Question about Whirlpool Duet GHW9150P Front Load Washer
When i wash colored shirts I notice spots that were not there
I have to re-wash with the spray and wash stick
  • 51 Answers
Your using to much detergent, should be using HE type, an only a teaspoom full. an wash on cold/cold water
Posted on May 16, 2009
My HE top load Kenmore is staining all of my dress shirts. from small little spots to large massive areas. I am wondering what it is. I have ruined about 50 shirts so far. Could it be the soap?
If they were all in the same load, something must have fallen into/got mixed with the load, such as ink pen, etc. Full washer with hot water and add cleaning agent such as ammonia or plain detergent to clean the washer cycle.
To clean those shirts, add a 1/4 c of "Simply Green" / The Green Stuff ($ store brand) to temp appropriate water, directly spray on spots and let soak a few minutes, then wash (with or without detergent) and do a double rinse cycle. Naptha or Zote laundry BAR soap are good as "detergent". HTH
Mar 06, 2014 | managemylife.com
How do i set color on tie dyed t-shirt? color is running each time i try washing it
my mam told me to steep them in salty water before puting into wash old wives tail but it worked for me but most home dyed stuff the colour will run hope this helps ivan
Sep 28, 2012 | Washing Machines
Hi, can you teach me on how to use jobos dye. Appreciate if you could the complete step by step... Thanks
For this project, we will be making a basic sunburst design on a t-shirt.
  1. First, wash the -shirt in order to remove any possible dirt and prepare it for dye absorption. Tie-dying is best done on damp fabric.
  2. Cover our work area with newspaper to protect it from any spills, and assemble all your tools.
  3. Wear rubber gloves to prepare the dye. Carefully follow the manufacturer's instructions provided on the package.
  4. Our particular fabric dye, Venus, for example, calls for the powder to be dissolved in boiling water to get the best, fastest results possible. So fill the large container with lukewarm water, bring to boil, and pour in the dye, starting with the lightest color if you are using more than one color.
  5. While the water is coming on a boil, lay the t-shirt flat on your work area. Grab the center of the t-shirt with your thumb and index finger, and lift it up. Run your other hand down the cloth, twisting the fabric as you gather it together tightly.
  6. Wrap one rubber band around the gathered t-shirt, right below the spot where you lifted. Then, wrap a few more rubber bands, about one to two inches apart from each other. Feel free to make up your own spacing.
  7. Once you're satisfied with the rubber band placement, immerse the entire t-shirt in the first color dye. Boil the t-shirt for 10 minutes , stirring constantly. Then, stir 4 level tablespoons of salt into the mixture for each gallon of water used. Boil for another 20 minutes, stirring constantly.
  8. Remove the t-shirt and rinse in cold running water. Wring out the garment until water runs almost clear.
  9. For designs requiring more than one color, repeat steps 3 to 8, using colors in order from lightest to darkest.
  10. When you have finished dying the garment, remove rubber bands and lay t-shirt flat on your workspace. Place a towel over the still-damp garment, and iron it flat.
Feb 10, 2011 | Garden
Dark part of shirt bleeding into white part during wash. How do I fix this?
Shirts with two colors. Dark part bleeding into white. Wash the shirt in vinegar water. Dry normally. That should set the colors
Sep 27, 2010 | Kitchen Ranges
Sometimes I get little brown spots on my wash, like on a tee shirt or shirt. The spot will not come out on a rewash.
the main cause of this problem is a rusty object inside the machine,ie a small screw/paperclip/nail something that has come out of a pocket and is lying in the nachine,adrian,,,,,,
Aug 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer making holes in clothes
Feel the drum inside for any sharp object example a pin that is sticking sideways in a hole or the the drum spot-weld spots that came lose making a high spot.
I did find the same kind of a problem with a Defy front Loader machine. You can also check the gap between the door and the drum lip.
Hope this will solve your problem and save yourself from spending big bucks on new clothes.
Clive
Apr 17, 2009 | LG WM-2277HW Front Load Washer
Bleach spots with HE detergent
I have learned the hard way that after I wash a load with bleach, I have to remove the dispenser drawer and wash it out. The bleach in the compartment isn't always entirely used so when you wash another load, then it gets the remainder that wasn't flushed out.
Nov 10, 2008 | LG WM-2277HW Front Load Washer
6 years old hoover washer dryer. Not all, but some light colored tee shirts coming out with what appears to be oily spots. Tried bleach and dishwater tablet as suggested by another forum, but to no avail....
Hi there monobloc,
I've gone through this too. Dishwashing liquid soap, specifically with grease cutting properties. It does take a few cycles to clean it all out though.
Mike
Sep 01, 2008 | Hoover Washing Machines
Our washing keeps getting bleached spots / areas. Clothing has light patches.
it wont be the machinei think.
try doing a hot wash cyle on an empty machine with some descaler powder or soda crystals to clean it out.
Aug 25, 2008 | Hotpoint WMA58 Front Load Washer
Spots on clothes
i would refer that question under your owners manual for washablity issues and cleaning the duet front loader also go here for tips http://www.whirlpool.com/custserv/index.jsp mean time ill check the service bullitans to see if there are any issues front loaders are pretty dependable if i find any issues ill post them to your reply
Dec 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
46 people viewed this question
Dan Webster
Dan Webster
Sal De
