Question about Motorola Mobility MING A1200
A 1200 i dont know how 2 use my phone a 1200 as a modem via usb port
  • kaazal Oct 24, 2007
    actually i have already done this but still was not able to do it so posted this problem anyways its ok.thanks
  • 490 Answers
You need internet settings in your h/s,after than you have to instole cable drivers in your computer , (motorola phone tools)
-In computer select control pannel-phone &modem-select the modem of your h/s,
Posted on Oct 16, 2007
I have a Dell dimension 350 pc with just a modem connection for a phone line. I just got cable installed which has the ethernet hookup. i would like to still use my 350 with win. 98 if i can. how can i...
Does your cable modem have wireless internet? If so, you can buy a Netgear wireless usb port adapter for about $20 and use that to connect wirelessly to the internet. Your pc has usb port connections - right? (Usb port looks like a rectangle)
If you don't want to use a wireless connection you can purchase a cable modem with a usb connection for about $65. You run the ethernet cable to the modem and then a usb cable from the modem to your pc.
If you have a serial cable connection on your pc (looks like a round circle with tiny metal pins in it) you can buy a gender changer and convert that to usb (in case you dont have a usb connection or need another one). You can buy one for about $11.
You can buy an I/O Gear bluetooth usb adapter for $13 and pick up the internet via bluetooth by putting it in your usb port but I'm unsure how well it would work with Win 98.
If you have another pc that has an ethernet connection you could use good old fashioned bi directional printer cable and network both computers together. You may need to upgrade to win xp for networking capabilities.
Mar 26, 2012 | Dell Dimension Computers & Internet
I have don't found LG kg195 modem driver
i dont know how to use the th ephone via usb but i can say that the phone perfectly works as a mass storge and as a bluetooth DUN modem
u need to get hav a blue tooth dongle active with drivers
i recomend IVT blueSOliel for this purpose
go to "phone and modem options and there choose the DUN modem and in advnce option input the string inside the codes without the codes
"AT+CGDCONT=1,"IP","name of access point "<cr>
the name of acess point for some connection are
airtel gprs(mobile office )="airtelgprs.com"
airtel gprs nop= "airtelwap.com"
airtel gprs airtel live ="airtelfun.com"
u may not need to proxify ur browser when usin mobile office
but for usin the airtel live and nop u need to proxify
use the proixy as 100.1.200.99
port number 8080
dats all
an don more thing i dint know dat how ndwhere to get the com port 7332 driver
if any on gets this plz tel me and may mail me the dowwnload link
my id is = ashloverscn@gmail.com
u kno why i need th ecomport drivewr
its because if i get the usb driver of lg kg195 it will make the request and reply data transfer between port and modem much faster as a result the modem speed will increse
an broesing wil be faster as a 1 to 2 mbps modem after usin some more speedup software and compression of data
thanks
Jun 21, 2010 | LG KG800 Cellular Phone
Usb modems will not work see's modem but will not complete driver install. Even if you manually update. Tried 2 modem's
check to make sure that your USB ports are working properly. Best thing is to hook up a usb mouse or usb keyboard.
if it recognizes those and installs the drivers properly then you know your USB ports are fine, at this point you know that its got to be something with the modems, either they are not compatible or the modems are bad.
Try a brand new usb modem and make sure whatever type of usb port that the modem requires is the type of usb ports you havve on your server.
Aug 11, 2009 | Dell PERC6/E SAS Adapter for Dell...
I have an external modem for broadband connection. it connects only via usb i am not able to connect via the phone cable port. what seems to be wrong?
The broadband modem connects to thecomputer using the USB or nework port not the phone cable port.
The network port has 8 wire connectors and whilst they both look similar the network (10baseT) port is wider than the phone port.
You also need to configure or reconfigure the model to let it know which cable you are using to connect the modem to the computer.
Apr 05, 2009 | Acer Aspire 1703SC Notebook
My NEC versapro nx series VA50 has no dial up connection, it has no port. what will i do so that i can use it since we only have dial up connection in our place.
you have 2 options:
1. buy an external modem that connects to your computer via serial port. There are some models that connects also via USB
2. buy a PCMCIA type modem card. This should be a better option with regards to less wiring involved.
Feb 25, 2009 | NEC (090132) Modem
I have linksies router and 2 wire modem will they work together?
If the Modem has an ethernet port (looks like a large phone plug like the ones on the router) connect an ethernet cable from it to the "internet/wan" port on the router. If it doesn't there isn't much you can do.
Dec 30, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Want to hook laptop up to home computer via cable modem
You need a router or a wireless router to do that.
If your cable modem is wireless you can set directly via wireless network a connection with your laptop (the laptop also need a wireless card (if dont have any built in))
The connection must be done in this way
ISP ----->> Cable Modem ---->> Wireless Router o Router ----->> Computer ( 1, 2, or more)
Nov 19, 2008 | Computers & Internet
Driver for LG KG195 mobile set
If you're trying to use the phone as a modem call your carrier most companies need to add a plan to the account to use phone as modem features.
Oct 15, 2008 | LG U400 Cellular Phone
No drivers for lg kp220
There is no need for drivers to connect KP220 with ur PC simply connect ur LG KP 220 with PC(WIN XP) via USB cable , While Connecting it needs u to choose any one option "1. Mass Storage" "2.Com Port" Simply choose first option(Mass Storage)
At the momoent ur mobile phone will atomatically get switched off and ur mobile behaves like an Ordinary USB Pen Drive
Simply go to MyComputer and browse ur cell phone like a pen drive...
Drivers of LG KG200/KG300 is also supports LG KP 220
Jul 30, 2008 | LG CU500 Cellular Phone
Modem - dont know how to use it
activate the gprs in your phone get the dialling key
insert the cd into rom connect the phone to the laptop
via usb cable after installing phone as a modem in add new
modem menu use the dialling key to dial.if not phone me on
9829793957
Sep 22, 2007 | Sony Ericsson W800i Cellular Phone
Motorola Mobility MING A1200 Logo
120 people viewed this question
Top Motorola Mobility Computers & Internet Experts
Unlockingcom
AJMAL KHAN
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
