Question about McCulloch Garden
Need better replacement catches for recoil start on McCulloch Eager ****** 2014 ...have gone thru two sets in a season, about 8 hours of use. thanks for your help
    President:
  • 2,220 Answers
Please register your complaint here:
All McCulloch Products
1 (800) 521-8559
HTH
Lou
Posted on Sep 16, 2009
The "pull start" mechanism is
i had the same problem a while back on an old eager ******. i couldnt find anything to fit. try www.ereplacmentparts.com. if they dont have it then i doubt you will find one unless you get lucky and find someone parting one out on ebay.
Jul 14, 2011 | Garden
Whats the part # for the mcculloch chainsaw eager ****** MS 42 recoil spring
YOU CAN HEAT THESE UP WITH A TORCH AND MAKE THEM WORK AGAIN..SEARCH EBAY EAGER ******, THIS GUYS GOT LOTS OF STUFF CLICK HERE TO SEE
CLICK ON THE YES IF I WAS OF HELP .. JAY ..FLORIDA
Jun 13, 2011 | McCulloch Garden
Model 2014 eager ******-- will not start, very weak or no spark
If there is no spark with a new plug, then try dissconecting the earth cut out wire from the ignition unit, this will rule out the switch, or a trapped wire, if still no spark then it will be a replacment ignition unit, part no. 538219848
May 11, 2011 | McCulloch Garden
My McCulloch Eager ****** 2014 chainsaw will start and run for 3-4 seconds then shuts off. What steps should I take to fix this problem.
1. Drain fuel tank - use new gas/oil
2. Replace the "In-tank" fuel filter and possibly the 1/8" fuel line also. This can be bought at any lawn mower repair shop or Home Depot.
3. If problem persists - remove carburetor and clean all passages. There might be a small screen that needs to be cleaned. If you dont tear any gaskets - they can be used again. Just make sure nuts and screws are tight
4. You may need to adjust the High & Low mixture screws by removing their plastic anti-tampering covers - the high speed jet is usually marked "H".
5. Make sure air filter is clean
6. Remove exhaust assembly and clean screen and exhaust port if 1-5 does not work
May 02, 2011 | McCulloch Garden
How to adjust carby settings after rebuilding. McCulloch Eager Be
Turn both jet needles CW to stops (lightly), then back out each CCW 1-1/2 turns. This is a basic setting that should allow the engine to start and run. Start the engine and allow to warm up, then pull throttle full on. Adjust H needle CW until the engine starts to speed up, but continues to 4-stroke. Proper setting is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for better idle, yet allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Aug 01, 2010 | McCulloch Garden
Need an owner manual for mcculloch eager ****** 300s-16 electric chain saw. Already contacted mcculloch and their parent company and the manual is not available from them
You would pay the manual about the price of new saw. These are made in china and usually motor or the switch blows. Check that the voltage pass thru the switch and if so and it dont work, throw it away.
Aug 28, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Eager ****** not so eager when it warms up!
If the chain locks up it may be to tight. Try loosening the chain and see if the same problem happens.
Jun 20, 2009 | Garden
Garden Logo
96 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
