Water Heaters Logo
Posted on May 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Baxi solo 2 30pf will not fire up.. please help!
2 weeks ago my boiler would fire up for about 2 mins then cut off. Now it does not fire up at all. during this time I have had two different plumbers round who have changed various parts... PCB board x 2, fan, air pressure switch, water pump and motorised 3 port valve head... luckily I can get these parts at cost but still now getting expensive! What else is left???
The boiler and pilot light is on when calling for heat. Does anyone have any suggestions as to what else could be causing the problem?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2015
Points
First off ensure water is getting to boiler, next, No pilot = pressure switch. On my baxi solo 40 pf pressure switch is replaced 8-10 times a year cures your problems,,,,,,,, momentarily , and have had all your other parts,but with no effect to speak of,.......sorry............ solution = [ change boiler ].sounds like gas pressure or lack of water to system or **** boiler like mine .........good luck.
Ned C Cook
Level 3:
President:
  • Master 3,433 Answers
  • Posted on May 18, 2009
Ned C Cook
Master
Level 3:
President:
Answers
3433
Questions
0
Helped
1436834
Points
9966
Try a thermocoupler? If so equiped.
crazyfach
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on May 23, 2010
crazyfach
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
2269
Points
5
Could be a faulty overheat stat , i think thy are an auto reset type on these boilers
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1883
Points
Plumbers are great, but they are there to supply the water...
try having a skilled and knowledgeable gas tech come and check your system. Not 100% sure on this model, but is there is a motorized valve you are using it for heating as well, or the option is there... i might be a faulty flow switch or there could be a small bypass is your hot to cold valves,,, meaning not enough flow going though the unit activating the flow switch, this is where the plumber is used....
hard to say with out seeing the unit, but try a gas tech that is what they do not a plumber
Have a Baxi solo boiler 340PF, have hot water but no heating, pilot light will not stay on. how do I fix it so I get heating please?
it might be the thermal coupler....it is a piece of wire that goes from the pilot to the thermostat. very inexpensive. .I am a 50 yr old woman, and I changed mine on my furnace twice..Home Depot or equivalent should be able to help. Google "thermal coupler"
1helpful
Boiler not working
When the fan stops working it also stops the boiler. Safety.
Check that the fan is turning and blowing air out. You can hear it turning at the top of the boiler and at the vent pipe exit.
With the electrics off, remove front cover and test the fan by moving the blades by hand. Any element of stiffness or jerking or if the fan does not turn freely - replace. These have an induction motor - no repair
Check the electrical contact wires to fan are ok. If the fan is ok check also the 2 plastic tubes to & from the air pressure unit [usually close to one side of the fan] are intact [no splits or holes and will maintain pressure and vacuum] and fully connected to their metal terminals.
Next is to examine the pcb (the electronic board behind the switches) Look for any block connections loose and any obvious signs of black marks on the board. If the latter, replace
My boiler(baxi luna HT330) keeps going into E1 fault mode.
After you pressure system do you bleed the rads then top up again .
Overheating
you could have a flow problem due to sludge or scale in the boiler, it could be a pump problem as it may not be circulating enough water around the system. or it could be a faulty thermostat if it is not cutting out soon enough.
1st try turning the boiler stat down to its minimum, if it still over heats then it is probably the stat.
if you have a switch on your pump to increase the speed make sure it is on setting 3. if the pump is old then it may be time for a replacement.
Manual for Baxi Boiler
any merchant will get one mailed out to you
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
3helpful
2answers
Locating pump on Baxi Back Boiler
hi this problem sounds like a pump problem. now if its not in the airing cupboard, sometimes they can be besides the boiler in a cupboard or under the floor where the boiler is sited, or boxed in in a dummy casing either side of the boiler/fire unit.
i suspectthatthe pump is stuck & needs releasing or worse case scenario a new unit fitted.
The reason you mentioned about frequently getting air in the system is condusive of sludge build up or the pipe-work configuration is not installed correctly giving rise to air being drawn into the system & posing future probs such as component failure.
If the pump is sited under the floor by the boiler it is at risk of collecting sludge as its at the lowest point in the system.
Recommendations re-site the pump if possible & look to have the system power flushed, to assist the life expectancy of the system
Kindly
Richie
Top Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Water Heater Expert? Answer questions, earn points and help others
