Question about Acer Aspire 9500 Notebook
Internet explorer icon will not open error message pops up
I can connect to the internet provider but cant open icon for explorer
I have upgraded from MS windows 8 to 8.1 Now I have lost my internet connection. The router is working fine
Sounds like your WiFi isn't connected. Pop the charms bar out of the right hand side by putting the mouse in the upper right hand corner, and go to settings.look for the WiFi icon, click it, is it connected?
Nov 30, 2013 | 2wire 2700HG-B Router (2700HGB)
Face book error message 'big_pipe' is null or not an object
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to assist you with your problem. You are receiving an error message stating "'big_pipe' is null or not an object". This means that the 'big_pipe' phrase is being ignored. To try to solve this problem, you will need to open the developer tools. To do this, click Tools and then click F12 Developer Tools (you can also press F12 on your keyboard). Click the script tab and switch to your Internet Explorer window. Click the error message icon and look at the URI (Universal Research Identifier), compare it on your developer tools window and check the URI button to make sure it has the same address. If it doesn't, click that button and find the correct address (the button has an address with a down arrow beside it). Use the scroll buttons on the screen to find the 'big_pipe' phrase. Click Start Debugging. A message will pop-up on your screen stating that the webpage needs to be refreshed; click Okay. If the solution was successful, you shouldn't see the error icon at the bottom of the window. Hopefully this will solve your problem.
Jul 03, 2011 | Microsoft Internet Explorer 8
Why i cant open internet explorer
When you click the Internet Explorer icon, window may flash a second and quits. Or, it may show an Error-Reporting dialog. This may be due to a malware Browser Helper Object which causes Internet Explorer process to terminate. If you see the Error-Reporting dialog, click "to see what data this report contains" and identify the Module Name causing this error. In most cases, it may be the malware DLL; in which case, reinstalling Internet Explorer may not help.
1. Click Start, point to Settings, and then click Control Panel.
2. Double-click Internet Options.
3. Click the Advanced tab.
4. Under Browsing, clear the Enable third-party browser extensions (requires restart) check box.
5. Restart Internet Explorer.
Download Ad-Aware from www.lavasoftusa.com and follow this:
1. Start Ad-Aware.
2. Click "Check for Updates", "Connect" and download the latest pattern file if available. and click Finish
3. Click "Start", "Next"
4. After the scan is finished, click "Next"
5. Select all the items (checkboxes)
Right click on any object in the "Scan result" list and choose [Select all objects]
6. Click Next and click OK to confirm removal.
Jun 23, 2011 | Computers & Internet
Sometimes when I click on the Internet Explorer icon, and error message appears in front of a blank web page. The error message says "Internet Explorer has stopped working. Click to close program". When...
Try a scan with your virus scan, then with a malware scanner, i use Malwarebytes.
I would then use CCleaner, use the registry cleaner also.
This will clean out all your temp files, and remove any registry errors that may be causing IE from starting properly.
You could also use Firefox, or chrome as your browser if this does not fix it
Sep 05, 2010 | Microsoft Internet Explorer 8
My browser will not connect to the internet
Do you have any other internet enabled applications that are connecting properly? If you do have other internet enabled apps and they too are having problems than I would suggest trouble shooting your network connections.
If you are running Windows XP go "Control Panel" and under "PIck a Category" select "Network and Internet Connections". Next select "Network Connections". Right click your network connection and select "Repair". Windows will attempt to repair your network drivers, settings, and reestablish your network connection. If unsuccessful it will attempt provide an error message describing the problem.
If you don't see that option start checking connections along your network cable wiring. A plug may have come out or a cable damaged.
If it is not your network connection or your wiring it is your browser software. Reset your browser back to default settings to repair any changes made by accident by yourself or perhaps a website attempting a browser hijack:
Reset Internet Explorer to the default settings To reset Internet Explorer to the default settings
  1. Close any Internet Explorer or Windows Explorer windows that are currently open.
  2. Open Internet Explorer.
  3. Click the Tools button, and then click Internet Options.
  4. Click the Advanced tab, and then click Reset.
  5. Select the Delete personal settings check box if you would like to remove browsing history, search providers, Accelerators, home pages, and InPrivate Filtering data.
  6. In the Reset Internet Explorer Settings dialog box, click Reset.
  7. When Internet Explorer finishes restoring the settings, click Close, and then click OK.
  8. Close Internet Explorer. Your changes will take effect the next time you open Internet Explorer.
Hope this helped.
Feb 05, 2010 | Acer Computers & Internet
When i try to open facebook mindjolt bouncing
why you are getting this issue means because of the internet explorer.
>please go ahead and uninstall the internet explorer 8.0 from the add/remove programs
>restart the computer
>then the internet explorer 7.0 will open by default
>now try to access the facebook and the issue will get fixed.
------------All the best-------------------
Nov 18, 2009 | Microsoft Internet Explorer 8
Internet connection
most of the time internet explorer is by default brouser available in window when u install the mozila at end end of instalation process a message comes that take settings from internet explorer u have to click on yes option.
or
u can direct see the connection property or lan seting from internet explorer and copy it in mozila connection setting
Mar 05, 2009 | ASUS Eee PC 2G Surf Notebook
HELP!!
hi my friend
i've seen the problem before and the fix for this issue is just to update the windows explorer thats all what you need to do
so if you have internet explorer 6 (and thats the main one thats making the issue) update it to internet explorer 7 and everything will be back to normal.
dont forget to rate my answer
cheers
Nov 07, 2008 | Yahoo Messenger
Lavasoft adaware problem
Are all you icons at the desktop also gone and are now links but will not open?
If yes pls post back that we can provide you with the solution.
Kind regards.
Feb 13, 2008 | Computers & Internet
Acer Aspire 9500 Notebook Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
