Question about Uniflame 2158 Smoker
I lit my bbq and only got small blue flames, all three burners.
So I disconnected the tank, and no gas would come out. It felt like it had gas in it, it is a 7 gallon tank. So I took it to get filled, and it only took 3 gallons. Used it one time, and now gas will not come out again. There is gas in it as I turned the screw on the side and got pressure.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 06, 2010
BBQ does not get hot enough to cook properly. All gas jets are clean as BBQ is almost new
blue flame? if flame is not blue, then air gap needs adjusting. if blue flame and burner control is on high, then could be your regulator. (assuming tank if full)
Apr 17, 2015 | Grilling
Gas bbq
flame running back is an indication of insufficient gas pressure or flow. check and adjust the regulator and ensure that there is no blockage in the jets.
May 14, 2013 | Grilling
BBQ won't get hot enough. What can I do? There is plenty of propane. Pete
I suspect the problem, is a result of either dirty and/or clogged burners and venturi valves (part of the burner). Or the grills gas regulator is partially locked close.
Since the regulator problem does not involve any real dismantling of the grill, I'll start with that solution first.
1. Turn the gas valve on the tank OFF. Remove the grill grates and flame tamers, so that you
clearly see all the burners.
2. Disconnect the hose from the tank and wait 5 minutes.
3, Reconnect the hose to the tank and turn the tank valve ON, VERY, VERY SLOWLY (Slow
Motion, slow).
4. Once he tank valve is fully open, light the burner farthest from the tank first and turn the burner
knob to HIGH. Dose the flame height look correct? If so, light the remaining burners the same
way, until are are lit and burning. Do all the flame heights look correct when set on HIGH? If so,
you solved the problem.
If the above did not solve the problem, you will need to replace the grill's Hose/Regulator Assembly. You can purchase one from any home center or hardware store that sells gas grills and accessories. They run about $30.00. Take you old one with you for comparison purposes.
Hope this helped you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 17, 2011 | BroilKing Grilling
Connecting Reddy HD30 to RV Propane Tank
pipe feed could be too small poor flow of gas or flamesafety is cutting in
May 26, 2010 | Reddy HD30 Heater
Won't stay lit .. I try lighting the 3 burner bbq with ignitor, flames for about 10 seconds then goes out. Age is approx 2 years old
it may need a clean or something blocking the gas flow on that burner it could be a spider web or a ant inside the orifice
Apr 25, 2010 | Fiesta Blue Ember Gas Grill
Weber grill three burner. New tank of propane but
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Mar 29, 2010 | Weber Genesis Silver B Grill
Weber Silver BBQ has 3 burners only 1 has normal flame.
you may have to remove the burners and clean the inside of them. they could have insect webs inside preventing the flow of gas. hope this helps. also, try opening the tank really slowly.
Oct 12, 2009 | Weber Grilling
Weber gas bbq
Hello stevie66, disconnect the gas tank, carefully remove the burner element (the thing with the small holes) and soak it in a bowl of vinegar overnight. Remove and shack the excess out, remount and connect the gas. Open the gas line about 1/4 turn and CAREFULLY LIGHT. Please E-Mail the results. Thank you.
Oct 26, 2008 | Grilling
No gas getting to bbq
I switched to the new style 20# tank with the new turn-on knob.  I couldn't get enough gas pressure to the BBQ burners for all three burners to light or to keep a strong flame on even one burner.  The new style tanks have a safety valve on the inside of the tank that shuts the gas off if you turn the knob on too fast because the safety valve thinks there is leak.  Shut everything off and then try turning the knob on real slow, especially at first, before turning it all the way on.  If that doesn't work (it didn't for me), then replace the large plastic connection valve knob (female end) that attaches the regulator to the tank.  Mine was for the old style tank and was black (low pressure).  I went to a propane company and had them replace it with a green knob (higher pressure).  Took it home and WALA!  Everything works fine now.  But it was very frustrating trying to figure why I couldn't get any gas to the burners after buying a brand new tank.  I hope this helps solve your problems.
Sep 15, 2008 | BBQ Guys BBQ400C/G42 Grill
Flame on gas grill is too small
From: http://bbq.about.com/cs/replacementparts/a/aa071100a_3.htm
Symptoms and Solutions Low Flame: The grill just doesn't want to heat up. This can be cause by several things. Taking it from the fuel source to the flame, lets start with the burner. Newer propane tanks contain a self regulating feature that will automatically slow down the flow of fuel if it thinks it's too high. This can be solved by turning the tank valve off completely and disconnecting it. Open the control valves (on the grill control panel) and ten close them. Reconnect the fuel tank and slowly turn on the valve. Now light the grill to see if that fixes it. Otherwise check the control valve(s) and venturi tubes for obstruction and alignment. Make sure that the flow of fuel is continuous. Check the burner for clogged gas holes. You can usually see this problem by observing how the grill burns. If there are spots without flame then you probably have a clogged burner.
Oct 28, 2007 | Patio Classic Barbecue Bucket Grill
Uniflame 2158 Smoker Logo
111 people viewed this question
Top Uniflame Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Bill Boyd
Are you an Uniflame Grilling Expert? Answer questions, earn points and help others
