Question about Dell Precision 530 XEON Workstation Dual Processor Capable - DVD-RW (PRECISION5301551218D) PC Desktop
Warning on boot up cooling fan on power supply failure
There are two fan, can see from the back one turns and other doesn't
  • 63 Answers
You have some fan with termal swich, they work only when you comp have high temp. Look that fan when you play the games, they must work some time and stop.
Posted on May 15, 2009
What does the error message C5351 mean on a Konica Minolta Bizhub 200?
Fault Code
C5351
Description
Power Supply Cooling Fan Motor Failure
- The Power Supply Cooling Fan Motor Lock signal remains set to H for a set period of time while the Power Supply Cooling Fan Motor is turning.
- The Power Supply Cooling Fan Motor Lock signal remains set to L for a set period of time while the Power Supply Cooling Fan Motor remains stopped.
Remedy
1 Check the M4 connectors for proper connection, and correct as necessary. 2 Check the fan for possible overload, and correct as necessary. 3 M4 operation check PWB-A PJ33A-1 (REM) D-5 4 Change PU1.
Oct 28, 2016 | Minolta bizhub 200 All-In-One Printer
AVE ERROR CODE 5351 WHAT IS IT?
C5351 Power Supply Cooling Fan Motor Failure The Power Supply Cooling Fan Motor Lock signal remains set to H for a set period of time while the Power Supply Cooling Fan Motor is turning. • The Power Supply Cooling Fan Motor Lock signal remains set to L for a set period of time while the Power Supply Cooling Fan Motor remains stopped.
Aug 26, 2015 | Computers & Internet
Error code 5351
Motor Failure
stopped.
Jul 17, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Hp Designet 500 plotter power supply fan not rotating
Does it show the HP logo at boot up? Does it show an error code? If it boots but fan does not turn then the power supply must be replaced. If it doesn't boot, then the first step is to replace the power supply.
Jun 06, 2011 | HP DesignJet 500ps InkJet Printer
MY PRINTER hp laserget 4250 dtn is displaying 57.4 error when I turned it on, what can I do? I am ofetn requested to suitch off and then to switch on but it fails to mark " Ready"
57.4 Main fan error
Hi I hope this will help
The text come from the hp manual
good luck Ian
Q2431-90912 Chapter 7 Troubleshooting 287
57.X
PRINTER ERROR
To continue turn off then on
or
57.3
EP FAN FAILURE
or
57.4
MAIN FAN FAILURE
A printer fan is not functioning.
X Description
3 EP cartridge fan, right side
(LJ 4300 only)
4 Main cooling fan, left side
Turn the printer off and then on.
57.3 Cartridge fan error (F2)
1. Reconnect the connector
between the fan and the
DC controller PCA
(location J78).
2. Replace the fan. See "Cooling
fan (right side;
HP LaserJet 4300 series
printer only)" on page 170.
3. Replace the
DC controller PCA. See
"DC controller PCA" on
page 181.
57.4 Main fan error (F1)
power supply.
2. Verify that the ribbon cables
are fully seated in the
connectors on the
DC controller PCA.
3. Replace the fan. See "Main
cooling fan (left side)" on
page 168.
4. Replace the power supply.
See "Power supply" on
page 188.
5. Replace the
page 181.
57.7
DUPLEX FAN FAILURE
The cooling fan in the optional
duplexer is not functioning.
1. Turn the printer off and then
on.
2. Replace the duplexer.
Mar 25, 2011 | HP LaserJet 4250dtn Printer
PowerMac G5 Mac Desktop: It will not boot...
Is this a liquid cooled G5? What CPU is it? Need as much info as possible like what where you doing last time it turned on? Have you looked inside the case? Do you hear any clicking when the power cable is connected for the first time? A lot of the last G5's were liquid cooled and a lot have leaked in the past. This small leak eventually ruins the power supply and worse yet ruins the logicboard and CPUs. If you don't know if it is liquid cooled look for a warning stamp on the bottom near front by the CPU fans (inside the case). It states to shut off if liquid is viable (something to that effect). Most times the liquid cannot be seen as it drips into the power supply on the very bottom. I would take it to Apple and have them check it out.
May 17, 2010 | Apple Power Mac G5 Desktop
Computer boot problem
Temporarily swapping-in another power-supply is the first thing to try.
Don't connect the disk-drives, CD/DVD drive, nor 3.5-inch drive.
If the computer "beeps", and shows the POST (Power On Self Test) screen, then changing the power-supply is the solution.
Look at the motherboard -- any "blown" or "bulging" capacitors?
Oct 27, 2009 | ASUS A7N8X-E Deluxe Motherboard
Computer Randomly Cuts off
processor overheating. When it gets too hot it automatically shuts your pc down and boots it back up. Even if the fan is running, it could not be supplying enough cool air anymore.
Jul 27, 2009 | Computers & Internet
Deep freeze computer inresponsive
it sounds like your computer power supply went bad.
go to your local computer store and buy a power supply, install it and you should be up and running.
that is if you didn't fry everything from running it without the proper cooling.
make sure that you have proper cooling fans in your computer, a fan outside will not do it.
It sounds like your power supply fan stopped working and it just got to hot and died
May 24, 2009 | E-Machines eMachines Desktop PC
Dell XPS 400 Card Cage Fan Failure
dell xps 400 pentium d once i turn it on, it beeps and says "card cage fan failure" everytime i press f-1 to continue it shuts off and boot up again it does it everytime how can i fix this CARD CAGE FAN FAILURE??
Apr 22, 2008 | Dell XPS 200 PC Desktop
Computers & Internet Logo
141 people viewed this question
Alun Cox
