Question about Eclipse Premium 34230 Car Audio Amplifier
Eclipse 34230 no base
Just got hold of the amp and installed it, but the sub is not really being moved i've read that this amp is really powerfull. i have one xtant 12". the amp prior to this was a ppi pcx280. what am i doing wrong here i had the other amp bridged but i guess you cant with this one so where am i going wrong? also all the settings are on max...
  • 631 Answers
If the woofer isn't moving significantly, try the following settings:
gain at highest (most sensitive) setting
crossover at highest frequency
subsonic filter at the lowest frequency
If those do nothing and you have a dual voice coil woofer, you may have one coil reversed. If you disconnect one voice coil and the woofer moves significantly more, check the polarity of all speaker wire connections.
Here's a brochure for the amp:
You're correct. this amp cannot be bridged to produce more power. It's minimum safe load is 4 ohms per channel. It's essentially two bridged amps in one chassis.
Posted on Oct 16, 2007
Model 34230 powers up then one second later green power light slowly fades off. What can it be?
if ur fuse is not blown it might bee to wires touchin of grounding out it will put it into protector mode
Nov 21, 2010 | Eclipse Premium 34230 Car Audio Amplifier
My subs are moving and pulsing with the volume off
I am currently having this problem. Im no professional but i have done installs on my own personal cars and my friends cars (saab 95, Mitsubishi 3000gt, 1996 mustang, 1999 mustang, ect..) I have replaced every but my amp, so today i tried using a friend of mine amp and that solved the problem. I have a TON of research on this and everything i've read says its more than likely a bad relay on the amp and unless you have FLAWLESS soldering skills not to mess with it. idk if this helps much but it was the solution to my problem!
May 05, 2010 | Car Audio & Video
you need to get a bigger ground wire and the cut in and out will stop the cutting in and out is the protection mode starting if it cant hold the thump a capacitor 2farad will hold the bass
hope this helped
Feb 15, 2009 | Eclipse Premium 34230 Car Audio Amplifier
Help my fuse is blow!
If the amp blows fuses only AFTER you send remote turn-on voltage to the amp, the amp probably has blown output transistors. To eliminate other possible causes, read through the following page.
Amp Troubleshooting
Let me know if you have any other questions.
Aug 25, 2008 | Eclipse Premium 34230 Car Audio Amplifier
Car Radio
hello. you can find what your manual at this link!!! hope this help's you. let me know "GOOD LUCK"
Aug 17, 2008 | Eclipse Premium 34230 Car Audio Amplifier
Amp turns on and off
loose power connections. check your terminals.
May 19, 2008 | Eclipse Premium 34230 Car Audio Amplifier
Hi, i have jbl 1201.1 running 2 audiobahn aw1200v subs, i used to have 2 jl audios but the amp blew them, when i turn up to about 32 volume the subs cut out, they come on and off, amp doesnt go into...
well first off the cap should be reading 14.00 volts not 12 but check on ur settings maybe its to high if that dont work then ur amp or amps is way to powerfull for those sub or theres not enough watts from the amp to the sub causeing the amps to under power the subs but let me no if u got it im all wayz here to help
Apr 04, 2008 | Car Audio & Video
My amp turns on but once you turn the volume up it shuts off
What is happening is an overload situation. If you can use either left or right (white or red) RCA inputs but not both, then the amp is overloading and getting hot internally and probably getting ready to die. You'll need someone to fix the final drivers in the amp.
Hope this helps, and please rate my advice.
Thank you, and good luck!!
Feb 03, 2008 | Eclipse Premium 34230 Car Audio Amplifier
You need to conform that you have a good ground and 12v on the remote & B+ terminals.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Dec 25, 2007 | Eclipse Premium 34230 Car Audio Amplifier
Information on the Eclipse Premium 34230 Car Audio Amp
Specs: 370x2 RMS@ 4 ohm STEREO (the AMP DOES NOT BRIDGE) CLASS A/B (also do not run it 2 ohms unless you like smoke) 0.004% THD @ 4 ohm 105db S/N @ 4 ohm weighted 200 damping factor 11.85" (width) x 2.05" (height) x18.50" (length) 16lbs Worth somewhere is the 200.00 range if it is in really good condition
Jun 03, 2007 | Eclipse Premium 34230 Car Audio Amplifier
Eclipse Premium 34230 Car Audio Amplifier Logo
144 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
