Question about AudioBahn A6004T Car Audio Amplifier
I'am missing a rear channel, checked fuses, reversed spkr leads one channel worked the other did not! any suggestions as to where I should go next? The amp is a Audiobahn A6004.
  • emcarter1 May 15, 2009
    I have 2 rca inputs. Any ideas as to where I can find the Manual for this amp, Audiobahn A6004T.
    Sniper:
  • 61 Answers
Have you got on one rca input to this amp or two. of two you may need to use a set of splitters.
Posted on May 15, 2009
Using a remote how do you hook up Pro technique pt18 5.1 Channel surround receiver amplifier
I need to see the rear or know if this set has speaker outputs. If so, then 1st, place your speakers on the walls or floor where you want them to stay. (Attach the wires to them first.) The black wire, black stripe or silver colored is the negative side. Run all the wires to the back side of the amp. Allow enough slack to put the wire under the carpet or along the walls to be out of the way and concealed if possible. Make sure to use a thick gauge of wire. The thicker the better. The thin stuff is junk! If you go to Lowes or Home Depot to get the wire, it will cost less and it's the same thing! Don't waste your money on 'Monster Cables'. Just get 12 gauge spkr. wire and it'll be the same thing. 14 gauge is the typical gauge for powerful spkr. wire but 12 gauge is for those who want earth shattering, furniture moving bass. (Think about it. How much power can go thru a thin wire verses a thick wire?) Run that wire to the black connection of the speaker that corresponds to it's position in the room. (Left front spkr., right front spkr., left rear spkr., right rear spkr., front center spkr. or sub woofer spkr. Find the red & black connectors for each speaker on the amp and attach one of the two speakers wires (the one w/a black stripe or silver colored or totally black to black). And the other color wire for the same spkr. to the red connection of that spkr. on the amp. It's not hard. Take your time and think about it. It makes sense if you look at it one spkr. at a time. Hook up only one spkr. at a time. Before you know it, it'll be all hooked up and you'll say I did that?
Aug 17, 2017 | Audio Players & Recorders
18c808 aa subwoofer with amp from Focus. How do I install it?
ask here
http://www.f150forum.com/f75/how-fix-your-subwoofer-amplifier-7l2t-18c808-aa-227544/
or
Diagram 7l2t 18c808 aa - Dual Ford Mustang Convertible 94-12 Boss 12" Phantom Sub Box Ce1250m 1250w Amp
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
Oct 23, 2015 | Ford Cars & Trucks
Need radio cd wiring diagram for 2005 jeep grand chrokee
120706502.jpg FUNCTION PIN WIRE COLOR Accessory 12 Volt SEE NOTE ¹ Constant 12 Volt 1,12 RD/OG (2X) Chassis Ground 11,22 BK (2X) Power Antenna Remote Illumination Dimmer FUSE VALUE FUSE LABEL FUSEBOX LOCATION 20 AMP #28 DRIVER'S SIDE UNDER HOOD ¹ The receiver does not have an Accessory 12 Volt lead, it is triggered by the data lines in pins #5 and #6. When installing an aftermarket stereo, an Accessory 12 Volt lead must be run to the fusebox to a switched power lead.
² If equipped with "Hands-Free" cellular phone system.
The dash speakers are wired in parallel with the front door speakers.
Left Front Spkr + 10 D.GN Left Front Spkr - 9 D.GN/BN Right Front Spkr + 7 GY Right Front Spkr - 8 GY/BN Left Rear Spkr + 18 D.GN/D.BU Left Rear Spkr - 19 D.GN/VT Right Rear Spkr + 21 GY/D.BU Right Rear Spkr - 20 GY/TN Hands-Free Audio ² 4
16
17 D.GN/OG
D.GN/YW
D.GN Data Lines 5
6 WT/OG ¹
WT ¹ DO NOT USE THESE WIRES!
Sep 25, 2011 | Car Audio & Video
It says chk spkr when i try to turn it on how do i get it to work agaiun?
You probably have a blown channel. but check for a shorted speaker wire or bad speaker. Remove all speaker wires from the rear of the receiver if it still says check speakers when turned on, then one of the output channels is bad.
Feb 12, 2011 | RCA RT2500 System
Need color code for kenwood kdc mp 245
black - ground, red - switched or ignition, yellow - constant (memory) power, white - left front spkr pos., white/black - left front spkr neg., gray - right front spkr pos., gray/black right spkr front neg., purple - right rear spkr pos., purple/black - right rear spkr neg., green - left rear spkr pos., green/black - left rear spkr neg, blue - antenna remote, blue/white amp remote turn on.
Nov 02, 2010 | Kenwood KDC-325 CD Player
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
I'm hooking up my sony player to a nissan versa and the colors are confusing and I'm tryna get it to work , and it wont
Car Colors (Assuming NON-Rockford factory system)
4-6 speaker system.
Accessory 12 Volt L.GN
Constant 12 Volt BN
Chassis Ground BODY
Power Antenna
Remote
Illumination OG
Dimmer (-) Bk
Left Front Spkr + WT
Left Front Spkr - BN (PK @ Spkr)
Right Front Spkr + GN
Right Front Spkr - L.BU (RD @ Spkr)
Left Rear Spkr + VT (L.GN @ Spkr)
Left Rear Spkr - RD (GY @ Spkr)
Right Rear Spkr + L.GN
Right Rear Spkr - GY
CLICK HERE for generic wiring tips for your radio.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 19, 2010 | Sony XPLOD CDX-GT200 CD Player
What color is the hot wire for the radio
A Left Front Spkr (-) Light Gray
B Left Front Spkr (+) Tan
C Right Front Spkr (-) Light Green
D Right Front Spkr (+) Dark Green
E Ground Wire Black
F Not Used
G Headlight Dimmer Wire Gray
H Power Antenna Turn On Pink (if available)
I +12 Volt Ignition Wire Yellow
J +12 Volt Battery Wire Orange
K Right Rear Spkr (-) Light Blue
L Right Rear Spkr (+) Dark Blue
M Left Rear Spkr (-) Yellow
N Left Rear Spkr (+) Brown
Nov 07, 2009 | 1992 Oldsmobile Cutlass Ciera
What wire do i hook the remote wire to coming from the amp?
Hello cjfatback,
You want the blue/white wire.
Here's what the manual shows:
Red - Power (to ACC in vehicle)
Black - Ground
Yellow - 12V positive (battery lead)
Blue/White - External Amplifier Control Lead
White - Left Front Spkr +
White/Black - Left Front Spkr -
Gray - Right Front Spkr +
Gray/Black - Right Front Spkr -
Green - Left Rear Spkr +
Green/Black - Left Rear Spkr -
Violet - Right Rear Spkr +
Violet/Black - Right Rear Spkr -
The red and white RCA pigtail leads is for AUX input
Left set of Preamp Outputs - Rear Channels
Right set of Preamp Outputs - Front Channels
Only Models C3433U, C3304U, and C3333U have a 2nd set of RCA pigtail leads for subwoofer output.
Hope this helps.
Apr 14, 2009 | Car Audio & Video
cheers
djmac62 is also an excellent answer
Jan 10, 2009 | 1998 Dodge Ram 1500 4WD
AudioBahn A6004T Car Audio Amplifier Logo
89 people viewed this question
Top AudioBahn Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jerry Naidoo
Robert Rankin
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
