Question about Kenmore 63672 Convection/Microwave Oven
KEMS378GSS3 Door has lost tension
The door on this micro opens like a traditional oven and used to have a a spring that provided tension so that the door did not drop. I ordered part 4375324 tesion spring to fix the problem, but I can t figure out how to take the door apart. Is there a diagram of the door that can guide me?
    Brigadier General:
  • 3,917 Answers
Please find the diagramatic presentation for the replacement or removal of the door.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/d12cd4888abce86285256a42005ea985/0330c966a25780ac8525740c006f9000/$FILE/4317430.pdf
Do not be worried about the model if its exactly not the same as the basic removal process is 99% similar.
Thank You
Posted on May 15, 2009
Blows fuse when you open door
Be-safe, Un-plug your microwave oven ,
Open the microwave cover ,
Close and open door few times to check the door latch(es) and switch(es).
Door switch assembly may has one or more micro switches.( Most switches are black or grey and about 1,25 in long X 3/4 in wide X 5/6 in thick with two or three wire connections).
Making sure door latch close and open these micro-switches.
You can hear the switch "clicks" when small switch pin or lever is pressed.
Sometime these door micro-switches pin or lever get stuck or broken.
You can take couple pictures before remove wires or micro switches
You can buy these switches for about 3-7 dollars online. Some web sites have video showing how to check them. (Using Volt-Ohm meter)
Jan 24, 2014 | Magic Chef MCO160UB Microwave Oven
I have a Durabrand DBM001 microwave which until yesterday was working fine. Have checked plug and socket - they are working fine. As it is only a basic microwave there is only a timer button to turn the...
This could be the upper latch in the door. Mine stopped working just as you describe. After dis-mantling I noticed the mechanical action which should operate 3 micro-switches in the door lock was not working correctly on the upper switch when the door was closed.
This is part of the safety interlock circuit to prevent operation of the magnetron when the door is open.
Closer inspection of the door striker arm revealed a crack which allowed the top part of the arm to spring away from the upper switch which stopped the oven working.
This part is easily removed by prising the door inner trim off gently, starting at the bottom was easiest for me, then sliding the arm up against the spring tension until it slides clear of the guide grooves, finally detach the spring.
I have no idea where to get spare parts for this ASDA only branded product, so I am going to use super strong epoxy resin to repair the striker arm.
Jul 31, 2013 | Microwave Ovens
Broken Neff microwave hook for tension spring on door. Can I reconnect spring to metal frame or will there be too much tension?
If you very carefully prise off the inner trim of the door you should be able to see where the lug broke that was originally holding the screen. Use a small cable tie to fix one end of the spring to one a the angle pieces of metal around where the window is, about the same level (make sure the other end of the spring is on the hook assembly). You can secure the cable tie and adjust how tight you pull it to get to roughly the same tension it would be if still on the original lug. Cut off the excess of the tie and clip the frame back in position. Door should open and close now.
Hope this helps
Mar 28, 2013 | Neff H5430 Convection Microwave Oven
The 2 hooks(latch) inside the door have lost spring tension.
For no apparent reason, the latch broke on the 9187 ST. Take the door off of the microwave,which isn't too hard. Rotate the door to 90 degrees, lift up, and slide it to the left. Place the door on the counter, latch side up. Use a thin knife or screwdriver to lift the panel that covers the latch. It is very easy to remove it from the door. Then slide the latch up and lift is out. The spring is under the latch. The clip on the latch that held the spring was fractured. So, I drilled a tiny hole in the body piece from where the clip extended. I reattached the spring to the latch, replaced the panel, replaced the door, and it is as good as new.
Nov 11, 2012 | Samsung SMH9187ST Microwave Oven
I opened the door on my sharp microwave and now it wont latch. it sounded like something snapped off where the door latches to the microwave, not the door itself . Even if the door is held shut the light...
It may be the latch head spring or the door open lever or button.
DOOR SPRING LATCH HEAD HOOK
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
you have to separate the door panels (as shown in the attached photo) and then you'll see how it goes together.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
DOOR OPENING BUTTON LEVER
What usually breaks is the door open lever, but it may also be that the rear side of the door open button has worn down too far to work.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can usually find exploded views and part numbers for Sharp models by entering your model number at the Sears parts site.
If not, let me know. We have many Sharp manuals and if we have yours, we can link you to it at no charge.
The best place to order Sharp parts is
Encompass (formerly Tritronics).
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Oct 10, 2009 | Sharp R-1480 Microwave Oven
Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Mar 26, 2009 | KitchenAid Microwave Ovens
Door won't latch/microwave won't turn on
The door does come apart. Open the door and where the hinges are, there are openings where the hinges enter the door, this plastic piece (goes all the way around the door) With a small flat blade screws driver VERY carefully pry it (plastic) off, once off, check the latch end for the spring, typical failure for a Sharp is the little tab that the spring hooks to on the door, the only way to repair this so it will last is to replace the door frame. they are not too expensive, about $50 or so Part# FCOVB166KIT
is the door frame assy
Jan 07, 2009 | Sharp R-1405 / R-140 Microwave Oven
Microwave door tension spring
See answer here http://www.fixya.com/support/t265705-microwave_door
in different thread.. Basically have to pry plastic trim ring off inside of door with putty knife (careful, it cracks easily) to get to screws on bottom of door. See second pic. Top screws are easily accessible from inside of door. Spring can easily be replaced by hand once you get adequate access. You'll need a fairly stubby right angle screwdriver (I used a cut-down #2 Phillips bit and small Vice-Grips as a make-do) to get to the screws. Also need Torx (T10, I think) to detach the shock absorber doodads from the door where they attach above the hinges. If you're just starting to take the door apart, be careful when you take out the top 2 screws on the inside-- they hold the inside plastic piece on , but they also hold the whole outer stainless/ glass/ handle piece on. It just slips in at the bottom, so be ready to slide it out when you take these screws out.fea33aa.pngc391898.jpg
Dec 16, 2008 | KitchenAid KEMC377K Convection / Microwave...
I've replaced the computer on my kitchenaid kems378gss3 oven/microwave combo. I need the "codes" to key in on the keypad - to make the microwave actually "cook: things. Everything else works...
If you don't have the owner's manual you can download it here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%204452300.pdf
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20(Micro)%20-%204452614.pdf
Some units will not allow time programming if the door is open - or if the microwave thinks it is due to a bad door switch or door switch mount, etc.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 07, 2008 | Microwave Ovens
Kenmore 63672 Convection/Microwave Oven Logo
137 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
