitor that is either in the burner or outside the burner.
The spark ignitor switch that is located on the burner control. (( one for each control ))
The spark modual. the modual creates the hi-voltage spark.
If the burner that does not ignight with its control does not spark but does spark with one of the other controls then the spark ignitor control switch is bad.
You can test it with one of the other burner control knobs. (( just try a working burnder and when it clicks look at the bad burners ignitor and look for the spark.))
If the bad burner that wont ignight does not spark then either your modual is bas or the ignitor is shorting out.
If you see any little spark but it does not spark from point A to Point B like the other burners then your ignitor is shorting and should be replaced.
If your ignitor is ceramic and it is cracked, then it should be replaced.
Jan 13, 2010 | Miele KM360GSS 23 in. Portable Gas Cooktop
Jenn-Air 36 Gas Cooktop
try to use macth in the burner u said,if ok the flame,the problem is the igniter wire,nid to replace,but if u use the macth then the flame is malfunction again i think the sensor is the problem,nid the tecnician coz is hard to repair,sometime after repair the sensor it problem again in next day
tnx gerbee
Jul 02, 2009 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
Ignighter issues
gud day,try to clean the area wer the knob place by using vaccium try to remove the knob then claen by vaccium,coz the dirt inside coz of grounding.
Jan 08, 2009 | GE 30 in. Profile JGP989 Gas Cooktop
Creda gas hob now keeps ignighting
the ignitors have got wet usually due to cleaning. they are usually located under the rotating switches just let them dry out ( very well .....may take days) and it will work normally again
Dec 23, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
One burner has no spark for ignition..
Yes this is arcing, and should be replaced. If it is still atatched, you may be able to move it away from an area that it is arcing onto, and give it a try. Wery often it is just items in close proximity that causes the issue.
Jun 29, 2008 | GE Profile JGP636 Gas Cooktop
All five ignitions clicking rapidly
yes is safe you probably got the ignighters switch's wet if one is wet will cause all to fire after awhile they dry and return to normal
Jan 10, 2008 | Cooktops
Cooktops Logo
Top GE Cooktops Experts
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
