Question about Whirlpool Duet GHW9150P Front Load Washer
Spin cycle very slow
I have a whirlpool duet front load washer and it is not spinning properly and timer counts down to 6 and then shuts off
  • 51 Answers
Have you cleaned your pump filter? using correct detergent HE an proper atmount? all this will cause problems. IS YOUR DRAIN HOSE CLEAN?
Posted on May 16, 2009
Whirlpool duet banging on spin
with the door open,take your hands at 3 and 9 o'clock in the drum and try to move it back and forth,then try 12 and 6 o'clock try moving up and down if you can move it either way,the spider that holds the drum is broken behind the drum and needs replacing
Apr 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer stops towards the end of the cycle and flashes 6 then F. The door stays locked and the washer beeps. It has happened before, the machine is about 6 years old, how can I fix
F/06
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Feb 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
The digital timer on the machine will say 1 minute to go, but the machine will run on the spin cycle for 6 to 8 minutes before it finishes. Is there a part I can replace to correct this problem?
Your washer displays an estimate of time remaining in the current wash cycle. That estimate is based on the load finishing without any delays. Prior to going into a high speed spin, your washer "tests" the load balance by either rocking or slowing rotating.
If it senses and off balance condition, it will attempt to "rebalance" the load by itself and then retest, rebalance, etc. until it is satisfied that the load is as balanced as possible. Then it begins to spin. When your washer takes longer than is predicted in the display, it is because of this.
Happy washing...
Jan 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool GHW9250ML is having problems spinning
My Whirlpool Front Load Wasehr Model# GHW9250ML is having problems spinning on the final rinse cycle. The machine shuts down and the letter F appears on the digital read out.
Mar 06, 2010 | Whirlpool GHW9250M Front Load Washer
My whirlpool duet spin cycle problem
Check the MCU
Feb 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL GHW9150PW4 DUET WASHER DOESN'T SPIN AFTER START
F/06 Drive Motor Tachometer Error
  • Check the MCU
Mar 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not stop -- door locked, and it is stuck in the drain
Had the same issue with my whirlpool front load washer and it turned out to be the water pump. Believe it or not it turned out to be pricey (about $280). The service guy said that the this was a common problem with these new front load washers.
Feb 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Will not spin out
Is the machine draining the water out? The machine will not spin unless the water is pumped out.
Oct 24, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
402 people viewed this question
Dan Webster
Dan Webster
Sal De
