Question about GE Profile Harmony DPGT750GC Gas Dryer
Ge dryer blows cold air, it doesn´t generate heat
My dryer blows cold air, it doesn´t generate heat
  • 112 Answers
SOURCE: the dryer only blow out cold air.
I would start by checking the continuity of your thermal fuses on the unit. You will have at least one and they will be located around the heater element or ducting near the heater element. If they check out good, check to see if you have an open element.
Posted on Oct 18, 2008
futureloginn
  • 734 Answers
SOURCE: DRYER BLOWING COLD AIR-NOT HEATING UP
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
jsrock516
  • 5911 Answers
SOURCE: kenmore model 76712 does not blow heat just cold air
The following link explains how to troubleshoot and dryer "no heat" problem and the common causes:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Read through the link thoroughly, paying particular attention to the section that discusses proper ventilation. Most dryer heat related problems are caused by insufficient air flow which, in turn, causes the dryer to overheat to failure. More commonly, the Thermal Cut-Off (TCO) fails. You will need to check all the components mentioned in order to be sure. If you haven't had your dryer ventilation cleaned or inspected in a while, now would be a good time to do so. Failure to correct any potential existing problems, can cause premature failure of any parts you replace.
If you have questions, or require additional assistance, please let me know, so I can provide you with a viable solution. i hope this helps you.
Posted on Jan 22, 2009
  • 98 Answers
SOURCE: the tumble dryer is work but is only blowing cold air
sounds like a heating element. not to hard. remove the back and its is right there.
Posted on Jun 07, 2009
Illeagle
  • 525 Answers
SOURCE: maytag performa dryer will not heat up
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
maytag performa dryer Model PDGT910AWW
"No Heat" complaint.
Firstly, make sure that you have selected/ascertained a "Heat" setting, then read the checklist below provided by; www.repairclinic.com
They also provide disassembly diagrams and repair parts..
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Jul 08, 2009
GE dryer dwsr463eg7ww timer isn't working and doesnt heat up
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/7-3-850356-/GE-Dryer-won-t-stop-DWSR463EG7WW
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Sep 12, 2014 | GE Dryers
Tumble dryer isblowing cold air only?
Your dryer is called smart dryer and in this case should have to generate familiy code E60 (or any of exactly fault code E61,62,63,64,65,66,67) if blowing cold air, as you explain. Means something is wrong with heating phase (drying).
So, in this case could be: Heater unit faulty; Wiring faulty; NTC sensor faulty/out of position; Electronic board faulty;
Thermostat faulty; and finally fun motor - but considering that it blows cool air I guess that is correct.
24642590-hf2jxxovvq5cn05mugly0fcq-2-0.jpg Dado
Jun 16, 2014 | AEG T58840 Dryer Electric
My GE profile harmony dryer blows cold air on any setting do I need to replace heating element?
Yup...heating element (usually there are two) is done. Likely the first one was done long ago and the second has finally died.
Dec 03, 2013 | GE Profile Harmony DPGT750EC Electric...
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
In the heat mode blows cold air heating element good condition
There are a few different things that could cause the heater to blow cold air. I would suggest looking into the different parts of the heater that cause the heat to be generated. If any of those are bad, it would definitely cause this problem. If you aren't able to find the damaged part, you should talk to a professional to look at it for you. Hopefully you can get this figured out without too much trouble.
http://www.getzschman.com/bellevue-ne-air-conditioner-furnace-repair-installation/
Jan 29, 2011 | GE Zoneline AZ38H12DAD Split System Air...
I have a GE DPGT750 Gas Dryer. The dryer will not heat up. Air is blowing out of the exhaust outside. However, the air is cold.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 28, 2010 | GE DPGT750GC Gas Dryer
My GE gas dryer is blowing cold air and wont blow hot air. what could possibly be the ploblem.
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 06, 2010 | Dryers
Dryer works but is only blowing cold air. just bought the dryer last year and have already had it repaired once.
my Samsung was in a flood(so solution may only apply to floods), changed heater assembly, still blowing cold air, turned out to be the little black box on the generator, took box cover off,cleaned the connectors in box and voila...instant heat
Nov 28, 2009 | Samsung DV448AEE Electric Dryer
Not getting heat from dryer
check the high limit switch and glow rod
Sep 15, 2009 | GE Dryers
GE Profile Harmony DPGT750GC Gas Dryer Logo
1,017 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
