Question about Sony Cyber-shot DSC-W55 Digital Camera
Converting internal memory to memory stick
I have a Sony Cybershot, and I have pictures that are stored on internal memory is there a way to transfer them or copy them to my memory stick?
  • 10,594 Answers
Put memory stick in camera, power up, press Menu >> Copy >> OK
That will copy internal memory pictures on memory stick.
Posted on May 15, 2009
How to transfer internal memory pictures on a DSCW70
Unlike most brands/ models of cameras, the Sony CyberShot (DSC) cameras feature internal memories, (not enough to hold sufficient data). If you took a few shots before inserting the memory card, the pictures are stored in the internal memory. You can transfer/ delete those pictures by the following steps.
1. switch off the camera,
2 open the battery/ SD card slot cover and remove the SD card.
3. close the cover and switch on
4. press the display/ preview button and your picture should be visible on the screen.
You can now do whatever you want with your picture.
Does this help? Please provide some feed-back if my answers do help.
Sep 09, 2014 | Sony Cyber-shot DSC-W70 Digital Camera
Remove the internal memory card
You don't need to remove the internal memory. Simply insert the memory stick, and the camera will store new images and videos to the stick instead of the internal memory.
Jul 24, 2012 | Sony Cameras
Is it possible to transfer the photos I took on my Cybershot camera onto my memory stick?
To copy the images from the Internal Memory of the Camera to the Memory Stick select the COPY option from the Memory Stick Tool Menu of the Camera to OK.
To select the Copy option, press MENU-->SETUP-->MEMORY STICK TOOL-->COPY-->OK.
The copy option will copy all the images in the Internal Memory to the Memory Stick in the Camera.
Thanks for using FixYa
KenSolutions
Dec 06, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
How do i tranfer pictures from internal to the memory stick on a sony w55 cybershot
Firstly go to Menu and select the appropriate files of pics that you want transferred. Then from the menu select Move. Then specify where you want them moved, ie, the memory card. And the files would be transferred to the memory card and removed from the camera memory. Also, you must set the camera such that in future it stores all pics to the memory card itself.
Dec 14, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Recently purchased Sony Cybershot DSCW180. Took 3
Yes, you need to have memory stick because camera has limited internal memory that can store few pictures only.
Put new memory card, format it through camera Menu and copy internal memory pictures to memory stick, take our memory card from camera and delete internal memory pictures either one by one or format internal memory through camera Menu.
Thanks.
Dec 02, 2009 | Sony Cybershot DSC-S950 Digital Camera
How do you upload pictures on the internal memory?
If you normally upload your pictures by connecting via the USB port, remove the memory stick before connecting the camera to the computer. If you normally upload your pictures by putting the memory stick into a card reader, use the camera's memory stick tool to copy the pictures from internal memory to memory stick.
Nov 15, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Problems with my Sony Cybershot W210
1) Make sure that you're not using more than 4 GB memory stick pro duo with the camera. Then try to remove the memory stick and capture 2 images in the internal memory and turn OFF and turn ON the Camera and check. If the error message comes, its the issue with the Camera itself and requires service after resetting. to reset the Camera, select Initialize under Main Settings 1 menu under Settings. if the issue persists, the camera may require service
If its working fine, transfer all the images to the Computer and format the memory stick. Formatting will delete all the contents. If the issue persists, memory stick should be replaced.
Sep 21, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Took pictures with sony cybershot DSC-100 and then realized I did not have the memory stick in there. How do I get the pictures out of the camera and either onto the stick or computer? Thanks.
Please inster memory card in camera, power it up and go to Menu>>Copy>>OK
That will copy pictures from internal memory to memory card.
Apr 03, 2009 | Sony Cameras
Unable to load pics from cam to pc
i think your memory stick create problem,put out your memory from the camera , and take some picture on your camera s internal memory and than connect it to your pc
Feb 22, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Auto delete
If you are refering to the pictures you took on the camera before you put in the memory stick, then you took those pictures on the internal camera memory. the camera is set to default on the memory card whenever one is in. To get to the pictures on the internal memory, remove the memory stick and you should be able to view the pictures. To transfer those pictures to your computer follow the steps in the manual, just be sure not to have the memory stick in.
Dec 23, 2007 | Sony Cybershot S650 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
277 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
