Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Vertical Hight needs adjustment 1 inch,
Need Factory menu sequence,
  • brodiemac Nov 15, 2007
    When I press the volume up and down button on the t.v. to get the serivce menu, nothing happens. The menu doesn't come up.
    An expert whose answer gotĀ voted for 100 times.
  • 317 Answers
Hold vol up and down on tv and serv menu will appear...
Posted on Oct 19, 2007
Vertical Alignment
I would take a good look to make sure it got back together correctly, set does have a hidden adjustment menu once entered the Mitsubishi remote can adjust a lot of things including centering etc, want to be careful in that menu,,,confirm the model and I will give you the four digit enter code for the set.
Aug 27, 2012 | Mitsubishi WS-65315 65" Rear Projection...
Philips magavox model 19pr15
1. To enter the Service Alignment Mode (SAM), press the following key sequence on the remote control transmitter: 0-6-2-5-9-6-Status.
2. From the top level SAM menu, use the Menu Up/Down keys to highlight the Geometry sub menu.
3. Use the Menu Left/Right keys to enter the Geometry sub menu.
4. In the Geometry sub-menu, use the Menu Up/Down buttons to select VAM.
5. Using the Menu Left/Right keys, adjust VSH so that the horizontal bar is properly centered, top to bottom.
6. Using the cursor up/down keys, select VAM from the Geometry sub-menu, and use the Menu Right key to
increase the value to obtain a slight overscan.
7. If other Geometry adjustments are needed, proceed to the necessary adjustment using the Menu Up/Down
8. Upon completion of Geometry adjustments, press the Menu button to return to the top level SAM menu.
9. To exit the Service Alignment Mode, turn the set off with the Power button on the remote control.
Oct 30, 2007 | Philips 19PR19 19" TV
My new LG Flatron E2350 does not fill the 23 inch screen only 22 inches with a black border, have updated graphics and monitor card to the latest. What do I need to do for the graphics to fill the 23 inch...
Similar to TV - you need to adjust the "H" - Horizontal and "V" - Vertical. Horizontal will move picture up or down and Vertical will adjust left to right.
Use the menu button on your monitor.
Apr 03, 2011 | LG Flatron L1515S 15" LCD Monitor
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
With user’s RC 1. Power TV On 2. Press Menu button and call up User OSD Menu 3. Select Sound-> Balance 4. When Balance value is “0”,Enter 0->5->3 ->2 in sequence. Note: If necessary, re-do number keys. 5. Factory OSD appears. 6. Press the standby button then AC turn off and restart the TV, which can exit factory OSD menu.
Jan 21, 2009 | Televison & Video
Rca 14f512t cannot get into service menu
Try this
Switch appliance to Standby.Press VOL(-)
and PR(-) on keyboard for about 8 seconds.
May 18, 2008 | RCA 14F512T 14" TV
Toshiba 32 inch tv made1990
yes,you can adjust it by your remote control,find the service menu and from there you can now adjust the vertical from of your tv.
Oct 30, 2007 | Toshiba 32AF43 32" TV
Full screen on monitor
you can use the menu and adjust the vertical size.or if did already but it doesn't work,try to open your monitor and look for a trimmer in the vertical section,then try to rotate by these you can adjust now the vertical size
Oct 18, 2007 | HP Compaq FS7600 17" CRT Monitor
Vert hight adjustment
How do I adjust the vertical hight of a SANYO 36" TV. vertical height can adjusted by height conrol that is inside tv in your case you can also adjust by remote control. for that you will have to open menu by giving service code. regards thanks
Sep 10, 2007 | Sanyo AVM-3659S 36" TV
JVC Vertical Problem
You need to adjust the vertical height in the Service menu.Press the SLEEP TIMER key and set the SLEEP TIMER for 「0 MIN」. Then press the DISPLAY key and VIDEO STATUS key of the remote control unit at the same time to enter the Service menu.In SERVICE MENU, press the FUNCTION ▼/▲ key to select any of the SUB MENU items. (The letters of the selected items are displayed in yellow.)You want #2 DEF - go to sub-menu and look for the height adj. FUNCTION / key Setting (adjust) the SETTING VALUE of the SETTING ITEM. When the key is released the SETTING VALUE will be stored (memorized). EXIT key Returns to the previous screen.
Aug 22, 2007 | JVC AV-27320 27" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
42 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
