Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
The trigger on webley vulcan rifle sticks in the fired position.
This is a british made air rifle about twenty years old.
I do not know any retailers in s. bucks. putting name on the internet
does not get a response.
Sounds like a broken/displaced spring .. T C Chambers Gunsmiths are good for replacement parts
Posted on Jul 05, 2009
On webley 928. Breaking gun ( empty) open the extractors work fine. But following shooting and then breaking open the left extractor never works.
The barrel selector sounds like it is not engaging correctly to the switch over of trigger to firing pin for the second shot if you don't get it repaired it may get worse and go off when unexpected
Jan 29, 2017 | Air Tools & Compressors
How to refit triger on webley xocet air riffle 2"2"
I believe this is the manual: http://www.webleyandscott.com/shop/userfiles/Airguns/Rifles%20PDFs/Stingray/A5_STING_XOCET_OWNERS_MAN.pdf
On page 14 of the manual there is a section entitled MAJOR OVERHAUL OR REPAIR. I do not know enough about airsoft to be of any more assistance. Good luck.
Oct 05, 2014 | Air Tools & Compressors
Trigger problem on my Yugoslavian SKS rifle. when the bolt and carrier are locked in the firing position it pushes down the pin on the trigger group and the hammer will not fire. If you pull the bolt...
I'm having trouble visualizing which pin (firing pin???) you're talking about. How sure are you that the rifle has been reassembled correctly? Could you post a picture so we can see how it's assembled? One shot (no pun) of the assembled trigger group would be good, then another shot of the bolt & carrier.
Aug 07, 2014 | Optics
Weihrauch air rifle will not ****.
Sounds like your sear is broken.
Mar 13, 2014 | Optics
I have a 'used' Beeman Sportsman 1000 Series rifle (no scope). Have a pellet in the rifle (it's been in there for about a year, heh), I'm moving the lever-near-trigger back and forth but rifle won't shoot...
If your pumping the rifle and you hear air seeping out then the seal on your air chamber is bad or got pushed from where it is suppose to be, you can take it apart and see, its real simple...
Aug 03, 2013 | Beeman SS1000T Sportsmans Series .177...
I have a Bostitch N80S stick framing nailer that leaks air from the trigger area. I replaced the entire trigger valve with a new single fire trigger to see if the old bump fire trigger was the problem
Remove the nails and take off the trigger to expose the trigger valve (usually part # tva6). Connect air and spray soapy water on the valve to determine if the air is leaking from the center of the valve or around the outer edge between the body and valve. If leaking from the center, could be defective valve or debris under oring. Pop out the valve and examine internal parts for cut oring or defect. If leaking from between body, you could have cut orings installing the valve. Make sure that there are no rough edges in the body of the gun. Bump fire or single fire happens with the trigger type not the valve. Bump fire trigger is usually black metal and single fire trigger is light color plastic. Good luck
Apr 10, 2013 | Stanley Bostitch Nail Gun
Crossman Sierra Pro Air rifle
If the trigger is adjustable set it more coarse to hook the piston rod. Make sure trigger is loose and will reset to it foremost position. Check trigger spring and pin for ease op operation. Lastly check if piston rod did not turn inside cylinder so hook is turned away from trigger.
Feb 08, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Refrigerators Logo
296 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
