Question about Compaq Armada E500 Notebook
My computer wont power up!!!!!!!
I just moved and i set up my computer and hit the power button in front and nothing happened! I have a emachines T2042. Please help. it is plugged in and ready to go but nothing at all happens when i hold down the power button............
  • 55 Answers
Re: my computer wont power up!!!!!!!
Just moved?First try another device in your new place a/c socket to see if it is working.Then see if your lpt's power adaptor is damaged(if you do not have a multitester just put it on your tongue-it won't kill you-).After these steps you can continue with the battery.Also check for any button on your device which could be stay pressed some times this thing blocks some functions
Posted on Nov 16, 2007
Take the battery out and put it in again. Sometimes the power management gets in a funny state. This happened to my flatmate - he rang a computer repair shop and the suggested this - it worked. Strangely, the next day, the same thing happened to my O2 Xda - it worked for me too !
Posted on Oct 31, 2007
  • 155 Answers
Some PCs has an ON OFF switch on the back, did you check it?
It also could be possible that after you moved it some cable inside is loose.
Open it, check all the cables, connect power and see if on the motherboard you have any LED on. If not test the power supply or change it.
Posted on Oct 19, 2007
0 characters
3 Points
My computer says it is charging but as soon as i hit the power button it stops charging and does nothing even happens
Have you tried running the computer with just the AC plugged in and not with the battery? If not try that. It could be the battery is going out. I had a similar issue once. If that doesn't work it might be the power supply / powercord or it could be the motherboard.
Jan 17, 2013 | IBM ThinkPad T30 2366 Notebook
Toshiba satellite not opening after i cleaned the cooling fan.
Did you take the Heat Sink off that is over the CPU? If so you probably need to apply a fresh coat of Thermal Paste.
Remove the Power Cord, Remove the memory cover and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 06, 2012 | PC Laptops
My laptop will not turn on. When I hit the power button, the only thing that happens is that I get a little orange light on the front (left) that blinks on and off three times. the light looks like a...
This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
Jul 07, 2011 | Compaq Presario M2000 Notebook
Just bought a pre used asus 1001p netbook with win xp from Amazon. I am just trying to do start up with language settings and when I try to move to next page using green arrow at bottom right hand side of...
Weird. Make sure that there is nothing else on the screen it wants you to select. Sometimes they are not so obvious.
If not, hold the power button down until the computer shuts off and restarts, but like I said, make sure there is nothing else on the screen that it may want you to select.
Hope this helps.
Mar 14, 2011 | ASUS Eee PC 1001P Netbook
My laptop won't turn on. Blank screen, green on/off botton blinks. Tried forcing it off, but nothing hapens. Tried taking battery out and pluging it in, still no change.
it's fell asleep,switch it then the minute you've hit the power button start tapping the F2 key unit you get into the bios settings.
in there you will see a set of tabs across the top the last one being "EXIT" useing the arrow keys go to exit
Which ever & hit ENTER select yes then hit Enter again then move back up to exit saving changes or
save & exit the computer will shut down & reboot.
if not download & check the manual : click here
Nov 22, 2010 | Acer Aspire 5520-5908 Notebook
Hi i have a emachines g420 laptop and it froze so i switched it of and turned it back on and my vista home operating system wont come back up so how would i go about fixing it of resetting the whole thing
Did you make a set of recovery discs when you bought the computer, if you did you can power on the laptop and insert disc one into your dvd drive and then turn the machine back off by holding the power button down for 5 seconds and is will shut down, wait 10 seconds and push the power button again and your laptop should ask you if you want to boot from CD, just hit any key and follow the step by step instructions. But you will loose everything you had on your computer putting it back to factory specs, so if you have made some backups to an external drive after you reboot the computer you can reinstall all your stuff.
Nov 07, 2010 | PC Laptops
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
Laptop wont boot up
Stay away from Emachines in the future. Pay another $100 and get a real computer.
1. check that nothing is in the CD-Rom drive and restart the computer.
2.Shut down the computer. Unplug the AC power. Remove the battery pack. Wait 2 minutes or until machine cools.
try powering on comp on battery alone, then try with AC power alone.
Dec 26, 2009 | eMachines eMD620-5133 Notebook
My HP Pav laptop just died (shut down on me) and wont turn on
1.remove the battery and disconnect the power cord from the laptop. 2.hold down the power button for 1 minute connect it only to the power cord.keep the battery away 4. as soon as you press the power button to turn it on, keep on tapping F8 key. 5. If you see advanced option, you can choose safe mode with networking and it hit enter. 6. now remove the security like Norton or macafee and scan it with malwarebytes( 7. Now, restart the computer 8. If data is not important you can restore the computer to the factory setting, but all of the data would be lost. restore the xp computer start press F10 at the startup 10. to restore the vista computer start press F11 at the startup.
Dec 08, 2009 | HP Pavilion dv9000z Notebook
Compaq Armada E500 Notebook Logo
41 people viewed this question
Top Compaq PC Laptops Experts
John mullen
 Mike M
Mike M
Are you a Compaq PC Laptop Expert? Answer questions, earn points and help others
