Question about Sony Cyber-shot DSC-S600 Digital Camera
Error message on display
When switching on the camera it takes a couple of seconds. I then get a error message E:61:20 flashing on the screen. This does not affect any pictures or usage of the camera, but why?
Re: Error message on display
Had the same problem, turn on camera wait until power up is complete and turn it off again. Give lens area a firm hit and turn camera on error should be fixed. try several times as it may not work first time. This worked for me hope it helps
Posted on Mar 18, 2008
0 characters
3 Points
Black screen
Try downloading the photos to a computer. If this doesn't work there may be a problem with the flash chip. If so, try reformatting it - that worked for me when I had a couple of photo storage locations that constantly put up garbage displays and produced file error messages on downloading.
Jul 20, 2013 | Konica Minolta Dynax 5D / Maxxum 5D...
Error message at display screen
Set both the exposure dial and the focusmode to "M" and press the shutter button. Then turn the camera off for 10 - 15 seconds. If this doesn't solve the problem, it's an electronic or mechanical error.
Jul 08, 2010 | Nikon D80 Digital Camera with 18-135mm...
My flash doesn't work? how do i turn it on?
Have you tried resetting your camera? Powerdown and take batteries out. Then hold "power" button for 30 seconds, release and repeat couple of times.
Jul 08, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
I have a canon rebel xti, I partially blocked the pop-up flash while taking a picture. There is an error message on the screen - flash error 05, turn camera off and on again to clear. It is not working....
You can reset all your settings and clear errors by removing the battery pack and also under the camera is an access screw to get to a button battery or two. The type of screw you use a dime or quarter to open. With the battery pack out, remove the button batteries and leave all those out for several minutes and then with the batteries still out, activate the On switch for your camera and leave it in the full on position for 30 seconds. That should drain off all residual power from the circuit board inside. You will have to reset everything, such as your personal settings in Tools and the time and date setting. All of those user set items, but your error message should clear too. If you get the error message again, right away, after reinstalling the batteries and battery pack, then you have damaged the Flash Unit... but I doubt that. Canon makes a good camera and I don't think what you describe would cause that problem.
Jan 18, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Sony DSC-W50 Flash Error code-E:91:01
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
If it is working then don't forget to set your Clock.
Oct 08, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Flash Error
The error 5 can mean that there is something blocking the flash from popping up. If it is up but still get the message then you need to check to see if the little black pin/stick that lets the camera know that the flash is up, is not stuck. With the flash up and pointed at you ( like you are going to take a picture of yourself) the pin is located on the right side close to the where the flash attaches to the camera. Yo should see a little pin sticking up. make sure that area is free of dust and /or debris. if it is not up then that is the problem. try to free it with out braking it or get it professionally repaired.
Jul 08, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Sony digital camera dsc s40
code error 61 related to internal lens problum.i think lens movement moter stuckup this is reparable
Jan 13, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Error message when turning on that stays on
If you cannot find a solution to your problem you may want to email He has good advice and good used parts at a fair price.
Nov 01, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
According to the user manual an error 91 means that the camera has malfunctioned. You need to reset the camera. Here is how you do that:
Aug 23, 2007 | Sony Cyber-Shot DSC-P200 Digital Camera
"Memory card is protected"
This error message indicates that the memory card is locked. The switch on the memory card is in the write-protect position. Reset the switch as shown on the camera screen.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Sony Cyber-shot DSC-S600 Digital Camera Logo
182 people viewed this question
Top Sony Digital Cameras Experts
Larry Spears
Larry Spears
Vish Iyer
Vish Iyer
Rick Johnson
Rick Johnson
Are you a Sony Digital Camera Expert? Answer questions, earn points and help others
