Question about Compaq Presario 700 470024-192 Notebook
Window XP drivers
I can detect wifi but cant online device manager show that my ethernet controller got problem
Internet both WLAN and ethernet
You will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a Red
X or a yellow Exclamation or Question mark !?
you will need to update or install the driver or it could be firewalled.
If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc
click start control panel administrive tools computer management device manager scroll to network adapters could see a yellow question / exclamation mark? ! or a red X right click install drivers
You only need to do the following if you cant install the driver
Make sure you Ethernet/internet is enabled in biosRestart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) usually the Delete or F2 key press and hold that key to enter bios using arrow keys scroll to intergrated peripherals.
Look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press ENTER make sure its enabled
wifi
Most new laptops are equipped with all the components necessary to go online wirelessly to account for the increasing popularity of Wi-Fi Internet.
If you find that you are not able to connect to any wireless networks on a laptop, take a few basic troubleshooting steps on your own before having the laptop serviced.
In all likelihood, you will be able to restore your laptop's wireless functionality and be browsing Wi-Fi Internet in no time.
Enable the wireless card by pressing the radio button, typically located near the top of the keyboard.
Press the radio button until a light illuminates indicating that your wireless card has been enabled and is ready to go online wirelessly.
Test your connectivity once again; if there is still no wireless access, it is time to check for a possible issue with your wireless card.
Navigate to the computer's device manager by opening the "Start" menu and either clicking "Device Manager" from the "Control Panel" window or right-clicking "My Computer," clicking "Properties," and choosing "Device Manager" from the "Hardware" tab, depending on what version of operating system you use.
Look for the wireless card in the Device Manager by clicking the "+" next to "Network Adapters." If you see any item labeled "Wireless Card" or "Wireless Controller," check to see if it has a "?," "X," "!" placed over the name; if it does, you will need to update the software drivers for the wireless card. Contact the manufacturer of the computer for assistance.
Attempt to connect a wireless network other than your home network. Make sure you connect to a wireless network that you are legally allowed to use, such as a free public Wi-Fi hotspot, and that you are not illegally connecting to someone else's wireless network.
If you can connect to other Wi-Fi networks, the problem is likely isolated to your home network and you will need to troubleshoot that.
If you are still can't connect to any Wi-Fi networks after following the steps above, you may need to have the laptop serviced or have its wireless card replaced.
Mar 10, 2014 | Computers & Internet
No drivers for wifi
hi....
in order to install drivers for your hardware,you can follow 2 ways:
1.USING DEVICE MANAGER:
  1. Click on Start and then Control Panel.
  2. Click on the Performance and Maintenance link. Note: If you're viewing the Classic View of Control Panel, you won't see this link. Simple double-click on the System icon and proceed to Step 4.
  3. In the Performance and Maintenance window, click on the System icon near the bottom of the window.
  4. In the System Properties window, click on the Hardware tab.
  5. With the Hardware tab selected, click on the Device Manager button.
  6. In Device Manager,Look For Network Adapters Or Something Similar(i dunno for sure as i have a win 7 notebook)
  7. Double-Click It And You Will See Your Wireless Hardware And Some Other Items(Look At The Image)
8.Double-Click On Each One Of Them One At A Time.A Window Will Open
9.In The Video Go To Drivers Tab And Click Update Driver. 06b21539-8b78-4b49-ba89-48e19e957172.png
10.Another Window Will Open.Now Do As In The images Below(Look For Similar Options In Your Windows)
IF THERE IS NO SUCH OPTION,THEN YOU NEED TO LOOK UP THE NAMES OF YOUR 'NETWORK ADAPTERS' YOURSELF ON THE INTERNET AND DOWNLOAD DRIVERS FOR IT ONLINE.YOU CAN LOOK FOR DRIVERS AT YOUR NOTEBOOK MANUFACTURERS WEBSITLE .
And I Am New So If There Is Any Option That You Like My Response,Please Do It.............Have A Nice Day
Jan 11, 2014 | Systemax Computers & Internet
Afer i reformat my lenevo 3000 g430 i can't connect anymore to a wifi connection
Hi Welcome to FixYa!
