Question about Polaroid i733LP Digital Camera
Polaroid i733lp- green light flashes when i try to turn it on
The batteries ran out during taking a shot and now the barrel is out permanantly and it won't turn on :(
  • 2 more comments
  • Viko Nov 07, 2007
    Hi all,
    Same here, battery whent dead wile taking picture and barrel is out. Camera wont turn on whit new batteries :S
    Thanks,
    Vikosan
  • SteveKincade Nov 17, 2007
    Same here :-(
    Steve
  • janmp Nov 30, 2007
    the barrel was out when taking pictures and even replacing the batteries hasn't helped - the light comes on an occasionally it will make a beeping sound
  • kelli c Dec 06, 2007
    same problem here! Batteries ran out while my daughter was taking a picture and now even with new batteries, the barrel will not go in. The camera will do nothing.
Try changing the batteries to Duracell alkaline...it seems to work. I had a similar problem, now the camera is fine again.
Posted on Dec 20, 2007
  • Hepsi Jan 02, 2008
    THe Polaroid i733 has two battery settings. You can access these by pressing the menu key and selecting set up. You can choose Alkaline or NimH. I suggest Duracell Alkaline. If you are using rechargeables ensure that they are NimH and change the setting to reflect same. That should solve the problem.
Same Here!!! What's going on??
Posted on Dec 17, 2007
Just replaced my batteries and the green light flashed my lens would not come out i held down the power button then thelens came out now the screen wont come up and my camera is off and the lens is out
I have this same camera and had this problem once. Turns out the batteries I used were duds. Try changing out the batteries. I would suggest lithium or rechargeable batteries.
Nov 28, 2010 | Polaroid i733LP Digital Camera
POLAROID SOS
The battery in the film pack may be dead, or the camera is broken. Take the film pack out and replace it. If the camera does not reset then the camera is gone.
Sep 29, 2009 | Polaroid 600 Business Edition Instant...
Polaroid i733
It may be something more serious, but the problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion buildups may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment, clean the contacts at both ends of the batteries, and reinstall them in the camera. Assuming that the batteries are fresh/fully charged, this takes care of about 90% of the startup problems. I hope it works for you.
Sep 07, 2009 | Polaroid i733LP Digital Camera
Camera not coming green light just blinking
Try 4x normal AA batteries. (new)
Also ensure that the memory card cover is firmly closed.
Mar 07, 2009 | Polaroid i733LP Digital Camera
Polaroid i737 battery usage
Change the battery type in the Setup menu to NiMH.
Feb 02, 2009 | Polaroid i733LP Digital Camera
My batteries died in my pink i733 and when it shut down the "zoom lense" did not recede. i put fresh batteries in it but all that happens is that the green light flashes. it wont come on or...
This can sometimes be fixed if you remove the batteries over night and allow the camera to sit and discharge it should correct this problem. hope this helps.
Mar 28, 2008 | Polaroid i733LP Digital Camera
I733 DIGITAL CAMERA WOULNT TURN ON...
my camera started to say the screen said the batteries needed to be replaced can u help ME
Feb 28, 2008 | Polaroid i733LP Digital Camera
Polaroid
try pressing the top button or change the batteries
Sep 02, 2007 | Polaroid i733LP Digital Camera
Polaroid i733 that eats batteries
Sounds like you need to change the camera settings and cut down on turning the camera on and off between shots. Viewing pics on the LCD screen eats up the battery life the most... just an FYI.
Aug 07, 2007 | Polaroid i733LP Digital Camera
Won't turn on! Possible lens problem?
My daughter just had this problem with her camera. The camera was off with the lens barrel extended. When I looked at it closely, I noticed that the inner part of the lens barrel was at a slight angle to the camera. I pushed firmly on the low side of the inner part of the barrel, and it popped the rest of the way out. Camera works fine now. Good luck!
Jun 16, 2007 | Polaroid i733LP Digital Camera
Polaroid i733LP Digital Camera Logo
64 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
