Question about GE Heating & Cooling
Will not start, I have checked power supply it is okay, where is the thermal over load on unit,
    Guru:
  • 1,524 Answers
On the compressor.
Posted on May 15, 2009
Kenmorer dishwasher wont start.Lights do not come on.
Of course, theck the power supply the dishwasher is plugged into. The next place to check is the junction box on the bottom of the dishwasher, behind the toe kick panel. If everything is okay there, then it is probably the thermal fuse located inside the door, attached to the dishwasher controller. If you need a new thermal fuse, you can check SearsPartsDirect.com, RepairClinic.com, EasyApplianceParts.com, or AppliancePros.com.
Mar 03, 2015 | Kenmore 24 in. 15932 Built-in Dishwasher
Getting no power to Kenmore Quiet Guard 587-16163401
Of course, theck the power supply the dishwasher is plugged into. The next place to check is the junction box on the bottom of the dishwasher, behind the toe kick panel. If everything is okay there, then it is probably the thermal fuse located inside the door, attached to the dishwasher controller. If you need a new thermal fuse, you can check SearsPartsDirect.com, RepairClinic.com, EasyApplianceParts.com, or AppliancePartsPros.com.
Aug 16, 2012 | Kenmore Dishwashers
PE1800 server didn't start up at all, no green light in Power supply
Check and see that the power suply cables are properly connected to the power supply and that there is voltage on the Mains. If this is okay, replace the power supply unit.
Jun 30, 2011 | Dell PowerEdge 1800 Server
My Whirpool dryer stopped working after I just finished a load and tried to start the next one. The power source is working and the vent is not clogged. Where do I locate the belt?
If it's not working at all, the first thing to check is power. You should have a dipole 30 amp breaker and you have to make sure that both legs are hot going to the machine. Remember that it's possible for the breaker to appear to be okay but one leg has tripped. Inside the unit you need to be able to check for continuity on the thermal fuse(s) and across the heating element. The door switch could have failed as well, which would not allow it to tumble or heat.
Dec 02, 2010 | Whirlpool Dryers
My Hobart 250 airforce doesn't start
On the main circuit board for the power supply, there is usually a thermal fuse installed, its a sealed unit and is not servicible, look for a black epoxied case,approx 3/8x3/4 long, with 2 leads coming out of it. Inside is a set of bi-metal contact points which serves as an over voltage/over current protection. These contacts deform/corode over time and it sounds like there not contacting properly. As soon as you try to load the machine, the current passing through this high resistance heats these contacts up, and shuts off power to the unit. I am not familiar with the guts of a hypertherm, but have extensive experiance repairing inverter based plasma cutting equipment, and i have encountered this before. I assume hypertherm must have some equivelent to this thermal switch inside the power supply.....Good luck..
Dec 29, 2009 | Miller Hobart AirForce 250A Plasma Cutter ...
I REPALCED THE TIMER CONTROL AND MY DRYER WILL
Always check to make sure you have power at the unit. If power is present and you replaced the timer control there is something else causing your unit not to fire up. I will assume your unit is an electric dryer. Before you check anything inside the dryer make sure your power cord is unplugged. Then check the door switch for continuity. If the door switch test okay then check the thermal fuse located on the blower assembly. Remove one lead and test for continuity, if okay then check the upper limit on the heating box. Again, this is a continuity check and again remove one of the leads before you check for continuity.
Sep 15, 2009 | Dryers
Kenmore 90 series elec dryer,replaced heating element, checked the thermal fuse, its okay, still no heat, dryer still tumbles,. air is being forced, running out of ideas...
Several things to check. Be sure you have the correct voltage to the unit.
Since this is an electrical heated device, it is loaded with safety switches. There is sometimes a thermal overload,or clix-on bimetal device in the exhaust inside the rear of the unit. If your exhaust becomes restricted, it will take the heater out of the circuit. If you do not have enough air flow, the element would burn up/ out. I would look around again as I'm sure there are other safety devices as the one I mentioned as well as one near the element to prevent overheating.
The timer is also responsible for sending power to the element as well as the motor.
Good Luck and hope this helps.
Mar 10, 2009 | Roper RES7646KQ Electric Dryer
I have an 1984 rudd 75,000btu forced hot air unit with pilot light, while cleaning unit an electrical connector broke off ! it looks like a blue plastic wing-nut, and It has 2 large black wires that go to...
The simple diagram for that specific problem it connected series to thermal cut off sensor.
The two black wires, One came from a power supply line (it means an active power
and the other one goes to the load motor) If you shorted it connection it will run the motor.
But it bypass the sensor.
Unplug the power then try to fix the both end of that black wire connected to terminal bolt of your thermal sensor by replacing the broken plastic nut with a new one.
Fit the nut thight to avoid electrical arch while giving power on at the start.
r_ic7
Nov 29, 2008 | Heating & Cooling
Asus A8N SLI DELUXE MOTHERBOARD AMD PROCESSOR
When you reinstalled the processor, did you put thermal compound on it? Not putting thermal compound on an AMD processor could burn it. I've tried this before, thinking it was okay since i tried an Intel not placing any thermal compound, and there was burning smell on the AMD processor. If the problem before was the power supply, you might also want to check the motherboard. Defective power supplies destroy the motherboard as well. You may also want to check the if the power button was placed back to its pins. You may have missed that or the wire might have come loose.
Sep 13, 2008 | ASUS Computers & Internet
"No Power"
I've never known anyone that has "just changed a fuse" in a HP and have it spring back to life, I do know if a fuser or thermal fuse go you would still have display, I would check the switch, display connections then maybe pull the power supply out and check for damage, but in reality if got down to power supply one would write it off.
The fuser not coming on isn't a problem, missing supply voltages from power supply seem more likely.Check if fan powers on at start up.
Nov 17, 2007 | HP LaserJet 5m Printer
Heating & Cooling Logo
80 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