Have you already installed the drivers for your computer? If not yet, it could be the reason why you are not able to use your wifi. Follow these steps so that you could know what to do next:
1)check the device manager in Windows: A)if you are using Windows 7 or Vista: -click on Start, then on the searchbox, kindly search for Device Manager and open it. You should have something like this: mondimondz_1.png
B)if you are using Windows XP: click on start>run>type devmgmt.msc and it will open the device manager Window.
2)If you will find a category that says Other Devices, kindly look for a item that says "Network Controller" if you find it, it means that the Wifi adapter on the comptuer is not yet installed. All you need to do is insert the drivers disc CD if one came with the computer when you bought it. If not, you could try connecting the laptop to the modem directly using a cable and download the driver from Lenovo's support website: www.support.lenovo.com
3)If you still cannot connect with a direct connection, the Ethernet adapter could have been not yet installed also. You could also check it on the Device Manager window and look for Ethernet Controller under Other Devices. or check the category Network Adapters and see if the Ethernet Adapter is installed.
4)if the drivers are already installed, you can try contacting your Internet Provider or call Lenovo's Technical Support Team.
hope this would be a big help!
Jun 14, 2011 | Lenovo Computers & Internet
Motherboard P4i65GV ASROCK. Installed WIN XP service pack 2 , ethernet controller is not installed shows exclamation mark in device manager.Unable to connect to net.
you must ethernet controller driver first
goto device manager, right click at exclamation mark, then chose update driver, follow instuction step by step, if it ask for cd driver insert motherboard cd driver, if you did not have cd driver download ethernet controller here
http://www.asrock.com/MB/download.asp?Model=P4i65GV&o=XP
wait until process finish and exclamation mark at device manager disappear, and try to connect your computer to internet
i hope this helpful
thank you for using fixya
Feb 02, 2011 | Asrock P4i65GV Motherboard
Hi.. i reformatted one of my pc with intel pentium d and mobo "msi pm8m3-v"... the problem is, i lost the driver cd... so i searched the internet and found drivers.. vga, raid, audio and stuffs.....
Keep doing what youre doing and put it on the USB drive its the only way really. If a driver is not an EXE file you need to go into device manager right click on the unknown device and click update driver. Choose the option to let you choose not automatic and browse to the folder your driver is then install it. cheers from Scott and plz vote
Nov 02, 2010 | Computers & Internet
Problem with a Toshiba Satelite L45 s7423 Model my os is Windows 7. I recently got this laptop as a present from a friend since he formated it.....when I got it everything worked except the ethernet cable...
windows 7 automatically install all the drivers in case it had missed the driver kindly download the driver from friend system or internet cafe on your usb drive.
there is link to download drivers for Ethernet.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
once your your online go to computer management > drivers and right click on WIFI card and click on update drivers it will download the drivers and install the drivers.
Jun 07, 2010 | Computers & Internet
Same BS wifi problem as everyone else
Have you tried restoring the computer back a couple of days to see if that clears up the hardware hiccup? You can also go to device manager and uninstall the device and delete the drivers. Turn the laptop off, take the wireless card out. Start the laptop back up and boot it fully....After a few, shut down again. Install the wireless card and restart the laptop. When asked to install the drivers for new device found, say ok, make sure you are online with an ethernet line so windows can go online and load the newest drivers unless you have them on your C drive already.
Aug 30, 2009 | HP Compaq Presario F730US Notebook
Network Adapter/Ethernet Controller
Nothing wrong with having two network adapters installed on your computer. If you have this DWA-552 wireless adapter installed as well as an onboard NIC, the correct thing to do is have both drivers installed so you see them both in your Control Panel->Network Connections window.
If you really want the onboard nic to go away, go into device manager and disable it - not uninstall it.
Mar 08, 2009 | Computers & Internet
My acer extensa 5220 laptop WiFi not working; device manager shows Ethernet controller need software, "Found new hardware" notification sometimes apear
You should download a wifi card driver and install it from this location:
http://www.laptops-drivers.com/acer-notebooks/download-acer-extensa-5220-for-windows-xp.html
Jan 09, 2009 | Computers & Internet
Compaq Presario 700 470024-192 Notebook Logo
191 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
