Question about Movincool Classic Plus 26 Air Conditioner
Can Movincool classic plus 26 AC set the air temperature at below 70 degree F?
The unit minimum temperature setting on the control panel will not go below 70 degree F? Is there a way to set the air temperature at below 70 degree F?
  • 909 Answers
Aircons normally pull down to approx. 17 degree celcius.and heats to approx 30 degree celcius.  most of the time you need to simply clean the condenser properly and to make sure fans are in good order.
Posted on Oct 23, 2007
How can i change the temperature setting less than 65 degree F
gettting it lower would only give problemes like dripping water all over your floors and walls from condensing water on the casing and other parts as they are not insulated for that purpose it could also lead to burning the compressor for having liquid freon entering the compression chamber as liquid doesnt compress, in short its just inst build for those kind of temperatures..
Jan 02, 2015 | Movincool 60,000 Btu Movin Cool Portable...
Hi,My remote do not get the good temp in my house. Ex: I set to 80F in heat mode but the thermopump operate slowly and dosn't get hire than 70-72F. The remote see the unit and all. Is the sensor in th
You have a heat pump.
Once the outdoor temperature falls below 36 degrees, heat pumps will sharply lose their ability to heat.
If you are getting a 72 degree indoor temperature when the outdoor temperature is 28-30 degrees, the heat pump is performing up to spec.
On heat pumps, the air coming out of the nearest air vent to the unit should be heated approximately 40 degrees warmer than the air entering the unit.
If you have a 70 degree indoor air temperature, the heat pump should be supplying 110 degree air at the closest air vent to the indoor unit.
Gas heat is a much better heating source where outside temperatures are commonly below 36 degrees.
Even electric furnaces perform better than heat pumps under these conditions.
Nov 30, 2014 | Heating & Cooling
Why is the AC still running after the set temp has been reached?
You may be hearing the fan run. Normally the fan will run 30-90 seconds after the unit has reached temperature to give you the air that you just paid to condition.
If it is actually the a/c running, that is because the thermostat internally reads in tenths of a degree. So when you set it to say 70 degrees, it is really set to 70.0 degrees. The thermostat will show 70 degrees when it reaches 70.5 degrees and continue to run all the way to 70.0 degrees
Welcome To the Best HVAC
Oct 10, 2014 | Heating & Cooling
After five minutes ac is starts tripping again it starts for some time and stops.even we set it at 16deg temprature
For beginners, 16 degrees cannot possibly be the temperature you are setting your A/C unit to... and anything below 70 degrees F you are risking freezing up your unit! Sounds like it might be a good time to invest in a new unit?
Jul 10, 2010 | Whirlpool Electronic Window Air...
My air conditioner is leaking water
The air conditioner have water runs into the plastic container and when the container is full of water the weight will switch off the whole unit until you empty this container.
The tube that deliever the water into this plastic container blocked up with dirt that stop the water runs into the container and overfill the condenser drain pan that water runs all over the floor. Clean this condenser pan outlet and the connecting tube then you will be ok.
Jul 01, 2009 | Movincool Classic Plus 26 Air Conditioner
Thermostat window ac turns unit on and off 8 degrees above se
the unit may be drawing the cool air it just released back into itself,plus the air close to the unit may be a little cooler than the air in the rest of the room.
Mar 19, 2009 | Kenmore 72059 Air Conditioner
AC not producing cool air
If this is a newer system there will be a freeze sensor. It may be low on refrigerant. I would check the obvious things first. Are the filters and coils free of debris? Finally only set the temperature to your comfortable temp not lower as this can cause freezing too (generally not below 70 degrees)
Jun 23, 2008 | LG BG8000ER Air Conditioner
AC changes temperature by itself!
If it's not some sort of built in economizing feature, someone else isn't getting up and changing the temperature while you are asleep and the air conditioner fairy is playing tricks, then the control PCB is in need of repair and will have to be repaired through a sears authorized repair center.
I am a bit surprised that it will allow you to set the temperature to a low 70 degrees as this is pushing the limits of an air conditioner. They tend to freeze the coils at around that temperature.
Jun 07, 2008 | Kenmore 75050 Wall/Window Air Conditioner
Movincool Classic Plus 26 Air Conditioner Logo
335 people viewed this question
Top Movincool Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Movincool Heating and Cooling Expert? Answer questions, earn points and help others
