Question about General Refrigerators
Refrigerator model ps123ngpc bb serial dh424241 side by side refrigerator there is a clicking sound and the temperature gauge is now showing for both the refrigerator or the freezer there is a green light that keeps flashing that says "hrs"
Add 134-a to refrigerator
You will need to install line taps on the service pigtails in the compressor compartment. Attach your gauges and remove the remaining refrigerant from the system. Cut the 2 access pigtails just below the temporary access valves and braze permanent Schrader valves for gauge access. Install gauges and draw a vacuum on the system. Find the charge listed on the spec. tag that mentions model and serial number. Get an accurate scale that weighs in ounces and weigh in exactly the charge by the ounce. The charge is critical and since this temperature control measures coil temperature and not cooler temperature it will not shut off without a close charge. Hope this helps and good luck.
Sep 28, 2014 | Beverage-Air BM23
GE GSS25KGTB-BB side by side refrigerator. Serial # HL 416525 Ice occasionally melting during defrost cycle(?) Currently trying to act up on me Set at -3/39 but is now passing through +6/45...
Hello Robert; Sorry for the delay in answering your question, but the site did not send me a notification. From you description of your problem the most likely cause is the temperature sensor.
on diagram
Temperature sensorPART NUMBER: WR55X10026
Substitution: WR55X10025
It is located in the freezer section of your unit next to the evaporator. Before you replace it, I would first try to defrost it, sometimes a small amount of ice will build up on it and cause it to sense a lower temperature than what is required.
Houston AKA ImJustAvg
Oct 23, 2011 | GE Adora DSS25KSTSS Stainless Steel Side...
I have side by side refrigerator GE GSS25IFRF BB MOD FH234420 IS NOT RUNING PROPERLY AND ALSO HAVE A SOUND LIKE A CLOCK AND TEMPERATURE IS NOT COLD
The control board on the rear of the refrigerator is making the noise because it has gone bad.
The control board must be replaced.
Mar 30, 2011 | GE GSS25IFR Side by Side Refrigerator
I have a GE side by side fridge. First the water would stop working intermittently. Then the ice and water stopped all together. Now on top of that its making a clicking noise and the freezer works for...
Your model needs attention soon to prevent damage to the control board. Something simple as a fan going bad will cause a chain reaction on your model. Let me know if you would like my assistance or your you would like to call in a technician. I can help you repair from here or my site. Thanks, Sea Breeze
Nov 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Model TFX27PFSM BB sise by side refrigerator has de Defrost warning on the diagnostic system but nothing seems wrong with the refrigerator. What could the problem be???? GE Serial # LL209010 purshased in...
If your model is the TFX27PFSM BB I only see a simple defrost timer. But not to say that you possibly have a bad thermistor that came on some models. Part number 305273 This is an alert so I would keep a close eye on freezer and refrigerator temperatures. The defrost thermostat may be defective and the light is warning you of a problem coming. Let me now if I can help you more, Thanks Sea Breeze
Jul 11, 2009 | GE Refrigerators
GE Eterna Series side x side refridgerator
Temperature adjust displays not showing, can not adjust temp, is something disconnected?
Dec 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side refrigerator
what is your serial #
Jan 06, 2008 | Refrigerators
Hotpoint side by side csx22grbk serial vz247504
chances are you have a faulty module (board) sounds like you'll have to call an engineer oput to replace it
Dec 09, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
99 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Shehu Pro
Shehu Pro
Joseph Mueller
Joseph Mueller
Are you a General Refrigerator Expert? Answer questions, earn points and help others
